Frst blowing like a mofo.
Postby xjtaggedx on Tue Feb 04, 2014 10:54 pm
I have a massive clicking sound coming from my engine bay and exhaust tone is a little deeper. I have been advised it is the exhaust blowing. So manifold, downpipe, etc I have been looking around for a new 1 or steal etc but no luck. Just curious where you boys get your parts from. Also please help with finding a engine mount. Genuine! Thank yo.
xjtaggedx
Re: Frst blowing like a mofo.
Postby beanyfrst on Tue Feb 04, 2014 11:05 pm
A little more info may help chap,
Are you on a t2 or t3 turbo? will depend on the manifold.
do you know if its the manifold or downpipe ??
Has bought my Fiesta RS Turbo back, Needs a lot of TLC
beanyfrst
Postby xjtaggedx on Tue Feb 04, 2014 11:07 pm
Sorry for lack of info. I am on the original t2 setup. I have no idea. Could it be the gaskets? Or unlikely?!
xjtaggedx
Postby reithy on Tue Feb 04, 2014 11:10 pm
The arnt any gasket on the down pipe, if I remember correctly. Try running the car and getting under the front and see where it's coming from.
reithy
Postby beanyfrst on Tue Feb 04, 2014 11:14 pm
Have a look around where the turbo meets the manifold, manifold to head or where the join in the downpipe is for a little black patch of soot you may be able to identify where its coming from. It may be a gasket or a join.
Manifolds and downpipes look on here in parts for ale or ebay bud :D
beanyfrst
Postby reithy on Tue Feb 04, 2014 11:17 pm
261389406300 manifold and down pipe on ebay 321310540657 guy breaking a turbo may have engine mounts
reithy
Postby xjtaggedx on Wed Feb 05, 2014 12:04 am
Thank youvery mmuchguys iI really appreciate your help a lot thank you for talking the time to help me.
xjtaggedx
Postby Turboboy67 on Wed Feb 05, 2014 12:20 am
Burton Power sell new engine mounts.
Turboboy67
Your car: 911GT3 RS
Postby beanyfrst on Wed Feb 05, 2014 9:41 pm
I recommend vibratech mounts they are solid and will probably be recommend by many other people on her too :)
beanyfrst
Postby xjtaggedx on Wed Feb 05, 2014 11:02 pm
I already have the vibratechnics mounts. Gearbox and engine and it shakes my teeth out.
xjtaggedx
Postby reithy on Thu Feb 06, 2014 11:55 pm
Keep the gearbox mounts but change the drivers side engine mount
reithy
Postby xjtaggedx on Fri Feb 07, 2014 12:59 am
thank you sir, i will do exactly that and report back when job is done, i will go with the std engine mount on burton power website thank you again
xjtaggedx
Postby xjtaggedx on Sat Feb 15, 2014 9:56 pm
my mechanic believes the ticking maybe coming from the engine. tappets? was talking about an engine rebuild! my question is can you just change the tappets, cam. camshaft kit? thank you
xjtaggedx
Postby mikeymikeyp on Sun Feb 16, 2014 2:34 pm
most cvh engine have some tappet noise you can buy a full kit cam tappets and all the stuff you need to do it if your changing the springs then do the stem seals as well as for the blowing get someone to hold a rag over the tailpipe and look for smoke coming out the exhaust at each one of the seals , dont buy bits till you know whats wrong
mikeymikeyp
Postby xjtaggedx on Sun Feb 16, 2014 8:09 pm
Thank you sir for replying, worrying the crap out of me. Been looking at kits, if I do need nee tappets, cam ext, should I go off indeed I need to, go for Kentcam kit cam or something else just want your opinions please and isthis a garage jobby?
xjtaggedx
Postby mikeymikeyp on Sun Feb 16, 2014 9:41 pm
it depends fully on the spec of the engine what you want from it ,,if your asking whats best well buy a Newman cam with solid lifters but if its a standardish car id try and find a good standard profile can with desent lifters and put some good oil in it BUT if its a new cam it MUST be broke"bedded" in properly or it will just fail
I have had piper and kent and im running a standard ford cam now but would only put a newman in if needed
Where abouts are you as a cam change isnt that big a job but to be fair im a ts mech :) :)
mikeymikeyp
Postby rsturbonutter on Sun Feb 16, 2014 10:02 pm
Kent cvh 34 cam kit is a good kit mate think its about £350 from memory includes new lifters and springs.
rsturbonutter
Your car: Fiesta RS turbo
Postby Boostjunky on Sun Feb 16, 2014 11:05 pm
I always had the piper 285t cam in my rs turbos and always went ok
Boostjunky
Your car: Ford
Postby xjtaggedx on Sun Feb 16, 2014 11:46 pm
this is exactly what i didnt want, a dilemma, so we have kent, newman, and piper. burton power do a few kits at about £400 not including cam. i will only be going up to a stage 2, so max 195bhp. not to sound like a dickhead but is a 1 day job?
xjtaggedx
Postby mikeymikeyp on Mon Feb 17, 2014 9:09 am
i wouldnt buy a dead dog from burton but every bodys got a story to tell :devil: :devil: :devil:
mikeymikeyp
Postby xjtaggedx on Mon Feb 17, 2014 12:29 pm
Why you say that, are Burton not good? So Saturday coming cars booked in to fit new manifold, heat shield and manifold gasket. I wan to ask is there a gasket or o ring that goes around the downpipe manifold? I can't find this info online. Thabk you so much for all the help Ihhave received as far.
xjtaggedx
Postby mikeymikeyp on Mon Feb 17, 2014 2:02 pm
T2 im sure has the o ring built in ,i think I just dont like a lot of the cvh stuff burton sell ,,thats just me
mikeymikeyp
Postby xjtaggedx on Mon Feb 17, 2014 2:18 pm
Thabk you again sir. What do you mean built in,? Is it something I can replace?!
xjtaggedx
Postby mikeymikeyp on Mon Feb 17, 2014 9:11 pm
no its not replaceable if i remember correct :-? :-?
mikeymikeyp
Postby xjtaggedx on Mon Feb 17, 2014 10:45 pm
Thank you again. I am very grateful for this forum.
xjtaggedx
Postby xjtaggedx on Sat Feb 22, 2014 1:31 am
Ticking has gone, manifold and manifold gasket fitted and working perfectly. Also forge actuator installed and car is mental, wheel skid in 3rd 4th gear while drive but get massive turbo lag which I didn'tget nbeforewith tthe standard actuator. 1 thing Idid nnotice though and I know it's a long shot but when giving it some in 5th gear at about 100mph and only when foot on the gas I feel and hear a grinding rubbing, vibrating sound from the engine or gas pedal. Any ideas what so ever? Thank you.
xjtaggedx
