Focus RS conversion for the Ka! - (Update: 21/01/11 - RR!)
Re: Focus RS conversion for the Ka! - RR results :) (07/06/10)
Some nice results there, was actually looking at a ka today to do a 2.0 conversion, but the rust was too bad
- Ruishy1
excellent mate!
shame about the clutch, but you can get it lined which is cheaper than buying a brand new one
Re: Focus RS conversion for the Ka! - IT RUNS! (26/05/10)
im guessing speed bumps are out the question
Totd are really good. They have done my Rs twice on the rolling road and both times got it running spot on and cured all my problems.
I take my hat off to you for taking up the challange of getting such a monsterous engine into a tiny ka bay.
When i saw a cvh turbo lump in the bay i was shocked. this is amazing to see
would love to be there to see a cocky bmw driver when you and your ka wastes it on a straight
- knuckles
- Your car: Fiesta Rs turbo
knuckles :moondustka :would love to be there to see a cocky bmw driver when you and your ka wastes it on a straight![]()
I must say that is exactly why I do this, not only cos the Ka handles well and it's light, still feels relatively modern inside, but for that. It's just the look on someone's face when my girls car comes out of nowhere
Not sure whether this 4 paddle is up to the job, but the only way up in 220mm clutches is a custom job
Thanks for all the comments!! Although I'll definitely be putting up some pictures when the boost hoses are done..
It looks tired from the photos already and I've only just built it!! Just of question of slowly going round it and replacing rusty bolts etc etc.
Speed bumps are actually not too bad!! I've been over those nasty black and yellow ones, you now the ones that are like blocks put together and really short..
The boost pipe underneath is the lowest - just slightly higher than the lower arm casings but of course further from the wheel!!
Also, anyone have any ideas of how to keep boost hoses and water hoses together if you don't have a tube beading tool! (they're sooo expensive!)
- moondustka
you and this car are legends
i foresee a fast ford feature, give them an email! and a link to this thread
jonyb4 :you and this car are legends
Cheers Mate
My mate knows the guy for this area. Fast Ford and Performance ford have been asking for the last 18 months
- moondustka
really
why you keeping them waiting then lol?
you need to go hunting mate and take some vids, this would previde some immense entertainment for all
- Ruishy1
jonyb4 :really![]()
Because I'm never happy with the car!
Ruishy1 :you need to go hunting mate and take some vids, this would previde some immense entertainment for all
I will get my mate to take some when i car is more together in terms of boost hoses etc.
- moondustka
was trying to time a 0-60 sprint
get some 888s on the front of it mate
and the only clutch that will stand a chance is the helix 4 paddle with the extra heavy duty cover ! been there done that lol before i went to the mtx
i have the part nom if you need it .
p-s its the torque the zetec makes that kills the clutch when loading it up low down on the rollers or out mapping ect.
300hp in that will be very quick off the line with the 888s!! sub 5sec's to 60mph and 12s on the 1/4 mile easy but the box will never last long
beast of a car good luck with it.
- crazycage
crazycage :get some 888s on the front of it mateand the only clutch that will stand a chance is the helix 4 paddle with the extra heavy duty cover ! been there done that lol before i went to the mtx
300hp in that will be very quick off the line with the 888s!! sub 5sec's to 60mph and 12s on the 1/4 mile easy but the box will never last longbeast of a car good luck with it.
Going to sort out the R888s on another set of wheels when funds allow..
How much is that Helix 4 paddle (Is it this: Series Part No. 77-2000 on their website)? is it 220mm? and why's it better than the AP one?
My box should be fine I reckon.. I can't see it breaking?? well hopefully. Quaife ATB, ST150 1-4th. !st and 2nd gears of those are shot penned also I'm led to believe!
Cheers for the info mate!!
- moondustka
moondustka :crazycage :get some 888s on the front of it mateand the only clutch that will stand a chance is the helix 4 paddle with the extra heavy duty cover ! been there done that lol before i went to the mtx
no mate the part nom is 60-5075 its mega heavy on the left foot tho
the box is still the weak link imo
- crazycage
Cheers for that! Whats the torque rating on that clutch?!
Aren't the CV joints the weakest link?
- moondustka
crazy you using mechanical clutch cable? his ka should have a hydrualic, should be less of a effort to push it
Mine is hydraulic..
Crazy uses the mtx box which means he muct be using a hydraulic clutch - but obviously not sure about before when he was using these clutches.
- moondustka
little update..
had a porblem with the water system where the pump was pumping water into the header tank and moving the air to the top rad hose! I did get to bottom of it eventually..
Started by replacing this t piece with larger outlet to water pump..
to this..
That didn't have much effect, so thought I hadn't got the expansion pipes right as there is an extra one on the FRS, so got the rad out and got an outlet welded on the corner!
back apart again..
But that didn't sort it either! Then I realised the only thing that's different is the header tank is plumbed separately all the way to the bottom rad hose.. Did that and all was ok
Made it bloody tight here though! But a p clip later and it's fine..
Cleaned up the rocker cover and replaced the bolts for stainless steel
I've got a stainless steel bug now and I'm slowly replacing all the bolts
Also had this package arrive
And started to fit them.. Few more to arrive yet to complete it
Re-doing the expansion hoses too so more pics to follow and boost system should be finished tomorrow
to this..
back apart again..
- moondustka
looking good mate, final stages now
Re: Focus RS conversion for the Ka! - (Update: 18/06/10)
any update on this.really want to see this finished and up and running.amazing how much work has gone into this.
- lachojski2005
the update is after all his hard work bens treated himself to a break so 2 weeks in spain!
the car should be at ford fair on the ka klub stand and will certainly attract a few looks.
the second focus rs ka is also made and running so there is 2 in the family. his brothers was mapped at 260brake and is just as good.
ill let ben update when he is back.
dave
dave
14.41 1/4 mile @ 96.95mph 0.088s reaction
- Dave_B
Cheers Dave!
Well I couldn't update for ages as photobucket said I'd exceeded the bandwidth
rubbish..
Here goes - pics tell the story
Air filter really isn't as red as that - dodgy picture!
Expansion hoes re-done..
Heat wrapped downpipe
Painted coilpack bracket
Painted this standard heatshield, fitted it but didn't like it - it was bent and tried to get it back but just didnt look right!
I then decided I wasn't happy with the paint under the scuttle panel and the turrets..
Painted and started putting back together:
I then found some holes!! There were more but no pics
so the whole car went to the bodyshop while I was away and is still there now..
Next update will be after Ford Fair - I'll have Friday night and Sat to put both bumpers on, waxoil behind them, put a rear door card on, the rear seats, get 2 new tyres fitted - tracking done and any last minute preps before Sunday!
- moondustka
Re: Focus RS conversion for the Ka! - (Update: 31/07/10)
fingers crossed you get it sorted in time mate, hate the rush before fordfair.
i planned to tinker and clean her up for the week before FF but now i will have 3 days
good progress make a start on dans now then??
- garyhurn77
jayrs :fingers crossed you get it sorted in time mate, hate the rush before fordfair.
I will make it even if I need redbull on a drip on the drive up
garyhurn77 :good progress make a start on dans now then??
Dan's is done Gary! Should both be at FF this weekend. Don't suppose you're going?
- moondustka
I admire that response ben... They "should" both be at ford fair!!
It will be awesome to see them both there! You've both put the effort in that's for sure!!
- Dave_B
red bull on drip
Ha..
Don't what state mine is at yet, haven't seen it.
Dan's however will more than likely miss sunday now
- moondustka
Just read through this thread... what a car!! Excellent work mate
- scouse-sambo
hello chap few questions for ya wot flywheel did u use wot starter an gearbox also wots the slave cylinder from wot shafts an wots the clutch from lol sorry for all the questions got very similair set up in a zetec s fiesta but got a few problems
- decked
one more thing does ur drivers side shaft have the bearing carrier bolted to the block if so is it the rs 1
- decked
fudgekin love this car
- ~nomad~
- Your car: Breadvan
scouse-sambo :Just read through this thread... what a car!! Excellent work mate
decked :hello chap few questions for ya wot flywheel did u use wot starter an gearbox also wots the slave cylinder from wot shafts an wots the clutch from lol sorry for all the questions got very similair set up in a zetec s fiesta but got a few problems
Gearbox is Ka IB5
Flywheel is 1.8 Zetec
Clutch is Fiesta RS turbo 4 paddle (AP one, but it's crap for this power)
Release bearing is Ka
Shafts are standard 1.3, CV joints seems to be ok! Drivers side shaft just has the weight on it
~nomad~ :fudgekin love this car
Thanks mate
- moondustka
just read whole thread lol, about embark on a ka myself, nothing as serious thou lol
- ~nomad~
top man an was the omex a pan in the arse to put iin
- decked
wheres the finished pictures from the body shop then fella
