Fitting ST24 brakes
23 posts • Page 1 of 1
Fitting ST24 brakes
Can anyone help on this re fitting info?
Too old and too bald.
- SimonT
I am sure he said you'd need to enlarge the holes to 12mm.
Thanks for the info about the spacers though!
Now what about ST170???
- wywywywy
- Asad
I dummy-fitted mine briefly tonight, and they appear to bolt straight on with no faffing around whatsoever
So, anyone able to give advice about how these can be put on?
Did you fit them on Heeman? Were spacers needed? etc...
" San Diego... German ofcourse, meaning 'A Whale's Vagina' "
- scarlet_pimp_mobile
- Location: Hurst Green, East Sussex/ Constitution Hill, Swansea
Fittin the 278mm mondeo discs (278*47*24) and the Mondeo/cougar V6 callipers (also the 278mm ones, the 260mm ones won't fit) . .
Cos4x4 calipers (sierra/escos) or Scorpio cos are the same.
In stead of needing to space out the calliper 6mm (needed for the cos4x4 discs which are 278*36*24)
you have to space out the disc about 4 - 5mm
This can be done without loss of the centring ring of the hub.. which centres your wheel onto the hub.
Needed:
- Mondeo/cougar V6 calliper (or escos/sierracos4x4/Scorpiocos)
- 278mm Mondeo/cougar discs
- 4 or 5mm wheelspacers with 4*108 and 63,5 or 65mm centre hole
- 5mm longer wheelstuds are recommended
You need to machine down the wheel spacers to 130mm diameter...
Now fit in the following order
- fit the spacer
- Fit the disc over the spacer
- fit the calliper (incl bleeding etc)
- Fit the wheel
Needed:
- fit the spacer
- Fit the wheel
- Jur
Re: Fitting ST24 brakes
i know this is a mega old thread but are these the actual v6 calipers or the smaller 2l ones that ford fitted to the later st24?
- John_D
i got some spacers made for me cost me £30 but are much better and safer in my opinion fit pefect can put put a pic of spacers if need
- fiesta_rs_g300wpx
- Your car: fiesta xr2i
