Fitting mk3.5 AVO Coilovers to mk3 Fiesta
Postby andymoto on Sat Jun 13, 2009 7:11 pm
Hello, I have searched the forum loads but couldn't find allot, most info is about putting mk3 hubs on a mk3.5...
I have some mk3.5 hub knuckles that i want to fit to my mk3 Fiesta so I can fit my mk3.5 AVO's, however the mk3 lower ball joint is too big to fit in the mk3.5 hole, the CV splines in the mk3.5 hub are bigger than the mk3 ones, and the bearings are bigger inner and outer diameter!! so my mk3 hub wont fit in the mk3.5 bearings and the mk3 bearings wont fit in the mk3.5 hub knuckle!!
What does everyone think? should I just mill the mk3 shock hole (43.8mm) in the hub knuckles out to 45.5mm? as i cant be bothered to mess around swapping everything over...
What a pain in the arse!!!
cheRS
andymoto
Re: Fitting mk3.5 AVO Coilovers to mk3 Fiesta
Postby xr2irhys on Sat Jun 13, 2009 11:33 pm
same with me
i have mk3 stuff
so want to convert my mk3.5 to a mk3 hub set up
but not sure what bits need swapping
xr2irhys
Car: 1996 Ford Fiesta Classic
Postby andymoto on Sun Jun 14, 2009 1:41 am
Yeah I think I read your topic mate...
If you want to do it properly you would need as far as I'm aware:
mk3 hub knuckles with bearings and hub
mk3 complete drive shafts 1.8d ones are a heavier duty i think...
mk3 bottom ball joint
mk3 track rod end
I read someone used spacers to get mk3 shocks in mk3.5 hubs lol, I would use steel spacers and tack them to the shock for added safety...
I 'm not going to change my drive train components to mk3.5 parts just so I can fit my coilovers, instead on Monday I will get Talon engineering (local to me) to mill my mk3 hubs to 45.5mm...
I don't care if it makes it a bit weaker lol not much I'm sure
andymoto
Postby andymoto on Sun Jun 14, 2009 2:00 am
A bit random but how do I make a sig? If that's what they're called?
CheRS
andymoto
Postby Ruishy1 on Sun Jun 14, 2009 12:32 pm
I cant remeber how he did it, but my cousin made up a spacer or something to get them t fit, what exactly stops them fitting in the hubs ?
Ruishy1
Postby xr2irhys on Sun Jun 14, 2009 3:40 pm
to big mk3.5 ones to fit in mk3 shocks
and for mk3.5 mk3 ones to small
xr2irhys
Postby Ruishy1 on Sun Jun 14, 2009 5:24 pm
So to fit a set of mk3's in 3.5 hubs all you need is a spacer ring making up, pretty easy tbh :D
Ruishy1
Postby xr2irhys on Sun Jun 14, 2009 8:54 pm
Ruishy1 :So to fit a set of mk3's in 3.5 hubs all you need is a spacer ring making up, pretty easy tbh :D
whats this? how does it look ? how does it work?
xr2irhys
Postby happypaul on Sun Jun 14, 2009 11:35 pm
xr2irhys :
Metal shim around the shock to take up the extra diamieter(sp?)slack in the mk3.5 hub with the mk3 shock fitted.
I myself have managed to fit mk3 shocks in 3.5hubs safely and checked out many times by various garages, used on the track and for over a year with no problems. Although nobody likes to hear me say that I did it :oooh: :lol:
happypaul
Postby xr2irhys on Mon Jun 15, 2009 1:14 am
oh right do they have to be welded up or what , where could i get this added/made
xr2irhys
Postby happypaul on Mon Jun 15, 2009 6:10 am
Not sure, should just be able to wrap it around the shock and bolt in as normal.
I didnt use a shim.
happypaul
Postby Ruishy1 on Mon Jun 15, 2009 8:15 am
A spacer is a viable option, any decent fabricator/engineer could knock them up for not a lot of cash :)
Ruishy1
Postby andymoto on Mon Jun 15, 2009 9:46 pm
Yeah, spacer rings ain't that bad!! I have seen some horrendous cars driving on our roads lol!! but as I said if I were using them i would use steel ones and weld them (tack/stitch) to the shock...
As for me I have given my hub knuckles to Talon Engineering to bore out my shock holes to 45.5mm, I will fit my AVO's tomorrow and take some pics...
Moral of the story? = Buy the right shocks for your car in the first place!! lol
I will add a project thread soon as I have been meaning to do so since I started my cars build, and im pretty much done now lol
andymoto
Postby FiL_FeZ on Wed Jun 17, 2009 6:58 pm
ok all u need to do is change the hubs to match your coilovers, everything else should fit or theres something wrong
FiL_FeZ
