Fiesta V6 Project
Fiesta V6 Project
Postby crispa on Thu Oct 17, 2002 3:41 pm
Just an Idea at the moment!
Has anyone every tried to put the Ford Galaxy 2.8 V6 205hp engine in a fiesta. Its the same engine as in the Golf VR6 but it has all ford bits on it.
I know ppl have thought about the mondeo v6 buts its to big but the vr is a narrow angle! and very short. :wink:
Now Sold My Fezzy 2i 16v 1.8 turbo :( but and now i have a 2.8 Vr6 :)
crispa
Postby moulder on Thu Oct 17, 2002 3:47 pm
I have no idea as to if it would fit etc but if u can put a cossie engine in then a v6 will fit. Just gotta be handy with the welder and be able to make up custom mounts etc. :D
moulder
Postby chumkila on Thu Oct 17, 2002 3:50 pm
hasnt been tried to the best of my knowledge.
Postby crispa on Thu Oct 17, 2002 3:52 pm
ummmm :D getting some ideas
crispa
Postby chumkila on Thu Oct 17, 2002 3:56 pm
kewl :D
Postby Radweld on Thu Oct 17, 2002 3:58 pm
Anything will fit!
Just depends on how handy you are with an angle grinder and a welder.
Radweld
Postby cubby240 on Thu Oct 17, 2002 3:59 pm
IMHO it would be too heavy for a fwd car, mid mounted rwd would be the way to go :wink:
cubby240
Postby Radweld on Thu Oct 17, 2002 3:59 pm
Actually, RWD would be fun! mount it in the rear.....hmmm thats got me thinking.
Radweld
Postby chumkila on Thu Oct 17, 2002 3:59 pm
cubby240 :IMHO it would be too heavy for a fwd car, mid mounted rwd would be the way to go :wink:
so true. i believe a mid-engined V6 Fez would rock!! Perfect balance.
Postby crispa on Thu Oct 17, 2002 4:01 pm
Radweld :Anything will fit!
well not any thing thats if you don't care about have an extra 3 foot of bonnet!! :lol:
crispa
Postby crispa on Thu Oct 17, 2002 4:03 pm
chumkila :
So cut away the boot floor and mount the sub frame in the back like the V6 Clio. Lot of work and cooling would need a bit of thinking but think of the possiblitys VR6 turbo 850hp fiesta mid engine NICE!!!
crispa
Postby chumkila on Thu Oct 17, 2002 4:06 pm
i think we're onto a winner here.
Postby crispa on Thu Oct 17, 2002 4:07 pm
Give sunny's a run for its money! :lol: :lol: :D :devil:
crispa
Postby AdrianFRST on Thu Oct 17, 2002 4:08 pm
Call Ian Howell and ask him if he thinks it's worth doing. ;)
Remember the RWD V6 Fiesta that was for sale last year? That was his.
Baby Battle Scratch
Baby Battle Scratch
Your car: ..? Pretty car..!
Car: 2010 Ford Focus RS
Postby chumkila on Thu Oct 17, 2002 4:08 pm
Postby PhilM on Thu Oct 17, 2002 4:09 pm
The 2.8 Cologne V6 engine is a pile of sh*te, and it's longditidunally deisnged, ie, for RWD Sierras.
The best engine IMO is the Duratec V6. In partiicular the 3.0 V6 from the MondeoST220, 220bhp and 275lb ft of torque normally aspirated! :D
It should go into a fiesta also FWD with just a few welds and grinds :) Not too much effort.
(Unlike the 2.8 V6 which is RWD and the whole chassis/floor pans would have to be altered to suit)
First EECIV 'plug n play' SECS S8
PhilM
Postby chumkila on Thu Oct 17, 2002 4:14 pm
Surely the Galaxy engine is a Zetec not a Cologne?
Postby crispa on Thu Oct 17, 2002 4:17 pm
Philm Not talking about the old sierra engine we were talking about the galxay VR6 engine which is FWD tranversly designed by VW for the VR's and brought by ford and changed abit and its the nutz.
If you want to go nutz out with a ford v6 which are all to big to go up front so you need to go to the rear then you should forget the mondeo engines and go for the Jag 3.0L which is ford/cosworth designed and sand cast designed to run trans!!! very very sweet
crispa
Postby PhilM on Thu Oct 17, 2002 4:35 pm
*Phil didnt read 1st ost propperly*, in that case ;) Sorted, hehe :p
Ford 2.5V6 is also cast by Cosworth for Ford :)
Engine Data
Engine Type 2.5L 24V DOHC Petrol
Displacement (cc) 2498
Bore (mm) 81.7
Stroke (mm) 79.5
Fuel type grade Unleaded petrol, 95 (RON)
Max power (ISO kW/PS) 125 / 170
At engine speed (rpm) 6000
Max torque (ISO Nm) 220
Max BMEP (ISO kPa) 1087
At engine speed (rpm) 4250
Compression ratio 9.78:1
Cylinders 6 in 60-degree V, transversely mounted
Cylinder head Precision sand cast aluminium alloy (Cosworth process) with sintered valve guides and seats
Cylinder block Precision sand cast aluminium alloy (Cosworth process) with dry cast-iron cylinder liners, bedplate and structural oil pan
Crankshaft Forged steel with 50mm-diameter crankpins, 6 counterweights, four 63mm-diameter main bearings and damped front pulley. Separate die-cast aluminium alloy girdle
Valve gear Double lightweight hollow fabricated overhead camshafts (DOHC) with low-friction roller finger followers and stationary hydraulic lash adjusters
Included angle between valves 50 degrees
Valve Sizes (mm) Intake: 32.0
Exhaust: 26.0
Camshaft driveSilent inverted-tooth chain with hydraulic tensioner
Pistons Lightweight, short-skirt, silicon-aluminium alloy
Connecting rods Sinter-forged steel with fracture-split big ends
Not a bad little engine ;) Just needs bigger valves (exhaust especially), but steel crank, steel rods etc as standard, cosworth head block :):):)
PhilM
Postby chumkila on Thu Oct 17, 2002 4:41 pm
Phil am i correct in saying that spec list above is for the ST24 and NOT the ST200 as the ST200 has 30ps more. :wink:
Postby crispa on Thu Oct 17, 2002 4:48 pm
the avantage of the jag version is that all engine extras like alternator, powersteering pump etc.. are all bolted ditrectly to the block rather than have brakets like most cars all so it has variable intake manifolds for extra torque. little bit more development money went in to the jag engine over the st200 but both still top engines :D
crispa
Postby PhilM on Thu Oct 17, 2002 4:51 pm
Chum, indeed, the ST24 one has 170, ST200 has 200bhp. But i'd recommend the 3.0 V6, as per ST220, 220bhp & 275lb ft of torque :eek: :D
PhilM
Postby chumkila on Thu Oct 17, 2002 4:54 pm
let's pull the change out of our pockets and build this Mid-engined V6 Fez. It could be the 1st Fiestaturbo.com car. :D
Postby crispa on Thu Oct 17, 2002 5:06 pm
Like your thinking chum FT.Com mid engine rear wheel drive 3.0L V6 B!TCH :lol:
In a Pop Plus shell with no body kit! A wolf in sheeps clothing LOL
crispa
Postby chumkila on Thu Oct 17, 2002 5:07 pm
AND paint it BROWN! :D
Postby crispa on Thu Oct 17, 2002 5:25 pm
with a really dodgy sun visor, and crappy tinted windows a right wagon!! But watch it go!!! :lol:
crispa
Postby chumkila on Thu Oct 17, 2002 5:27 pm
and have Derek & Sharon on the visor!
Postby Joris on Thu Oct 17, 2002 5:29 pm
"champagne beige" :lol:
crappiest color for a fiesta ever ?
Joris
Postby crispa on Thu Oct 17, 2002 5:31 pm
LMFAO
It would be so cool at santa pods talk about the under dog!!
Need to do it now get thinking peeps
we need a shell, roll cage, st200 v6, gear box, quaff dif, ap brakes, suspension OMG this is getting expensive
crispa
Postby chumkila on Thu Oct 17, 2002 5:47 pm
and sparco bucket seat and harnesses.
Postby crispa on Thu Oct 17, 2002 5:51 pm
omex engine mangement with launch control, traction control and second map for nitrous :D
crispa
Postby chumkila on Thu Oct 17, 2002 5:58 pm
T6 turbo with KKK Supercharger to spin low down until T6 begins to kick in.
Postby crispa on Thu Oct 17, 2002 6:03 pm
it that case we will also be needing 6 mahle forged low comp piston's with a drop forged steel crank, full balancing, ARP bolts all round, solid cam followers with custom profile cams, dry sump set up.
What do u reakon 1500hp non nos
crispa
