fiesta st170 turbo
Re: fiesta st170 turbo
Postby creator on Mon Feb 20, 2012 10:07 pm
Amazing fabrication work as usual gary,really intrested in seeing how the front ends going to look 8)
creator
Postby Excursion on Wed Feb 22, 2012 12:47 pm
Very good job :D
Postby crazycage on Sun Feb 26, 2012 6:22 pm
got two new front wings and a new front panel, front panel is spot welded on the wings are just sitting on at the mo as im waiting on a rivnut tool so i can bolt them on :D
also cut the old cvh engine mount bracket out of the shell ,i dont use it and it was in the way of aulternator that is now mounted on the rear of the engine :)
crazycage
Postby Dave G fsi on Sun Feb 26, 2012 7:20 pm
Good progress mate :Q
Dave G fsi
Your car: Mk1 FRS and FRST
Postby FRSJON on Sun Feb 26, 2012 8:11 pm
great work mate :Q
FRSJON
Postby jonyb4 on Mon Feb 27, 2012 1:56 pm
mind blowing job!
Postby crazycage on Mon Feb 27, 2012 6:37 pm
been meaning to do this for the last two years :o
the standard cam belt tensioners on the blacktop are not very good and the little tab for the self tensioner is the worst part.
i have had one sheer cleen off and an other twist in the last two years :x
so i have made this manual tensioner and its all steel not like the standard plastic item
crazycage
Postby SEG1 on Mon Feb 27, 2012 7:44 pm
nice work mate
looks like theres alot more space in the bay now :Q
SEG1
Postby jonyb4 on Mon Feb 27, 2012 8:19 pm
that will be a good piece of mind, its well known the belt tensioner is the blacktops main downfall
Postby crazycage on Sun Mar 04, 2012 4:30 pm
not much of an update, got my rivnut tool so the front end is all bolted on , used some little m5 button head bolts :D
crazycage
Postby FRSJON on Sun Mar 04, 2012 4:54 pm
crazycage :not much of an update, got my rivnut tool so the front end is all bolted on , used some little m5 button head bolts :D
same way ive done mine :D are you going to paint the bolts ? i used stainless as the black ones rust soo quickly :o
FRSJON
Postby Rhinopower on Sun Mar 04, 2012 5:14 pm
crazycage :been meaning to do this for the last two years :o
How much for another? Would need it by Wednesday tho!
Rhinopower
Your car: Volvo FH330
Postby crazycage on Sun Mar 04, 2012 5:33 pm
rhinopower , im having a batch made ,tensioner and the idler pulley , that one is only a prototype price tbc but should be around the same as the standard ones :)
i have a brand new ford tenioner if that helps you out in a rush
crazycage
Postby crazycage on Sun Mar 04, 2012 5:38 pm
same way ive done mine :D are you going to paint the bolts ? i used stainless as the black ones rust soo quickly :o[/quote]
think i will lacquer them , should look nice with them on red wings :)
crazycage
Postby Rhinopower on Sun Mar 04, 2012 5:41 pm
crazycage :rhinopower , im having a batch made ,tensioner and the idler pulley , that one is only a prototype price tbc but should be around the same as the standard ones :)
Could wait a bit longer, my standard one has rounded off on the Allen key hole so when I take the cambelt off to fit the vvt delete vernier adaptor I probably won't be able to retension it :(
Rhinopower
Postby crazycage on Sun Mar 04, 2012 5:45 pm
Rhinopower :
ahh i see , i may be able to get one for the end of the week :)
crazycage
Postby Rhinopower on Sun Mar 04, 2012 8:12 pm
Cheers. Pm me a price
Rhinopower
Postby crazycage on Tue Mar 06, 2012 10:30 pm
not for my car but ill post the pic's anyway :)
crazycage
Postby FRSJON on Tue Mar 06, 2012 10:47 pm
really like that :)
FRSJON
Postby crazycage on Sat Mar 17, 2012 5:25 pm
FRSJON :really like that :)
would look nice in your bay mate :D
a few pic's of a exhaust manifold that has been keeping me away from working on my own car.
crazycage
Postby Maxwell on Sat Mar 17, 2012 5:33 pm
:o
*away to get tissues*
Maxwell
Your car: FRST - 2wd SAFF COS
Postby FRSJON on Sat Mar 17, 2012 5:58 pm
crazycage :not for my car but ill post the pic's anyway :)
what would one of them cost ?
FRSJON
Postby crazycage on Sat Mar 17, 2012 6:21 pm
FRSJON :
£450 with billet fuel rail and -6 or -8 fittings and all vacuum take off's ect :)
crazycage
Postby FRSJON on Sat Mar 17, 2012 6:26 pm
is a good price..will see :D
FRSJON
Postby Maxwell on Sat Mar 17, 2012 6:27 pm
thats a fantastic price for that inlet!!!
would that suit a zetec turbo?? and what injectors does it suit? pico? bosch? and what is the throttle bodie being used on it?
ideas going about in my head now for my escort haha
Maxwell
Postby crazycage on Sat Mar 17, 2012 9:12 pm
Maxwell :thats a fantastic price for that inlet!!!
that inlet is for a escort zetec turbo , bosch injectors and a cossie throttle body flange tacked on :D
crazycage
Postby SiST on Fri Apr 06, 2012 8:10 pm
Hows the fabrication work getting on? Some great workthere
SiST
Postby crazycage on Sun Apr 08, 2012 12:27 pm
SiST :Hows the fabrication work getting on? Some great workthere
havent done anything on my car for weeks :( been up the wall with inlets and exhaust manifolds for other people :( all finished for now tho so will get stuck back into it next week :) rad and intercooler is next up.
crazycage
Postby crazycage on Sun Apr 22, 2012 1:29 pm
small update , radiator all sorted and mounted to the car :)
also will be building a new intercooler , the one in the pic is one im doing for ricks escort mine will use the same core tho.
crazycage
Postby creator on Sun Apr 22, 2012 3:02 pm
Nice work gary as usual mate :) looks awsome really coming together now mate ;)
How bigs that rad mate?
Pm on its way :D
creator
Postby crazycage on Sun Apr 22, 2012 3:47 pm
creator :Nice work gary as usual mate :) looks awsome really coming together now mate ;)
Pm on its way :D
its on the small side but its the biggest i could fit in the space i want to put it in, but if its a problem i will double stack two cores back to back doubling its capacity :D core is 350x350x50mm so could end up with 305x350x100mm
crazycage
Postby robp-tt on Sun Apr 22, 2012 4:42 pm
its coming along well gary, isnt there any room to have the rad where it normaly goes and move every thing foward more and chop the bumper out?
robp-tt
Postby crazycage on Sun Apr 22, 2012 5:38 pm
robp-tt :its coming along well gary, isnt there any room to have the rad where it normaly goes and move every thing foward more and chop the bumper out?
yes i have loads of room there :lol: but i didnt want to put it there. wanted to do somthing differernt from the norm.
plus moving it over will help with water temps and also act's as the rad wont be heating the intercooler and the intercooler wont be obstructing the rad plus it will counter balance having the oil tank for the dry sump in the other front corner :)
crazycage
Postby Excursion on Sun Apr 22, 2012 7:10 pm
crazycage :
I think that'll be way too small mate. In terms of doubling up, the max efficiency is within the first 30mm and beyond that it falls off rapidly as the air looses speed and is heated by the fins. Can you get the same rad on the opposite side?
Postby FRSJON on Sun Apr 22, 2012 7:22 pm
looking good and different :Q and i didnt mean to freak you out when i saw you at the pod :lol:
FRSJON
