Fiesta mk2 - ready for ford fair !
Re: Fiesta mk2 1.1
MK2 Jamie :My Ghia came with the rear speakers mounts. Theres a pic in my thread on how I did the speakers. I think, like mentioned above, only high end fiestas came with them. My mates 1.1L didnt have them.
Knuckles have you done the ARB yet? if not bolt it to the bottom of the car first then bolt it to the beam/bottom of the shock. Its so many easier doing it that way round as I found out yesterday.
no havent done the arb yet , went to B&Q today to buy the really long bolts which go through the shock at bottom.
so fit the arb to the shocks first at bottom then attach them onto the brackets ?
- knuckles
- Your car: Fiesta Rs turbo
Re: Fiesta mk2 1.1
Other way round haha put it in the brackets first then onto the bottom of the shocks.
- MK2 Jamie
Re: Fiesta mk2 1.1
MK2 Jamie :Other way round haha put it in the brackets first then onto the bottom of the shocks.
how easy do the brackets mount to the car ? i see one bolt on the outter of bracket
my 1.1 doesnt have a arb as std so im wondering if i need to drill any holes etc ?
- knuckles
Re: Fiesta mk2 1.1
wow, seems more mk2's come with rear speakers than mk3's, few mk3s come with them, ghias, RS/XR and some few Si
even worse in the mk4, only ghias and a few other added extra models had them
scarey
scarey
- rs-tom
- knuckles
Re: Fiesta mk2 1.1
If im thinking of the same cup then there is on one side bolt then there should be a little lip on other side of the cup the slides into a little slot or are you talking about the bit that the cup fixes too?
- MK2 Jamie
Re: Fiesta mk2 1.1
MK2 Jamie :If im thinking of the same cup then there is on one side bolt then there should be a little lip on other side of the cup the slides into a little slot or are you talking about the bit that the cup fixes too?
i think im going to have to just offer up the mount to the rear to see how it works
just looks weird off the car
- knuckles
- rs-tom
Re: Fiesta mk2 1.1
i know thats why im having a very trusted welder to modify it to fit the zetec
- knuckles
Re: Fiesta mk2 1.1
knuckles :i know thats why im having a very trusted welder to modify it to fit the zetec
you better start talking to this welder with respect other wish he might tell you to jog on
cheese and pineapple
Re: Fiesta mk2 1.1
jayrs :knuckles :i know thats why im having a very trusted welder to modify it to fit the zetec
you better start talking to this welder with respect other wish he might tell you to jog on![]()
bloody turd burgerler get on with it !
i ordered it over a month ago , getting beyond a joke now
- knuckles
Re: Fiesta mk2 1.1
ordered what fudge packer.....???
wheres the mount then? wheres the postage, wheres the money, wheres wolley!!!!!!
Re: Fiesta mk2 1.1
''i will mod my one and send it to ya then when you come over swap it for that one''
ring a bell !
ring a bell !
- knuckles
Re: Fiesta mk2 1.1
knuckles :''i will mod my one and send it to ya then when you come over swap it for that one''
ring a bell !
it does.., but...
have you made a start on the conversion....... have you told me when you need it by............
Re: Fiesta mk2 1.1
Since it was a dry day today and i have no more rs to work on
I got round to fitting the Rear anti-roll bar
Started by getting the arse off the ground and offered up the brackets and bolted them up.
Once the brackets were on i basically unhooked the p clips then put anti roll bar up then removed the shock bottom bolts.
offered up the bar bolted to bracket then bolted to the shock with the drop links.
This pic shows anti roll bar fitted to the bottom of the shock, Longer bottom bolts was required with new lock nuts.
Clearance from back of brake drum from the nut/bolt.
Cant wait to see if it makes much of a differance tomorrow.
- knuckles
Re: Fiesta mk2 1.1
you mean your more worried about losing your parking space to some monkey than test drive it and deliver us a proper report
lame
lame
Re: Fiesta mk2 1.1
jayrs :you mean your more worried about losing your parking space to some monkey than test drive it and deliver us a proper report
lame![]()
that may be one of the reasons yes. on the other hand it was getting late and i was very hungry
- knuckles
Re: Fiesta mk2 1.1
knuckles :jayrs :you mean your more worried about losing your parking space to some monkey than test drive it and deliver us a proper report
lame![]()
that may be one of the reasons yes. on the other hand it was getting late and i was very hungry![]()
steak and a pint? or cheese and pineapple
Re: Fiesta mk2 1.1
i can report back the rear anti roll bar makes a massive difference to the mk2 rounds bends.
rear strut brace will make an appearance soon too !
engine may see daylight soon if i ever get an engine mount
- knuckles
Re: Fiesta mk2 1.1
knuckles :engine may see daylight soon if i ever get an engine mount![]()
jump on a ferry and come help me sort this workshop, then i'll have time to fcuk about on the mount
got somewhere to do the engine change yet btw
Re: Fiesta mk2 1.1
jayrs :knuckles :engine may see daylight soon if i ever get an engine mount![]()
not yet fella, still got quite a few pieces to source before we start stripping it.
- knuckles
Re: Fiesta mk2 1.1
knuckles :jayrs :knuckles :engine may see daylight soon if i ever get an engine mount![]()
and you give me sh it about thew mount
price just went up
Re: Fiesta mk2 1.1
jayrs :knuckles :jayrs :not yet fella, still got quite a few pieces to source before we start stripping it.
price just went up
can you use the same gearbox in the mk2's then once its got a zetec?
i know with the mk1s its gotta be changed or you need to cut into the chassis leg and stuff
Re: Fiesta mk2 1.1
With a mk2 you can use the original 4sp box or a 5sp box without any cutting. Just drops straight in.
- MK2 Jamie
Re: Fiesta mk2 1.1
ah thats handy, are the 5 speeds hard to come by or are they quite common?
Re: Fiesta mk2 1.1
5 speed models were normally the xr2 models
most of the 1.1 car engine mk2's ive seen are 4 speed.
- knuckles
Re: Fiesta mk2 1.1
All MK2's were 4sp unless it was an XR2 or a 1.3/1.4 CVH which were all 5sp but they're pretty rare.
- MK2 Jamie
Re: Fiesta mk2 1.1
oh, i understood that the 1.3 cvh was only aviable in europe
would a mk3 5 speed box fit the mk2?
i know the gearbox cradles and mounts are the same, and yet again both had cvh and hcs engines
Re: Fiesta mk2 1.1
no the 1.3 was here too.
mk3 boxes will fit fine
Re: Fiesta mk2 1.1
oh, so i presume the mk3 box is a popular conversion then?
ill keep this in mind when i have a mk2
Re: Fiesta mk2 1.1
5 speed is, ans iirc, the mk3 linkage will fit the later mk2
early mk2's, like my xr2, had the early linkage, simular to what was fitted to the early mk3 escort, and what i love about my early linkage is, the fact you have to push the gearstick down then pull back to get it in reverse
Re: Fiesta mk2 1.1
So what red did the later mk2 come in?
Does the earlier linkage still fit the mk3 box then? Or do you just fit a later linkage
Re: Fiesta mk2 1.1
On the topic of gear boxes my first mk2 fiesta was 5 speed from the factory, it was a "fresco" model 1.1.
Im not so sure the mk3 linkage fits though? I never tried it but ive also never heard of it either?
with my 2.0 zetec im using a fiesta si gearbox but dont really recommend it as the ratios are pathetic! 5th gear is far to short, as are all of them really. Its good for initial acceleration but thats about it, depends what you want it for i guess.
Gareth.
Gareth.
- black2
- Ratspeed
