Fiesta mk2 - ready for ford fair !
Re: Fiesta mk2 1.1
Postby black2 on Tue Jun 01, 2010 8:39 pm
Exactly what jay said.
Gareth.
black2
Re: Fiesta mk2 1.1
Postby MK2 Jamie on Fri Jun 04, 2010 7:39 pm
Will keep an eye on this thread. Im starting to get the bits together to zetec mine. Where did you get the fuel tank from?
MK2 Jamie
Your car: 1988 Ford Fiesta Ghia
Re: Fiesta mk2 1.1
Postby jonyb4 on Sat Jun 05, 2010 12:33 am
black2 :
knuckles :
fiend :Why are you keeping the cat?
i bought the engine complete with all the hoses , rad, cat, hego , fuel filter etc.
i thought the engine had to run a hego to run correctly ?
the hego i got is in the cat convertor :-?
No cat and no egr are required It will run just fine - one thing which is very important to use is the lamda sensor in the exhaust though ive got a 4 branch manifold on mine and the lamda screws into that, im not sure where it goes on the standard mondeo system though?
Gareth.
what manifold is it? they still for sale new and how much? :D
im eagerly after a four branch, appearently they let the engine rev much more freely, without it screaming at you for mercy :lol:
jayrs :on the mondeo its on the down pipe.
lambda sensor shouls have a square fitting, like the sort used for the front spot lamps on the rs
4 wires, 2 white, 1 grey 1 black
ill second that, was trying to remove the lambda off a mondeo the otherdsay in a yard, bloody thing was seized in
Re: Fiesta mk2 1.1
Postby jayrs on Sat Jun 05, 2010 10:09 am
yeah that aint easy sometimes.
i always do my pikey bit at the scrappy, if i see a good one that looks newesh, ill have it :lol: , ive had to leave a couple before as they were fcuking tight :(
Re: Fiesta mk2 1.1
Postby black2 on Sat Jun 05, 2010 1:38 pm
Jony - Im not sure tbh chap - When i done my conversion i bought a 16v mk3.5 si as a donar car as i needed the usual bits off of it but it also had some nice extras on it like the 4 branch. I hav'nt a clue what the manufacture is, its not stainless & i cant comment on any performance increase because my zetec has never been run with the oe cast manifold - i cant imagine theres a huge difference in performance though?
Gareth.
black2
Re: Fiesta mk2 1.1
Postby knuckles on Sun Jun 06, 2010 10:27 pm
1800 Jamie :Will keep an eye on this thread. Im starting to get the bits together to zetec mine. Where did you get the fuel tank from?
ebay - there is a seller on ebay doing them for a pretty good price.
ive bought a cosworth external fuel pump off ebay for £54
ive got 4 meters of 8mm fuel pipe which is going to be used as the feed pipe under the car. As the 1.1 carb 6mm feed is not good enough for a EFi.
Now ive finished the Other Rs i will be beginning to strip out the 1.1 very soon
xr2 shocks are being sourced soon with a 35mm lowering spring kit.
Fiesta St front brake setup with 15inch steel wheels :wink:
knuckles
Your car: Fiesta Rs turbo
Re: Fiesta mk2 1.1
Postby hb69 on Sun Jun 06, 2010 10:30 pm
Plans sound good :aviator: Makes me want a mk1/2 again
hb69
Your car: Fiesta 1.1 LX
Re: Fiesta mk2 1.1
Postby jonyb4 on Thu Jun 10, 2010 12:37 am
woop should see some progress on it soon then clark :Q
Re: Fiesta mk2 1.1
Postby knuckles on Sun Aug 22, 2010 8:25 pm
not much of an update but i have been cleaning :D :lol:
i got some rear turret insulators and c pillar trims from a guy on xrtwo forum.
bit of a nightmare fitting them parts...
rear seat out , rear door cards out, rear shelf supports out rear seat belts off & then boot struts off to fit two pieces of insulation and 2 plastic covers :lol: :rolleyes:
Repaired the wiring to the rear wiper and heated screen
unblocked the rear washerjet
took out rad - flushed through old crap then flushed system and refilled with fresh antifreeze & h20
new wipers
got the Pi lowering springs from ebay 40mm drop
and genuine front and rear xr2 shock absorbers have been ordered. :D
knuckles
Re: Fiesta mk2 1.1
Postby Ratspeed on Sun Aug 22, 2010 8:36 pm
Looks sweet, but what is on the tailpipe? i canrt make it out :-?
Ratspeed
Re: Fiesta mk2 1.1
Postby jayrs on Sun Aug 22, 2010 8:45 pm
:lol: :lol: :lol: :lol: :lol:
looking good mate.
gotta say the car is better than i expected, looked very nice last week when you were over :Q
Re: Fiesta mk2 1.1
Postby knuckles on Sun Aug 22, 2010 9:00 pm
cheers jay :)
those wheels have got to be changed soon, its bloody scary going round sharp bends over 40mph !
needs lowering and wider wheels asap :lol:
knuckles
Re: Fiesta mk2 1.1
Postby jayrs on Sun Aug 22, 2010 9:06 pm
Ratspeed :Looks sweet, but what is on the tailpipe? i canrt make it out :-?
looks how shall we say, like a w@nk dish dont it
Re: Fiesta mk2 1.1
Postby Ratspeed on Sun Aug 22, 2010 9:08 pm
jayrs :
looks how shall we say, like a w@nk dish dont it :lol:
Seriously, what is it though? :lol:
Ratspeed
Re: Fiesta mk2 1.1
Postby knuckles on Sun Aug 22, 2010 9:15 pm
jays got some mints that would go well in that dish
knuckles
Re: Fiesta mk2 1.1
Postby jayrs on Sun Aug 22, 2010 9:28 pm
you know what, i bloody do mate!
Re: Fiesta mk2 1.1
Postby knuckles on Sun Aug 29, 2010 12:10 am
today i bring a big update
bit of a stressful encounter fitting bigger wheels. Every car i fit bigger wheels to always has rubbing issues.
This mk2 was no different
Got hold of some mk1 mondeo 15 inch steels for £50 off a nice chap on xrtwo.com, then today had 4 fresh p6000 tyres fitted as the mondeo tyres were too big and bald.
This is how its started out on 13's :lol:
Not my cup of tea & very scary around bends. Plenty of roll to say the least :oooh:
Comparing the two...
I went for 195/50/15 because i still want some ride comfort and 45 profiles in my past experiance are a harsher ride. Also
i want the car still to look standard with normal looking tyres.
The end result.
I had to space the front wheels out with 5mm spacers to clear the side wall of the tyres off the shock strut. Their is
slight rubbing on front inner wing on full lock but im going to find a steering rack limiter to cure that issue :)
The rears is where the trouble was.
the rear trailing arms which connect from the chasis to the rear beam were touching the inner side wall of tyre. It took 10mm spacers on rear to give it a 5mm gap between tyre and trailing arm.
I didnt require longer bolts as i had over 9 whole turns before it got tight
the mondeo wheels are 6J offset and i think they might be et40 from the problems ive encountered.
Other than that
on the plus side - car handles 100% better. Elliminated excessive body roll caused by the other wheels.
cant wait to fit the fiesta St front brake setup ive got sitting around and the xr2 shocks and springs and brake servo/master cylinder.
comments welcome
Clark :)
knuckles
Re: Fiesta mk2 1.1
Postby jayrs on Sun Aug 29, 2010 12:14 am
dont look too bad mate, as we talked about on the phone, there be ok.
need lowering, get them springs on, looks like a monster truck :lol: :lol:
Re: Fiesta mk2 1.1
Postby jimmyesh on Sun Aug 29, 2010 3:46 pm
Looks really good for its age :Q Looking evil on the Mondy 15's :)
jimmyesh
Your car: Yes
Re: Fiesta mk2 1.1
Postby Ratspeed on Sun Aug 29, 2010 4:53 pm
Drop it on its balls! :Q
Ratspeed
Re: Fiesta mk2 1.1
Postby rst-steve on Mon Aug 30, 2010 4:44 pm
When its lowered, thats gonna look superb...... the mondeo steel wheels are a nice touch :)
rst-steve
Your car: 1990 Fiesta RS Turbo
Re: Fiesta mk2 1.1
Postby black2 on Mon Aug 30, 2010 9:22 pm
That does look good but i see troubles ahead when you lower it now.
50's will rub badly i think.
Ive got 45's on my mk2 and even they rub a little im afraid. Also im not sure if your aware but when you lower the rear of a mk2, because of the panhard rod which connects the two side of the rear axel the drivers side rear wheel is brought in closer to the inside of the car, how much is dependant on the amount of lowering but it will exasperate the problem of the inside of the tyre touching the inside arch. You can get adjustable rods off xrtwo.com and you then adjust it to suit. It may not come to that but i know mine could do with the adjustable rod because ive had to currently fit 5mm spacers to my rear wheels purely because the drivers side wheel was rubbing as mentioned above.
also just a question re the st brakes. Do the calipers bolt stright on? or is there some jiggery pokery required?
Gareth.
black2
Re: Fiesta mk2 1.1
Postby knuckles on Mon Aug 30, 2010 10:59 pm
black2 :That does look good but i see troubles ahead when you lower it now.
Gareth.
ive tried to fit the st150 brakes today and ive come accross one problem.
the disc fits perfectly on the hub, then the carrier wont line up with the hub mountings as it rests on the outter edge of the disc. When you remove the disc the carrier mounts perfectly onto the hub with no modification.
The solution to fit these is to simply file down the inner carrier where the disc runs through it. Ive managed today to file 2mm of the carrier to clear the disc and allow it to be bolted upto the hub. i was told not to drill out the hole on the hub to suit as it would be very dangerous if the bolt should come loose and moved .
will get pictures of this tomorrow when i do the other side carrier.
Regarding the 50 profile tyres i have slight rubbing on the rear inner arch when going over harsh bumps or pot holes.
i think lowering will cause more agro so will just settle for its current state.
knuckles
Re: Fiesta mk2 1.1
Postby knuckles on Mon Aug 30, 2010 11:08 pm
passenger sider inner arch clearance
drivers side rear inner arch clearance :o
These are the old brakes soon to be binned. :)
knuckles
Re: Fiesta mk2 1.1
Postby jayrs on Mon Aug 30, 2010 11:10 pm
after you got them springs too :oooh: , mate, ill make up some adjustabel rods once ive finished sorting the workshop and got the cars back in place, then you can lower it down.
dont leave it so high you need a fcuking step ladder to get in it, jesus.
and re the phone calls, build a bench, get a vice and get some decent files :lol:
Re: Fiesta mk2 1.1
Postby knuckles on Mon Aug 30, 2010 11:23 pm
jayrs :after you got them springs too :oooh: , mate, ill make up some adjustabel rods once ive finished sorting the workshop and got the cars back in place, then you can lower it down.
fair comment regarding vice and file but i borrowed a bench from a neighbour so money saved :P
im thinking of spacing out the rears 5mm more to give the inner arch a tad more clearance.
ive got the longer wheel bolts so will experiment :)
knuckles
Re: Fiesta mk2 1.1
Postby jayrs on Mon Aug 30, 2010 11:45 pm
tight c**t, get a bench and vice and dont give me that crap about money saved and all that :lol: :lol:
Re: Fiesta mk2 1.1
Postby black2 on Tue Aug 31, 2010 2:04 pm
Thats interesting, so the actual caliper its self bolts on fine, and the bolt holes are the same dia. as the stnd mk2 ones. I wonder if you can use the mk5 rs2000 discs with these calipers? As looking on xrtwo.com the most common brake upgrade is to use 4x4 cossie calipers with rs2k discs which incodently i tried fitting on the weekend but ive been diddeled as i bought some calipers on the understanding they were the correct ones which in fact they arnt which is great! :rolleyes:
Gareth.
black2
Re: Fiesta mk2 1.1
Postby knuckles on Tue Aug 31, 2010 10:01 pm
st 150 brakes are the best option i think.
cosworth calipers i remember needed spacing away from hub to stop disc rubbing on inner edge.
its a bit of a pain to file but worth it to run the larger discs :D
they fit perfectly without any spacers/washers.
still waiting to get pics but will do this when i fit them :wink:
knuckles
Re: Fiesta mk2 1.1
Postby Ghost on Wed Sep 01, 2010 2:36 pm
knuckles :cant wait to fit the fiesta St front brake setup ive got sitting around
What do you mean that you have sitting around?!... :P
and stop ruining my carriers! :lol: :lol:
Ghost
Re: Fiesta mk2 1.1
Postby knuckles on Wed Sep 01, 2010 9:49 pm
Ghost :
blimey you still alive then ? :lol:
knuckles
Re: Fiesta mk2 1.1
Postby knuckles on Wed Sep 01, 2010 9:56 pm
something interesting i found which is STILL availible from fords :wink:
Rs accessory steering rack limiter.
kit consists of 4 couplings
2x circlips
4 x snap rings
2x boot clamps
fitting instructions.
simply attaches on to the track rod where it screws onto the shaft of the rack. Preventing the shaft going all the way in.
Eliminating the wheels rubbing on the inner front arches :aviator:
This was one exspensive bit of kit but worth it in the long run to stop ruining tyres and arches :)
knuckles
Re: Fiesta mk2 1.1
Postby Ratspeed on Wed Sep 01, 2010 10:19 pm
I never knew these even existed!! :Q
Ratspeed
Re: Fiesta mk2 1.1
Postby jayrs on Wed Sep 01, 2010 10:37 pm
nor did clark did i told him other day on phone :bonkers:
send them to me mate, i'll messure them up then send them back to ya and ill make some up :wink:
Re: Fiesta mk2 1.1
Postby EUFez on Thu Sep 02, 2010 1:17 am
Awesome :Q
EUFez
