Fiesta mk2 - ready for ford fair !
Re: Fiesta mk2 2.0 zetec coming soon !
nice touch, i dont even know of mk3s having that
i may copy you on that
which mk5s had it? hopefully not just the ghia
I like that, Ive always wanted a light of some sort in there, was going to DIY one at one point, but thats pretty smart, might have to copy it too. Top stuff
- - Danny Boy -
- Your car: Fiesta Si 2.0
on sunday the stripping begins to make way for the 2.0 zetec.
Will bring a tear to my eye doing this to such a original ford
plenty of pics will follow
- knuckles
- Your car: Fiesta Rs turbo
ford overalls on clark???
- RS rob
RS rob :ford overalls on clark???
without fail
- knuckles
knuckles :Will bring a tear to my eye doing this to such a original ford
agreed, you can be such a cnut dave
- GavStyli
- Your car: Fiesta Turbo
knuckles :RS rob :ford overalls on clark???
without fail
oo scary times, glad your going to get it started, been wondering when it was going to happen
i guess i better do that mount seeing as i dug it out
- GavStyli
trying to convince dave to put nos on it too, his answer pissed me off so....
- GavStyli
- MK2 Jamie
- jonboisescort
Car: 1994 Ford Fiesta
- Ratspeed
- knuckles
- Tweek
- Your car: VW Golf GTD
It was the end of the Hcs today. It will be missed. Hasnt let me down once this last year. Very reliable plucky engine.
and with only 44,350 under its belt it dont deserve to be scrapped.
before i started this morning.
minus one Hcs engine
Wiring !
End of the day
cant wait to get the zetec bolted in.
What a epic journey this will be building this 2.0
Wiring !
End of the day
- knuckles
- Ratspeed
about f ucking time
jayrs :about f ucking time
get that mount welded up and send over that servo
chop chop
- knuckles
YAWNNNNNNNNNNN yeah i get round to it somewhen
Re: Fiesta mk2 - goodbye Hcs
good stuff, the zetec will fit the bay nicely
- Smo
Smo :What you doing with the old engine?
not sure yet
any ideas
- knuckles
knuckles :Smo :What you doing with the old engine?
not sure yet
any ideas
ill fit it in my fiesta when i blow it up again and it will stay standard and do 50mpg!
- GavStyli
when that time comes i want £150 for the engine and 4 speed gearbox setup
cos you will certainly blow a hole in your gearbox too
- knuckles
knuckles :when that time comes i want £150 for the engine and 4 speed gearbox setup
if youve totally jinxed me now, angle grinder will defo be used in your next haircut
- GavStyli
proberly be more safer than them cunting sizzors that pull your hair out instead of cutting it !
- knuckles
Such a clean Mk2 and it should go well with a 2.0. Have you got an HO inlet?
Excursion :Such a clean Mk2 and it should go well with a 2.0. Have you got an HO inlet?
im not sure mark tbh, i bought the complete engine , loom etc off cellze
see link for a flash back of what car it came from
1-0-to-2-0-project-update-at-last-vt127232/?hilit=polo
arranged a van to collect the lump this weekend to bring it from my lockup to the car
- knuckles
knuckles :im not sure mark tbh, i bought the complete engine , loom etc off cellze
Ahh, nice engine. Yes, you have.
Re: Fiesta mk2 - 2.0 Its in !
The update we have all been waiting for !
A big thank you to Rhinopower for helping me 1st thing this morning to move the engine from my garage to the car.
Modified Cvh mount for zetec 2.0 - Jay modded this and express delivered it to me friday morning. Technician at work used air grinder to remove all surface rust and i cleaned it , primed and painted gloss black
Compairing the Zetec mk3 mount to the Cvh mount on left
One clean fiesta diesel 1.8 gearbox bolted upto the mk2 fiesta craddle
This was caked in stubbon grease that was 2mm thick all inside. Gunk sprayed and scrubbed then hosed off
Old style reverse switch fitted to match the loom & clutch arm changed from diesel version to the mk2 version.
For some reason my oil pump was different to jays 2.0.
The oil pump was in the way for the bottom of the cvh mount. The bottom hole is not being used as it dont line up with the mount so this needed chopping off.
Gav kindly did the chopping as im affraid of angle grinders !
All fitted back on
Fitting the lump was tricky , involved lifting the car up with 2 trolley jacks and axel stands. Then sliding the engine and gearbox underneath. Lower car back down and then lift it all up into place.
Fitted - Plenty of swearing and jiggling was needed. It was very tight near the brake servo and brake lines near the coil pack bracket. The Inlet manifold needed to be removed to clear the bulk head and to gain access to the mount to guide it into the inner wing. Once the drivers mount was located and bolted on. The rest was easy to line up with a trolley jack.
Both front tie rod bars had to be removed to fit the Lump.
Clearance from the inner wing to the crank pulley and alternator & belt (half inch tops)
Back on the deck !
Very happy it all fits. At one point i thought it wasnt gonna fit as the alt pulley was hitting inner wing. The bonnet just closes with it all in place and doesnt hit the inlet manifold.
Comments welcome
All fitted back on
Back on the deck !
Comments welcome
- knuckles
Re: Fiesta mk2 - 2.0 Zetec Its In !
Good work clark. looks like it left the factory that way. Whan do you plan on getting it running
- rs220bhp
awesome work
clarks finally gone zetec!
how longs it been?
looks snug in there
how longs it been?
looks snug in there
nice to see it in mate.
i will add, the bit i put on the mount is welded on the front as shown as well as on the back in case anyone was wondering.
i did consider cutting the bottom bit off that mount as ive seen it done many times before, but it cleared everything on my engine when i made the template for the extra bit up so left it on assuming you would have the same pump, tbh, i didnt know there were 2 different pumps on the silver top
i got plenty clearance on my lump as the pic shows
just looked at the pic of a 1.6 zetec engine i got for the bits (sump etc) and it has the same oil pump as you, so maybe the 1.6 and 1.8's has a shorter pump than the 2 litre
