Extensive cossie brake fitting guide (large download) pics
106 posts • Page 3 of 4 • 1, 2, 3, 4
turboben1 :i am using 4x4 discs and escort cossie calipers but the threaded holes in the carrier that bolt to the hub are bigger than the standard bolt. do i just drill out the hole or do i use a different carrier
anyone got an answer to this please please please
- turboben1
- turboben1
Will these breaks fit on a fiesta mk3.5 si, and under 15" volcano rims?
( the ones on the back of deemon tweeks cataloug).
- lucasdemoley
my calipers run on the rim, i have to use 5mm spacers!!
anyone else ahving this?
got escort 15" rims
got escort 15" rims
1995 Fiesta SI 3 door, green something, 2L + diesel gearbox in(130mph @ 5,000rpm
), focus inlet in, + k&n, passed mot without a cat
< FIESTA FOR SALE! GOT A BMW 528I SE MANUAL NOW
http://www.finalgear.com
- VUK
Yeh, depends what alloys you have. Just misses mine. I will say use threadlock, as one of the bolts droped out of mine, and i overtighten everything!
- lucasdemoley
its a pain cos now the tyre rubs on the wheel arch!
might grind down the caliper
- VUK
Yeh, ive heard people having to grind it down abit before. Just dont take off too much!
- lucasdemoley
lucasdemoley :Yeh, ive heard people having to grind it down abit before. Just dont take off too much!
well 5mm lol
i got tarox discs and red stuff pads, stops like nothing i'v ever driven, your organs shift fowards lol
- VUK
weegee :can anyone confirm that mondeo 4x4 calipers fit? hoping to do this at the weekend.
thanks
I'm gonna have a go on the Puma this weekend.
Have a look here....
http://www.pumapeople.com/index.php?showtopic=65163
and here....
http://www.zsoc.com/portal/showthread.p ... ight=brake
and here...
http://www.zsoc.com/portal/showthread.p ... ke+upgrade
HTH
- D.J
I have a mondeo v6 ive bought, and the caliper wont bolt on due to the bolds being m14 instead of m10 am i just doing something wrong or if i drill them out will they be ok? These are off the mk2 mondeo? Please help!! thanks scott
- clarks.2007
Re: Extensive cossie brake fitting guide (large download) pics
Which bit are you wanting to drill, the carrier? I'd have thought aslong as your only taking a tiny bit way so that the bolt can pass through and that there is still plenty of metal left then it should be ok.
Just because i feel like it, and ive just found the pic, this is how close mine run on some i think tsw alloys i have,
[IMG]http://img.photobucket.com/albums/v635/lucasdemoley/My%20car/DSC00130.jpg[/IMG]
- lucasdemoley
hi ive just bought a set of 2wd 4 pot cossie calipers hoping to put them on my mk 3 xr2i woth 300 mm discs am running 16" wheels so clearance not an issue but after readin all this am gettin worried as to wether they wil fit or not?? any help would be aprecieated! cheers .nath
- nathwright86
reading it through i think it says that only the 4x4 sierra cossie setup fits mate not the 2wd
- fray
As above, only 4x4 sierra cossie brakes fit, not 2wd.
- Tweek
- Your car: VW Golf GTD
I really want to do this upgrade (because i like to stop when i want, not when my fez feels like it) the disc that i have at the moment are just solid not ABS, does this mean that it wont work on mine?
Thanks Jack
Thanks Jack
- fiesta crazy
no it should work fine. ive discoverd that you do have to use 4x4 calipers of either escort or sierra as 4 2wd 4 pot brakes although better have 2 sets of brake lines going in and the fiesta only has one you can bridge these to make it work but it will not pass an mot so you would have to put ur old calipers and discs back on for the mot once a a year (really such a hardship?) but the most simple method is to use 4x4 calipers and 289/300mm discs agian 4x4 (note you will need to be running at least 16" rims to clear the discs) i would also advise to get a set of decent braided lines n put them on while your at it heres a number of great place i use they make up brake lines to order and can sort you out for not a lot of dosh RSM MOTORSPORT LTD 01524 844066 OR EMAIL SALES@RSMMOTORSPORT.CO.UK http://WWW.RSMMOTORSPORT.CO.UK hope this helps and if you after a set of cossie calipers ive got a set front and back for sale £100 deliverd gis a an email pine.designs@hotmail.co.uk
- nathwright86
4x4 cossie discs are 280mm. Really is a straight forward conversion =)
- Tweek
for sale 130 bhp fiesta xr2i moondust silver mint condition lowerd big brake conversion lots of extras call or email nath on pine.designs@hotmail.co.uk/07894137721
- nathwright86
Hi all. Just been speed reading this topic and there seems to be a lot of confusion with disc /caliper combinations.
all the answers are in the very first post,
but with regard to the mention of Mk2 Mondeo 24 V6 calipers, forget them as they use a 278 mm disc but smaller pads (due to a caliper, carrier set-up and a Ford cost cutting exersise) than a 4x4 Cosworth.
If you are shopping for calipers for this conversion though you are going to find that the 4x4 Sapphire Cosworth and Escort Cosworth will come at a premium price.
But, all MK 1 24 V6 MONDEO'S and 24V COSWORTH GRANADA/SCORPIO have the calipers you require, as they are the same parts as fitted to 4x4 Cosworth's, and are cheap as chips.
If you want to be realy flash though, go to your local Aston Martin dealer though and get a set of calipers for an early DB7, as they use the same one's too.
Mk 1 24V V6 MONDEO pad's are also available without wear indicators too, so are cheaper as a result.
- Cosmo
Any Chance Of A Guide On Bleeding The Brakes?
- rowley63
just got me some cossy 4x4 calipers, escort cos front pads and disc will do this in a few weekends time :)
to bleed the brakes what you wannado is:
you need a bottle with a long rubber tube to fit over the brakes nipples to catch all brake fluid being pumped out... and correct spanners to undo nipples.
this is a two man job with out any pressure systems used....
get a buddy to sit in the car front wheels are of the ground with wheels off...
make sure master cylinder bottle is full of brake fluid.
starting from the furthest nipple on the rear axle first then work forwards towards the front to get all air out.
right get your buddy to pump footbrake four times then hold it down.
crack of nipple til fluid as been released.
retighten nipple
get him to pump it again and holdit down
crack nipple again
re tighten
keep doing this til all air bubbles can't be seen in the tube going into the catch bottle.
do this with each nipple at each corner... after doing each nipple check and top up master cylinder bottle
after doing last nipple up after all air is out check pedal should be hard start car up check if it is spongy or goes to the floor.
if it does then re do the above again with engine running the servo may help the rest of the air out.
once pedal is all good with engine running road test :)
just a crude quick guide
retighten nipple
crack nipple again
re tighten
- Pastieman
- Your car: Mk3 Fiesta Rs Turbo
right just been looking at my cozzy calipers now the carries don't have m10 bolt fittings looks like m12 to me....
so do you use the frst carrier with the cozzy caliper
or do you just use the cozzy carrier and calipers and inlarge the hole in the hub for the bolt to pass though
many people have asked this question and it hasn't been answered and also its not clear in the guide?
or i will just have to find out when i come to do it ( as i'm lazy someone just answer this for me please, can't be arsed to fook about, i gotta fook about with other things on the RS )
- Pastieman
just double checked my calipers and carriers they are the same as in the pics so i do have the right ones.... but the m10 bolts i have are too small to fit the carrier...
the guy i bought the calipers off gave me the original carrier bolts m12's which where on the sierra cos 4x4
haven't put these up to the hub as of yet will do this next weekend, will let you all know how i get on
don't think these bolts will go through the hub, ( not even checked yet ) might just have to open hub locating hole up a bit to fit m12 bolts in to bolt up carrier to hub :)
- Pastieman
I thought the Sierra Cossie brakes were different to the Escort? Escort ones use the same bolts as the FRST although you need slightly longer ones
- Tweek
[quote="Tweek"]I thought the Sierra Cossie brakes were different to the Escort? Escort ones use the same bolts as the FRST although you need slightly longer ones[/quote]
this is what i'm thinking mate as i don't have a set of escort cosworth calipers to check... but other than that i'm sure they are the same
- Pastieman
yep sierra calipers need the frst hub holes opened up slighty to fit bolts through bit of piss then just do the same as above :) space out the pad carriers 5mm and bobs your uncle
- Pastieman
Yer, i done mine yesterday with the cossie 4x4 calipers and discs. I used the larger bolts with the cossie carrier plates. I used a 10mm drill bit (The biggest i had) and just wiggled it around the holes on the hub to enlarge them, until the large bolts fitted through them. I used 2 penny spacers on each bolt between the hub and the carrier plate to give me the correct offset. Also running 3mm wheel spacers on 16" mondeo 5 spokes, just to give some clearnce of the caliper, which worked out ok cause the wheels were very close to the suspension strut anyway.
- 95 Fiesta SI
[quote="95 Fiesta SI"]Yer, i done mine yesterday with the cossie 4x4 calipers and discs. I used the larger bolts with the cossie carrier plates. I used a 10mm drill bit (The biggest i had) and just wiggled it around the holes on the hub to enlarge them, until the large bolts fitted through them. I used 2 penny spacers on each bolt between the hub and the carrier plate to give me the correct offset. Also running 3mm wheel spacers on 16" mondeo 5 spokes, just to give some clearnce of the caliper, which worked out ok cause the wheels were very close to the suspension strut anyway.[/quote]
Had any problems with the 16's ?I'm just buying a pair of cossie calipers and looking to do the conversion myself this week.
I don't have any spacers on my car :D
Regards!
Regards!
- gcodin
[quote="gcodin"]
Regards![/quote]
Depends on the design of the wheel mate. Mine are 16" Mondeo 5 spoke ones and they only just clear the calipers. If you find your wheels catch the calipers get some 3mm wheel spacers for extra clearance. Got mine on ebay for like £10.
Regards![/quote]
- 95 Fiesta SI
[quote="95 Fiesta SI"][quote="gcodin"]
Regards![/quote]
Depends on the design of the wheel mate. Mine are 16" Mondeo 5 spoke ones and they only just clear the calipers. If you find your wheels catch the calipers get some 3mm wheel spacers for extra clearance. Got mine on ebay for like £10.[/quote]
Got the same rims as you mate,that's why I asked :D
Thank you for the info! :)
Regards![/quote]
- gcodin
