Extensive cossie brake fitting guide (large download) pics
Postby Ford_whore on Wed Jul 16, 2003 3:41 pm
a good guide top quality
Ford_whore
Postby jonzy@sw-cc.com on Wed Aug 27, 2003 3:13 pm
Stupid question - how thick are 5 penny washers? Id rather have spacers made up than use washers.
Jonzy
jonzy@sw-cc.com
Postby M Brian on Fri Sep 12, 2003 12:24 am
is there any chance of getting them under 14s?
MELV
Still needs a new sig!!
1.6CVH EFI mk2 turbo (not running needs new front panel)
1.8 16v Focus Turbo! ;) (Leaking oil and doing 1300 miles a week!)
and Honda CBR600 (loving the revlimiter)
M Brian
Postby AdrianFRST on Fri Sep 12, 2003 8:23 am
M Brian :is there any chance of getting them under 14s?
Below are 15s, so have a guess... ;)
Image[/img]
Baby Battle Scratch
Baby Battle Scratch
Your car: ..? Pretty car..!
Car: 2010 Ford Focus RS
Postby TJ on Fri Sep 12, 2003 9:37 am
Sorry to be so blunt, but no chance!! Ive got 15"s and i had to remove the balancing weights to get the wheel to turn! Look how thin they are!
TJ
Postby M Brian on Fri Sep 12, 2003 8:16 pm
are they closer to the front/spokes or the inner rim of the wheel?
its difficult to tell from the pic
MELV
M Brian
Postby penfoldian on Sat Oct 25, 2003 10:18 pm
I just want to stop when i want to!!! so please erm, can i use red dot brakes? or should i just look for a messed up cossie and leech off the parts?
penfoldian
Postby Sphinx on Tue Nov 11, 2003 12:04 pm
ignore, double post
Postby Sphinx on Tue Nov 11, 2003 12:05 pm
MadcatCraig :soz guys
yeah only 4x4 cossie calipers work
you cna use the sierra setup as i did
or escort cosworth ones work just the same
2wd cossie ones dont tho
So Sierra Cossie 4X4 OR Escort cossie calipers....i assume u mean the front calipers etc in both cases? :-?
Postby TJ on Thu Mar 11, 2004 4:05 pm
Yes front only.
TJ
Postby wywywywy on Tue Jul 13, 2004 5:31 pm
Can you actually buy the spacers instead of using washers? :-?
Fiesta Mk3 The Complete FAQ
Have a look, and do a search, before you ask anything :)
Project Log
wywywywy
Postby mrviper on Tue Oct 19, 2004 6:08 pm
i just got escort cosie calipers and disks with greenstuff pads :Q
is all escort cos stuff ok for a mk3 fez ? :rolleyes:
mrviper
Postby Project_XR2i_Trackcar on Fri Nov 12, 2004 10:21 pm
guys
those of you that have fitted escort cosworth calipers and aftermarket discs & pads......Could you give a description of the improvement over standard XR2i brakes.
I'm about to buy a set and would like to hear how they do
Renault Sport Megane 250 Cup
Ford Fiesta XR2i 2.0 trackcar
Your car: Xr2i
Postby wywywywy on Thu Nov 18, 2004 5:48 pm
Hi,
I've not fitted mine, but here is the description I heard:
"Your head hits the windscreen."
Is that good enough for you?
Project Log
wywywywy
Postby Project_XR2i_Trackcar on Thu Nov 18, 2004 9:08 pm
I've fitted mine now. pretty impressed first off. Will find out for sure on sunday
Your car: Xr2i
Postby VUK on Sun Dec 19, 2004 11:22 am
i can't see pics :cry:
VUK
Postby MadcatCraig on Mon Jan 10, 2005 3:28 am
havent been on this site fo ages guys and i cleared down my webspace a while ago.
as i see this guide is still at the top :D i have re uploaded the piccies and re-linked the first post to them :)
MadcatCraig
BANNED SELLER
Postby rsrob on Thu Feb 03, 2005 1:30 pm
are spacer brakets needed for the 4pot 2wd calipers :-? or do you need proper brackets ???
rsrob
Postby adamburzynski on Wed Oct 12, 2005 11:23 am
i've been told that sierra XR4x4 breaks are the same. is there any truth in this?
adamburzynski
Postby Luke_Si on Tue Oct 18, 2005 7:38 pm
This is how you can tell the difference between 2wd discs and 4x4 wheel and escort
4x4 Sirrea and Esscort Cossworth
Have
Dim 278mm
Hub 150 mm
height 36mm
thick 24mm
And also esscort cossie there is only one type of disc...
2 x Drive Sirrea
Dim 283mm
Hub 150 mm
height 55mm
thick 24mm
I hope this helps people out.
Luke_Si
Postby lucasdemoley on Wed Oct 19, 2005 3:14 pm
So, is this fairly easiy to do then as the guid makes it seem as though it is?
Anybody know what difference it makes i.e stopping from 60mph?
lucasdemoley
Postby Avinitlarge on Thu Oct 20, 2005 7:25 pm
IIRC the cossie brakes are the same size as the Mondeo V6 ones, I have a set of mondeo V6 calipers for sale.
I also have made a guide for fitting 300mm brakes to a mondeo, I imagine its similar to fitting on a fez
Avinitlarge
Postby RS_Rawli on Thu Oct 20, 2005 7:32 pm
cossie calipers are the same as mondeo 4x4
RS_Rawli
Postby Avinitlarge on Thu Oct 20, 2005 11:47 pm
RS_Rawli :cossie calipers are the same as mondeo 4x4
Shouldnt that be the other way round
Avinitlarge
Postby Rhinopower on Sat Oct 22, 2005 10:08 am
Rhinopower
Your car: Volvo FH330
Postby Avinitlarge on Sat Oct 22, 2005 12:45 pm
Avinitlarge :
Doh!!! I meant, 4X4 Cossie calipers are the same as V6 mondeo calipers
Avinitlarge
Postby RS_Rawli on Sat Oct 22, 2005 2:01 pm
no, 4x4 cos, 4x4 mondeo
RS_Rawli
Postby Luke_Si on Sun Oct 23, 2005 1:37 am
RS_Rawli :no, 4x4 cos, 4x4 mondeo
There is no mondeo 4x4 that I know off m8 :-?
Luke_Si
Postby RS_Rawli on Sun Oct 23, 2005 9:41 am
:lol: i assure you there is, and thats what the brakes come off
RS_Rawli
Postby Luke_Si on Sun Oct 23, 2005 3:32 pm
Hi All,
Got the stuff for my escort cossie capilers and mounts did u use the cossie mounts for the capiler or the fiesta ones as the bolts the fiesta ones uses is two small to fit in the cossie mounts and if u uses the big bolts the cossie uses they wont go in to the hub.
Any help would be thankfull.
Luke
Luke_Si
Postby Avinitlarge on Sun Oct 23, 2005 3:40 pm
The 4X4 mondeo brakes are no different to the mondeo V6 brakes then, All though, I thought the 4X4 brakes were just the same as a normal 2.0 Si, Ive got that many sets of calipers, Ive forgot whats what. The V6 brakes may be good on a fiesta but its a different story on a mondy due to the weight, The latest brake upgrade is to fit 300mm Mk3 mondeo brakes on the Mk1/2 mondeos
Avinitlarge
Postby turboben1 on Sat Dec 17, 2005 8:23 am
Luke_Si :Hi All,
Luke
anyone know the answer to this just had this problem my self
turboben1
Postby RS_Rawli on Sat Dec 17, 2005 10:47 am
Avinitlarge :The 4X4 mondeo brakes are no different to the mondeo V6 brakes then, All though, I thought the 4X4 brakes were just the same as a normal 2.0 Si, Ive got that many sets of calipers, Ive forgot whats what. The V6 brakes may be good on a fiesta but its a different story on a mondy due to the weight, The latest brake upgrade is to fit 300mm Mk3 mondeo brakes on the Mk1/2 mondeos
no, mondeo 4x4 calipers are not the same as V6 ones or the same as 2.0si ones
RS_Rawli
Postby turboben1 on Sat Dec 17, 2005 12:34 pm
turboben1 :
Luke_Si :Hi All,
Luke
anyone able to helpdo i just drill the holes out or are they the wrong brackets
turboben1
Postby Dazza on Sat Dec 17, 2005 1:38 pm
Need more info, you doing the 4X4 Cossie swap?
If so all info is in the 1st post
Dazza
