Extensive cossie brake fitting guide (large download) pics
106 posts • Page 2 of 4 • 1, 2, 3, 4
Stupid question - how thick are 5 penny washers? Id rather have spacers made up than use washers.
Jonzy
Jonzy
- jonzy@sw-cc.com
is there any chance of getting them under 14s?
MELV
Still needs a new sig!!
1.6CVH EFI mk2 turbo (not running needs new front panel)
1.8 16v Focus Turbo!
(Leaking oil and doing 1300 miles a week!)
and Honda CBR600 (loving the revlimiter)
- M Brian
- AdrianFRST
- Baby Battle Scratch
- Your car: ..? Pretty car..!
Car: 2010 Ford Focus RS
are they closer to the front/spokes or the inner rim of the wheel?
its difficult to tell from the pic
MELV
- M Brian
I just want to stop when i want to!!! so please erm, can i use red dot brakes? or should i just look for a messed up cossie and leech off the parts?
- penfoldian
MadcatCraig :soz guys
yeah only 4x4 cossie calipers work
you cna use the sierra setup as i did
or escort cosworth ones work just the same
2wd cossie ones dont tho
So Sierra Cossie 4X4 OR Escort cossie calipers....i assume u mean the front calipers etc in both cases?
- Sphinx
- wywywywy
i just got escort cosie calipers and disks with greenstuff pads
is all escort cos stuff ok for a mk3 fez ?
- mrviper
guys
those of you that have fitted escort cosworth calipers and aftermarket discs & pads......Could you give a description of the improvement over standard XR2i brakes.
I'm about to buy a set and would like to hear how they do
Renault Sport Megane 250 Cup
Ford Fiesta XR2i 2.0 trackcar
- Project_XR2i_Trackcar
- Your car: Xr2i
Hi,
I've not fitted mine, but here is the description I heard:
"Your head hits the windscreen."
Is that good enough for you?
- wywywywy
I've fitted mine now. pretty impressed first off. Will find out for sure on sunday
- Your car: Xr2i
havent been on this site fo ages guys and i cleared down my webspace a while ago.
as i see this guide is still at the top
i have re uploaded the piccies and re-linked the first post to them
- MadcatCraig
- BANNED SELLER
- rsrob
This is how you can tell the difference between 2wd discs and 4x4 wheel and escort
4x4 Sirrea and Esscort Cossworth
Have
Dim 278mm
Hub 150 mm
height 36mm
thick 24mm
And also esscort cossie there is only one type of disc...
2 x Drive Sirrea
Dim 283mm
Hub 150 mm
height 55mm
thick 24mm
I hope this helps people out.
Have
Dim 278mm
Hub 150 mm
height 36mm
thick 24mm
2 x Drive Sirrea
Dim 283mm
Hub 150 mm
height 55mm
thick 24mm
- Luke_Si
So, is this fairly easiy to do then as the guid makes it seem as though it is?
Anybody know what difference it makes i.e stopping from 60mph?
- lucasdemoley
IIRC the cossie brakes are the same size as the Mondeo V6 ones, I have a set of mondeo V6 calipers for sale.
I also have made a guide for fitting 300mm brakes to a mondeo, I imagine its similar to fitting on a fez
- Avinitlarge
- Avinitlarge
- Rhinopower
- Your car: Volvo FH330
Avinitlarge :RS_Rawli :cossie calipers are the same as mondeo 4x4
Shouldnt that be the other way round
Doh!!! I meant, 4X4 Cossie calipers are the same as V6 mondeo calipers
- Avinitlarge
Hi All,
Got the stuff for my escort cossie capilers and mounts did u use the cossie mounts for the capiler or the fiesta ones as the bolts the fiesta ones uses is two small to fit in the cossie mounts and if u uses the big bolts the cossie uses they wont go in to the hub.
Any help would be thankfull.
Luke
Luke
- Luke_Si
The 4X4 mondeo brakes are no different to the mondeo V6 brakes then, All though, I thought the 4X4 brakes were just the same as a normal 2.0 Si, Ive got that many sets of calipers, Ive forgot whats what. The V6 brakes may be good on a fiesta but its a different story on a mondy due to the weight, The latest brake upgrade is to fit 300mm Mk3 mondeo brakes on the Mk1/2 mondeos
- Avinitlarge
Luke_Si :Hi All,
Luke
anyone know the answer to this just had this problem my self
- turboben1
Avinitlarge :The 4X4 mondeo brakes are no different to the mondeo V6 brakes then, All though, I thought the 4X4 brakes were just the same as a normal 2.0 Si, Ive got that many sets of calipers, Ive forgot whats what. The V6 brakes may be good on a fiesta but its a different story on a mondy due to the weight, The latest brake upgrade is to fit 300mm Mk3 mondeo brakes on the Mk1/2 mondeos
no, mondeo 4x4 calipers are not the same as V6 ones or the same as 2.0si ones
- RS_Rawli
turboben1 :Luke_Si :Hi All,
Luke
anyone able to helpdo i just drill the holes out or are they the wrong brackets
- turboben1
[/img]
