et15 wheels?? will they fit
Postby smoov_fezzy on Fri Jun 27, 2003 11:19 am
as topic.. will they and what will ned doing im gonna lower it 40mm so whats the score?cheers! :D
Image...
smoov_fezzy
Postby Rich si on Fri Jun 27, 2003 11:19 am
NO
Rich si
Postby smoov_fezzy on Fri Jun 27, 2003 11:25 am
????y???
Image...
smoov_fezzy
Postby Ian C70T5 on Fri Jun 27, 2003 11:26 am
you fitting a super wide arch kit? if not they will fit but stick out a mile and fail MOT
Ian C70T5
Das Ist Kapput
Das Ist Kapput
Postby fiesta boy on Fri Jun 27, 2003 11:26 am
fiestas are arouned et 35 i think escort cos are et 16 and ther a pain in the arse 2 fit
fiesta boy
One big spelling error...
Postby smoov_fezzy on Fri Jun 27, 2003 11:28 am
they were dan xr2i's and he said he had em on his fezz no probs.
Image...
smoov_fezzy
Postby Ian C70T5 on Fri Jun 27, 2003 11:47 am
My Escort cossie wheels were ET25 and stuck out at front, however with FRST's the wheels sit in towards car more as syrsmads stuck out more than mine did
Ian C70T5
Das Ist Kapput
Das Ist Kapput
Postby smoov_fezzy on Fri Jun 27, 2003 11:49 am
so the hubs on a frst are more deeper than any other fezz?
Image...
smoov_fezzy
Postby fiesta boy on Fri Jun 27, 2003 6:53 pm
1.1 has wider track at the rear fact founed this out after i fitted my new 17's after i changed 2 a 2i rear set up
fiesta boy
Postby smoov_fezzy on Fri Jun 27, 2003 6:59 pm
where would i go to get some machined off the offset then?? much help appreceated.
Image...
smoov_fezzy
Postby Project on Fri Jun 27, 2003 7:14 pm
FiestaBoy - exactly what did you change when you went over to the 2i rear setup? Did you use 2i drums as well?
ET15 will physically fit, but as approx 1" further out of the wheelarch.
Wider track on the FRST is made by increasing the negative camber on the front wheels (through use of longer lower arms) which is why the top of the wheel sits further in.
Wrong forum.
Project
fiftyoneCL
fiftyoneCL
Postby F3 dappa on Sun Jun 29, 2003 10:14 pm
i tried to put ET18 16's on my 1.1 and that was a fookin bad idea, they came off the same day. they stick out a mile, look stupid, are illegal unless you get some super wide arches, rub like a bicth and waste a lot of time if you buy them (speaking from experience). wouldnt bother.
F3 dappa
