Drive Shafted!
19 posts • Page 1 of 1
Drive Shafted!
I can't seem to get my drive shafts out, the 2 nuts at the end of each one are solid as a platinum covered mr. t! any suggestions?
adam
adam
Just you wait! Its gonna be a beast!
- Adam_W
See i told you that you'd need my expert help
Just whatever you do, dont try towing it with the driveshaft half hanging out, bad things will happen
Undoing the bolts should just require a big ass spanner/socket
Find a nice big bar to slip over the rachet to get more leaverage and job done
- MaXsteri
MaXsteri :See i told you that you'd need my expert help![]()
Just whatever you do, dont try towing it with the driveshaft half hanging out, bad things will happen![]()
I will make a mental note of that wayne, cheers!
So big fookin lever it is then! Cheers lads!
- Adam_W
just do what i did and attacha bout 3 ratchet sets together then u got one big mutha fucker of a lever
- HaggisTurbo
Project ST2000 :Umm, I might be stating the bleedin obvious here, but you do know it's a reverse thread on one side don'tcha?
Seriously? I've never had that? Always left the gun on reverse.......
never noticed on any of the 4 festers ive taken shaft off! would make sense though!Excursion :Project ST2000 :Umm, I might be stating the bleedin obvious here, but you do know it's a reverse thread on one side don'tcha?
one minor point dont use a rachet to undo it ull prob knacker it!
buy a breaker bar from halfords! £15 i think mine was, loads of leverage and garenteed for life.
as for getting the driveshaft out the hub, the only way i do it now is to undo the lower arm bolt out (one in line with the hub) so the hub now swings on the other bolt and the suspension, then using plenty of penertatrive lube(wd40) pull the hub out wards far as freely possible and tap the end of the shaft with a copper head mallet
- FezzR
- God Damn Lazy
FezzR :as for getting the driveshaft out the hub, the only way i do it now is to undo the lower arm bolt out (one in line with the hub) so the hub now swings on the other bolt and the suspension, then using plenty of penertatrive lube(wd40) pull the hub out wards far as freely possible and tap the end of the shaft with a copper head mallet
Shame you didnt develop a method that actually works before we played with my car
- MaXsteri
MaXsteri :FezzR :as for getting the driveshaft out the hub, the only way i do it now is to undo the lower arm bolt out (one in line with the hub) so the hub now swings on the other bolt and the suspension, then using plenty of penertatrive lube(wd40) pull the hub out wards far as freely possible and tap the end of the shaft with a copper head mallet
Shame you didnt develop a method that actually works before we played with my carWould have saved just a bit of time
Oh well, got the job done eventually
funny thing is i did know that method but with ur knackered lower arms wouldnt have been able to get the arms back in, which is why i said u should get new arms!
- FezzR
- God Damn Lazy
Well i undid them yesterday, i learnt that its best to do it with the wheels on! lol
They is no reverse locking thingy, you just undo them as though they are normal nuts, i think you must be thinking of the rear wheels!
Thanks for all your help i juts got to get the bastads out know, any more tips?
adam
adam
- Adam_W
- FezzR
- God Damn Lazy
Adam if you want me to come over and "help", (point and laugh, make sarcastic comments, take pics, drink all your tea, distract you and force you to smooth my 2i bumper
etc
) then youve got my number, feel free to give me a buzz anytime.
I only work weekends now, i reduced my hrs to give me time to work on the car and portfolio, but mostly i just end up sleeping and sitting around getting bored playing PS2
So im free most of the time
- MaXsteri
