De-Cat for 1.4Si.....easy to fit? also....
Postby benc on Wed Jul 16, 2003 10:18 am
Hi, im lookin into buyin a de-cat pipe for my 1.4 mk fez si....just a few Q's i need answerin plzzzz....
Is it easy enuff 2 fit?
Will it fit a 1.6 Si when i eventually find one i want?
and last but not least, what do i do with the sensor thats plugged in2 the zorst once the CAT is taken off?
Cheers ppl.
B.
benc
Postby benc on Wed Jul 16, 2003 10:40 pm
help! there must b sum1 who knows??
benc
HELP!
Postby benc on Thu Jul 17, 2003 4:22 pm
HELP!...come on peepz, help plzzzz... :-?
benc
Postby Rich si on Thu Jul 17, 2003 4:30 pm
It wont fit a 1.6 si as they have a differant down pipe.
Should be to hard as long as the bolts havnt seized. Carefull you dont snap the studs in the manifold either
Rich si
Postby benc on Thu Jul 17, 2003 4:33 pm
Rich si :It wont fit a 1.6 si as they have a differant down pipe.
hope u meant shouldnt b too hard, lol...
is it just a matter of un-bolting the cat part of the zorst and puttin this in place? What happens to the sensor thats just before the CAT?
Cheers rich.
benc
Postby Rich si on Thu Jul 17, 2003 4:40 pm
The sensor will be the lambda sensor, id have thought there will be a place to screw it into on the de cat pipe.
Yeah its just a matter of unbolting the cat part. Iirc that has the down pipe attached to it.(by this i mean it one part and the deact pipe will include the down pipe) Well it does on the 1.6 anyway!
Rich si
Postby FiestaMental on Thu Jul 17, 2003 4:45 pm
i had it done on my old si. Sounded like a nascar. Nice if you like that sorta thing but can be very loud at times your dont want it to be!!
Mind you, saying that, it was a complete straight through pipe with 1 box and a 6" centre exit!!! :rolleyes: :lol:
***** 2 2 0 B H P M K 4 G O L F T U R B O *****
FiestaMental
Location: Ilford, esSEX Drives: 200bhp VW Golf GTI 1.8 20v Turbo
:o)
Postby benc on Thu Jul 17, 2003 4:53 pm
ok mate, thanks.
Your help is apreciated. If i hv any probs do u mind if i pm you n ask ya 4 some help?
Ta m8.
benc
Postby Rich si on Thu Jul 17, 2003 4:59 pm
Not a prob
Rich si
Postby benc on Thu Jul 17, 2003 5:07 pm
cheers m8.
Also...i see u have tinted the bottom half of your rear clusters...i wana do this to mine. will it look good on a java blue fez si? just afta some tips on doin it and wot did you use?
Cheers once again.
Ben.
benc
Postby Rich si on Fri Jul 18, 2003 9:20 am
On a java blue fez id go for a set of the smoked rears you can buy.
If you wanna half tint use foliatec light tinting spray.
You should use lacour after otherwise they'll look dull and bodged like mine do!
Rich si
Postby benc on Fri Jul 18, 2003 9:50 am
ok mate, cheers..i'll have a go at it cos im fed up [ERRR] bein pulled up by the old bill for my current ones! :x
Bit dark! :Q
So i'll hv a go a these ones. :D
benc
Postby Phil Si on Fri Jul 18, 2003 2:09 pm
changing cat...
1) jack up front of car, put on axel stands....
2) spray wd40 on all bolts needed to undo...
3) undo downpipe bolts... theres 2 of these and are the ones with springs under them, need a long extension bar to do this..( forst time i did it i tookt eh rad out etc and used a spanner.. what a fool lol)
4) take off S shaped undertray thingy if u have it...
5) undo D clamp bolts .. (2 of them) migh be seized. get a new clamp incase they break off...
6) wiggle zorst free (doh juut remeber to undo the lambda sensor! 22mm ring spanner i think)
7) spray wd0 on new decat and on the zorst bit its going into..
8 ) insert into exhaust bit... make sure its in all the way lol
9) put new O-ring aske on top of downpipe bit, bolt this back up... then put the d-clamp on the new bit of zorst ...
in there u will have to put the zorst hangers on...along with S tray thingy :)
not too hard :)
How's my moderating? Call 0800-U-R-BANNED
Phil Si
Crack Smoker Of The Year 1999
Car: 2000 BMW 330 Ci
Postby benc on Fri Jul 18, 2003 2:22 pm
cheers phil...im gona print this off n use it! :D
ta m8.
B
benc
