CAMBER Common Problem???
Re: >
Postby df908 on Thu Aug 07, 2003 10:42 am
MIK3Y :So new arms must be needed but at £280! I havn't that sorta money for wishbones at the mo, but something for the future
TheJester :but the good news is he also does them with standard bushes (which u could the replace with poly bushes) for £80 ish
Slightly less than £280... :rolleyes:
MIK3Y have a look at http://www.fiestaturbo.com/phpBB/viewtopic.php?t=38416 thats the original thread about the lower arms.
Nige
'94 mondeo. Pass the mortgage, son.
Hmm... what... eh?
df908
Re: >
Postby TheJester on Thu Aug 07, 2003 11:00 am
Like i Sed i a previous reply u can get standard rubber bushed adjustable lower arms for around £80. Its ths rose jointed ones that are expensive.
TheJester
Postby MIK3Y on Thu Aug 07, 2003 12:28 pm
AdrianFRST :Yep, they can be done without the rose joints.
New arms £100 plus postage.
Modification to your existing arms £50.
The rose joints are fine for road use though. They are PTFE lined to significantly reduce the wear caused by road grit / salts.
Is £280 for the pair?
So if i was to send my new genuine ford arms to Ian he would make them adjustable for £50 each but not rose jointed? Is this right?
Thanx
MIK3Y
Previous
