bike carb setup: breakdown
12 posts • Page 1 of 1
ok, im planning on going the bike carb route in a few months
but i keep getting confused with certain pieces
Management:
ive picked up the idea that if you go for bike carbs such as the GSX-r 600 setup, you can retain the standard ecu, and adapt the loom to fit the carbs TPS
am i right in saying that?
Manifold:
simple case of cutting up an old manifold and using joiners and clips to join the carbs to it, if needed blank off injector holes?
again right?
Vacuum:
bit vague on this topic, theres plenty of them,
crank case what to do with that?
brake servo vacuum? again blank spot
Fuel pump: think i have my head around this part, use a regulator/specified reducer
or use a select bike pump, eg R1
no return needed, blank off
Throttle linkage: what to do here? can you simply make a bracket so the standard cable can connect to the carb linkage fine?
Air filter: ive seen so many missing one, weather a single long unit or individual cones, some dont bother, cant be the safest right?
Correct amount of fueling: carbs deliever the right amount of fuel as per amount of air drawn through the venturi via vaccum effect, but what of the jets? how do i know weather the carbs are delivering enough or too much fuel for my 1.8 130 spec zetec?
think thats all the gray areas
oh also, i believe GSXR 600 carbs are 38mm, im lead to believe thats bang on for a 1.8, i know 40s would be fine but can anyone confirm?
if not which cc bike would be best??
Cheers!
Management:
Manifold:
again right?
Vacuum:
Cheers!
Re: bike carb setup: breakdown
I have bike carbs on a CVH and was going to fit to my 2litre zetec before opting for throttle bodies my opinions are
Management:
not sure if standard ECU will work with carbs as you will be removing the MAF input, correct TPS as different resistance profile and possible lamba sensor. best option ignition only ecu like megajolt.
Manifold:
again right?
I would make a new manifold from a lazer cut blank plate direct to head, will also gain extra space which will be required for filter some info here http://www.fiesta-si.com/forums/viewtopic.php?f=16&t=17588
Vacuum:
into separate catch tank
make new connections on manifold
use a matching fuel pump from bike carbs came off no need for a regulator then
correct
modify existing cable and carb connection
a blank plate and sausage filter
carbs will need rejetting to match zetec possible enlarge to 1.6-1.8mm, you will need to check with lamba gauge to confirm correct jetting
general 38mm-40mm carbs be fine zxr6 and zxr9 carbs a poplar choice for zetec's
hope it helps
Hope it helps
Management:
Manifold:
again right?
Vacuum:
correct
hope it helps
Hope it helps
- will121
to help give you idea of how to assemble with st170 inlet
http://www.sportingfords.com/forums/vie ... 60attached
i have followed this guide and am nearly finished on the fab work, i bought a DIY PNP eeciv kit from diyautotune that i will use to run it at some point
- AW0L
Is there any particular reason why you are using carbs rather than injectors?
Ex Fiesta RS Turbo owner
- filtra
well i understand bike carbs are simpler to fit, you can maintain the original ecu (not that its best choice) making it cheaper as you dont need to buy a megasquirt or other
TBH mate, I'd do it back to front to how you're describing it; get the ecu first; I know it's expensive, but you're setting yourself up for the future in one go and will let you make the best out of what you have now.
Nothing to see here...
- andymac
- Elite Pie Master
a fine point, that ecu is good for turboing, TBs or just as a mappable upgrade to mine... ill consider this
thanks
thanks
np dude, I'm doing it this way around because it means I can build up to a final spec and reap the rewards of all the changes as I go along. I was going to do it all piecemeal (to a degree I still am) but looks like fortune has dictated I'm going to inherit one, perhaps two complete cars (one a turbo, one a 1.8 VVc), so I'll drop the engine and box out of the turbo and rebuild both in my own time. I'll have a ready supply of panels and spares for years to come as well then too. I'll still do the ECU first though, get it mapped to the standard engine then once all the work's been done, remap to suit.
Clutch decision is the hardest bit of the whole lot; fast road organic, kevlar or paddle.
- andymac
- Elite Pie Master
You'll be better off using a throttle body setup, it's easier to set up with the original sensors ect.
If you need some help or advice, phone Graham at Chester Sports Cars. I always used to phone him up for random info when we used to put alpha webber setups on blacktop engines in kit cars. Him and his son are very knowledgeable in it all and will happily give you info on everything you want to know. They will be at ford fair too as usual, so pop over and speak to them on the day
- - Danny Boy -
- Your car: Fiesta Si 2.0
bang on danny, im always having a proper nose and taking dozens of pics of they're work at shows, think ill actually say something the next show
theyre blue mk1 mexico is a work of art
sounds very good andy, which model you refering to know?
I only own one car these days mate
I'll be megasquirting or getting a ready built solution from boostmonkeys tbh, then going from there. I have a 4k shopping list atm and that doesn't even include a new turbo...
- andymac
- Elite Pie Master
