belgian xr2i 2.0l zetec (13/03/12) megasquirt ecu
158 posts • Page 4 of 5 • 1, 2, 3, 4, 5
Re: belgian xr2i 1.8 16v (23/09/10)front end rebuild
Sphinx :Awesome as usual
i'll do my best
- dj_yd
- dj_yd
- dj_yd
Re: belgian xr2i 1.8 16v (30/09/10)painting things
I wish i had the time to do this sort of thing to mine
Abslutly stunning
Abslutly stunning
- martynkeep
i'v been doing a lot on the fiesta
i cleaned the inside of the cooling fluid bottle
i think it looks a lot better
before
after
then i cleaned the rust of the mounts from the headlights and painted them
befor
after
and this weekend i spray painted the enginebay , i chose ford frozen white, it looks good with the imperial bue
i realy like it
some heatshield against the firewall
than i started rebuilding things
the PAS steering rack ,cooler and pipes, the brakeservo and brakepipes, the wiper motor,the blower fan,feulfilter, and a part of the loom
i hope to drop the 2.0l in over the weekend
i like it , hope you guy's do to
gReetS
before
after
befor
after
i realy like it
gReetS
- dj_yd
Re: belgian xr2i 1.8 16v (17/10/10)enginebay rebuild
this week i prepaired the enginebay for the 2.0 zetec to go in
and i modified the plate that sits between the engine and the gearbox, because of the starter location in the mondeo at the rear
the original plate and the little peace that needs welding on the plate
welded and painted
than i could connect the gearbox and the engine(i'm using a old camcover for the instalation)
on it's way to his new home
and the engine is in , but no pictures of it yet
welded and painted
- dj_yd
- Ratspeed
Loving this as usual
- Sphinx
Ratspeed :man, that looks soooo clean!
thanks mate, i love your fords 2
- dj_yd
Sphinx :Loving this as usual
i have a fan lol
thanks
- dj_yd
- dj_yd
Re: belgian xr2i 1.8 16v (20/10/10)enginebay rebuild
last week i'v been bussy
the front susspension back in GAZ shocks and fiesta st brakes
and the 2.0l in :twisted:
i cleaned the front angine mount and painted it
and al build up
i need to clean it , i see dust in the pics
than came the big moment :mrgreen:
first remove the fuse from te feulpump and the sparkplugs, and crank it over a few times
sparkplugs and feulpumpfuse back in
ok here we go
i turn the key and .... hu hu hu hu..... hu hu hu hu
like i was thinking a flat battery :roll:
got my parents focus and conected the jumperleads and tried again
it started the first time :twisted:
and than switched it of again, i'm running piper cams and i have to run them in at +- 2500rpm for 20min, i couldn't do this as i had a cooling fluid leak
the next day i fixt the leak and charged the battery and started it again
20min at 2500 for the cams to bed in
than switched it of again and let it cooldown for a night
next day i started it again , to see what the idle whould do
it staled emediatly
the reason was that i dismantled the throtlebody and i had tho adjust the butterfly a bit , now it idle's at 1000rpm and 900rpm
i'v done the first miles and it runs verry wel , i'v not driven it hard just taking it easy and run it in for a few 1000miles
i'm happy that it does what its supposed to do
knowing i did it al by myself and i'm just a elektrician and never had a mecaniks training.
i'm verry pleased
gReetS
and al build up
ok here we go
it staled emediatly
i'm verry pleased
gReetS
- dj_yd
Re: belgian xr2i 1.8 16v (2/12/10)running 2.0l zetec
a few weeks back i was doing the last running in miles on the 2.0 and than this happend
the back end lost traction and afte a few times trying to correct it i whent in the ditch
i had no injuries thats the good thing , but the fiesta is something else
this is how it looked like
the place off impact
the next day when i was over the first shock i started stripping it
the front suspention is al fine , also is the engine , maybe the left rear wheel is bent on the axel, i have to check later, the chassis is ok , only the body has a few big dents
- dj_yd
- dj_yd
- dj_yd
- dj_yd
Re: belgian xr2i 2.0l zetec (3/04/12) crash and rebuild
Thats some rotten luck
Its nice to see its getting repaired though!
- - Danny Boy -
- Your car: Fiesta Si 2.0
Good Luck and I Hope Your Luck Gets Better..Its A Lovely Car
- Fraggle
something similar happened to me recently, its nice to see you havnt lost motviation!
such an awesome car and love the colour too!
- Michael!
i will post the last updates on the fiesta
i got the inner wheelarch at the rear back in shape and i welded a new peace on the outside
and than welded a new Quarter panel on
all nice gaps
and because i couldn't find a quarter panel from a mk3,5 i had to chop it and weld a new peace in for the filler flap from a mk3,5
the correct peace for a mk3,5 fillerflap
where it should be
and the mk3,5 fillerflap in place
that's it for now
greetz
all nice gaps
where it should be
that's it for now
greetz
- dj_yd
- - Danny Boy -
Re: belgian xr2i 2.0l zetec (27/04/12) crash and rebuild
some awesome work going into that!
bad luck about the crash though mate
- Ratspeed
good on ya for starting building it again, i think if that happened to me i just wouldnt have the heart to start over
- fezza89
I don't come on here very often these days but I'm really sorry to see this
BUT at least you've got the skills to repair it so I'm sure it'll be fantastic in no time
- Sphinx
wow!!! after all that rebuilding you're pretty much doing it all over again!! you're brave matey!! well done!!
- SLEEMAN
- dj_yd
Re: belgian xr2i 2.0l zetec (09/05/12) primer
looking great matey when is it booked in for paint?
- SLEEMAN
SLEEMAN :looking great matey when is it booked in for paint?
tnx, i'll do the paint myself at home , maybe in the weekend
- dj_yd
the last days i'v been bussy
i preped it all ready for paint
i made myself a "paintbooth" with some plastic and 2 filters , 1 drawing air out , the other one blowing fresh air in
in the back you see a clean filter
and then soe paint and clear
the strange lines you see is the plastic reflecting
and the filter did his job
the wheelarches from the bodykit
the boothlid
and the enginebay back in frozen white
there is a little bit of dust here and there , all in the clearcoat, so i can pollish it out
the bumpers , spoiler and the middle section from the bodykit are next
grtz
the boothlid
grtz
- dj_yd
Re: belgian xr2i 2.0l zetec (05/06/12) paint
looks awesome matey! keep it up!
- SLEEMAN
wow amasing project, love the engine work, its very inspiring
very sorry about the crash, but what doesnt kill us... makes us strong they say
very impressed your not giving in and giving a big smile back, fixing it up and you seem to be already back on track with it in some new coats of paint
love it keep it up mate
excellent news that its survived and you've not given up.
i still love this colour
- Michael!
imo its too new looking for a mk3, its the colour mk5 Zetec s comes in
jonyb4 :imo its too new looking for a mk3, its the colour mk5 Zetec s comes in
Well I think it's beautiful :')
- Michael!
