belgian xr2i 2.0l zetec (13/03/12) megasquirt ecu
Re: belgian xr2i 1.8 16v (24/09/08) fan
Postby dj_yd on Mon Sep 29, 2008 4:55 pm
it's alive again :D
i'll have to say, it sounds like a beast :D
and it drives much better than before, fast throtle response, and it pulls through the revs like hell :D
the new fan in place
st170 manifold
just missing the starter
had to chop a bit from the carter to alow the lamda to fit
the rest of the exhaust
little sound clip
http://img531.imageshack.us/my.php?imag ... 002ow1.flv
greetz
dj_yd
Re: belgian xr2i 1.8 16v (20/10/08)timing belt
Postby dj_yd on Mon Oct 20, 2008 9:35 pm
new timing belt from ford
greetz
dj_yd
Re: belgian xr2i 1.8 16v (20/10/08) timing belt
Postby jonboisescort on Fri Oct 24, 2008 11:30 am
looking good mate
loving the manifold :Q
jonboisescort
Car: 1994 Ford Fiesta
Postby dj_yd on Wed Nov 05, 2008 11:35 pm
i removed the belt again and changed the waterpump while i was at it
old vs new
all fitted back and running again
i bought a cross-over from a frst and modded it
as i got it( it's modded to fit a zetec rocker cover by area six)
and how it is now
removed the pipe on the left and welded 2 holes up and from "turbo" to "RS" :D
not ready though
greetz
dj_yd
Re: belgian xr2i 1.8 16v (05/11/08) waterpump
Postby dj_yd on Sun Feb 08, 2009 11:00 pm
a small update, not much happend to the fez , just driving it :D
i did got the broken koni shock back from koni after 3 months, got it true mot.
for now i'm collecting parts for a 2.0 conversion and a gearbox rebuild with lsd
escort mk4 lsd
2.0 zetec maf
2.0 zetec desk ecu
oil temp and oil pessure gauge + oilfilter sandwichplate for the sensors
greetz
dj_yd
Re: belgian xr2i 1.8 16v (08/02/09) new parts
Postby dj_yd on Sun Jul 19, 2009 9:50 pm
i got some new parts
i ordert a set of GAZ coilovers , still waiting on them
found myself 2.0 silvertop :wink:
rebuild set for my gearbox
and adjustable pully's
greetz
dj_yd
Re: belgian xr2i 1.8 16v (19/07/09) 2.0zetec+lsd
Postby dj_yd on Wed Jul 22, 2009 11:11 pm
today i start stripping the 2.0
gReetS
dj_yd
Postby dangerousdave on Thu Jul 23, 2009 9:19 am
just read the whole thread as i have never seen this before, well done mate a lot of hard work has gone into making this car :Q
keep us updated with the 2l build!! :D
dangerousdave
Postby dj_yd on Tue Jul 28, 2009 10:18 pm
dangerousdave :just read the whole thread as i have never seen this before, well done mate a lot of hard work has gone into making this car :Q
thanks mate
dj_yd
Postby dj_yd on Tue Jul 28, 2009 10:37 pm
a bit more
cylinder head cover of
at first site all looks good, when i removed the cams 1 of the bearingcaps had som blue colloring on it and there where some with marks on them, and where the camshaft meets the bearing there where some marks on them
the cams have been out before because the bearingcaps where marked, but when they refitted them they where possisioned the wrong way, i suspect this is the reason for the faults, and bad oil ofcourse
the bores and tops of the pistons look good imo
head of
sump of
gReetS
dj_yd
Re: belgian xr2i 1.8 16v (28/07/09) 2.0 disasembly
Postby dj_yd on Thu Aug 13, 2009 10:37 pm
i got my GAZ coilovers and fitted them, very happy with them
only need to fit a spacer at the back , the spring is catching the tyre
my alternator broke down, i had it rebuild and its back on now
gReetS
dj_yd
Re: belgian xr2i 1.8 16v (13/08/09)GAZ coilovers
Postby xr2irhys on Fri Aug 14, 2009 1:25 pm
that is beautiful :)
xr2irhys
Car: 1996 Ford Fiesta Classic
Postby dj_yd on Thu Aug 20, 2009 11:04 pm
xr2irhys :that is beautiful :)
thanks mate :wink:
i fitted a spacer between the reardrum and axle, the wheels are spaced 12mm both sides, so now i can lower the GAZ shocks at the back
and i made a rear strutbrace looks great and fits perfect :D only need to powdercoat it
gReetS
dj_yd
Re: belgian xr2i 1.8 16v (20/08/09)spacer+strutbrace
Postby dj_yd on Sat Aug 22, 2009 1:58 pm
Got in too the 2.0 again , same story as the head, marks on the bearings and crank
the head has been checked and can be fixed :wink:
gReetS
dj_yd
Re: belgian xr2i 1.8 16v (22/08/09)2.0 stripping
Postby dj_yd on Mon Sep 28, 2009 5:08 pm
latest updat
i got my home made strutbrace powdercoated
and started with the oil temp and pressure gauge's
i made a fiberglas peace and painted it
not the best pic :roll:
gReetS
dj_yd
Re: belgian xr2i 1.8 16v (28/09/09)oil temp and pressure
Postby dj_yd on Sun Oct 11, 2009 4:45 pm
i have finished the front strutbrace
gReetS
dj_yd
Re: belgian xr2i 1.8 16v (11/10/09)front strutbrace made
Postby dj_yd on Thu Oct 22, 2009 8:46 pm
got myself some pipercams for the 2.0 zetec :D . type KBZETA270BH
gReetS
dj_yd
Re: belgian xr2i 1.8 16v (22/10/09)piper cams
Postby frostie on Fri Oct 23, 2009 11:10 am
all very good work there but i would recommend getting some after market ecu then she will fly !
frostie
Postby dj_yd on Fri Oct 23, 2009 1:19 pm
frostie :all very good work there but i would recommend getting some after market ecu then she will fly !
i'm planning to build a megasquirt ecu, only need a base map for it then and see from there, you don't have one maybe? :D
dj_yd
Postby dj_yd on Mon Nov 02, 2009 9:38 pm
i had alot of vibration on flat roads, and when i fited the strutbrace the engine hits it on load
so got some vibra-technics fast road gearbox mounts for it
gReetS
dj_yd
Re: belgian xr2i 1.8 16v (02/11/09)vibra-technics
Postby dj_yd on Tue Nov 17, 2009 8:52 pm
recieved a nice upgrade today
fiesta ST
OEM 240mm van ST 278mm
testfit
they are a direct fit , and my 15" mk5 RS2000 wheels fit ok
st setup
now paint them, new fluid and hoses and get them on :D
gReetS
dj_yd
Re: belgian xr2i 1.8 16v (17/11/09)fiestaST brakes
Postby zottenbarryfrst on Wed Nov 18, 2009 2:41 pm
Nice, love st brakes , also love the colour
but if you're planning on doing a rear disk conversion you have to know somebody at Goca (MOT in Belgium) because it's illegal to do that :(
Stupid laws in Belgium
zottenbarryfrst
Postby dj_yd on Thu Dec 31, 2009 11:32 am
thanks for the repley
i'm not going to use rear disks, they are not mot proof in belgium, same as the front disks. :rolleyes:
gReetS
dj_yd
Postby dj_yd on Thu Dec 31, 2009 11:36 am
I got the block and head back from machining
the head had a skim, opend and flowed inlets and exhaustports, new valve gides en the valves has been cut again
the block had also a skim and the bores are honed
the crankshaft is polisched
gReetS
dj_yd
Re: belgian xr2i 1.8 16v (31/12/09)2.0 honed and flowed head
Postby dj_yd on Thu Mar 11, 2010 11:32 pm
latest progres
i got some pistonrings
and a set of arp rodbolts
had to buy some new tools
-a torquewrench 6 to 40nm
-feelergauges
-a pistonring compressor
dj_yd
Postby dj_yd on Thu Mar 11, 2010 11:47 pm
and finaly started the rebuild :D
new pistonrings after checking the gap clearance
new main bearings
crank in
the crankshaftseal housing
cleaned up
gasket in place
the housing mounted to the block
and the seal in place
ARP conrodbolts vs OEM
newbig end bearings
nr1 and nr4 in
i checked the running clearance on the main and big ends and checked the endfloat, all was well :D
dj_yd
Postby dj_yd on Fri Mar 12, 2010 12:03 am
new o-rings for the injectors,ford head bolds and new pistonjets
new 1.8 fiesta waterpump
4 pistons in :D
pistonjets
i cleanedthe feulrail
got the injectors in the feulrail , al new seals
i than matched the sandwich plate runners to the ports and gave them a mild pollish
also i mached the inlet manifold to the sandwich plate
thats it so far
hope you like and if you see something thats not ok then please tell me :D
dj_yd
Re: belgian xr2i 1.8 16v (11/03/10)2.0 rebuild
Postby dj_yd on Mon Jun 14, 2010 4:10 pm
cleaned and painted HO inlet manifold
painted the sandwichplate
cleaned and painted the throttlebody ,pollished the inside, pollished the butterfly and knife edged it, also made the inlet edge smoother
before
after
cleaned and painted the sump
i bought a oil pickup-pipe, when i recieved it the wiremesh was out
so i chopped the 2.0 oil pickup-pipe and got that mesh and got it in the 1.8 pipe
new oil pump
dj_yd
Re: belgian xr2i 1.8 16v (14/06/10)2.0 rebuild
Postby dj_yd on Tue Jun 15, 2010 9:59 pm
the latest updates
oil pickup-pipe fitted
new gasket on the clean sump
sump fitted with some stainles steel bolts
[IMG=http://img44.imageshack.us/img44/9190/picture004gj.jpg][/IMG]
new 1.8 waterpump
skimmed block
headgasket
head and piper cams ready for fitting
ported and flowed exhaust port
ported and flowed inlet port
head on block
piper cams fitted
now i need to sort the timing and the 2.0 is ready :mrgreen:
gReetS
dj_yd
Re: belgian xr2i 1.8 16v (15/06/10)2.0 almost build
Postby dj_yd on Tue Jul 13, 2010 9:25 pm
my latest update
i have some vernier pulley's , i only had to drill a hole to match the piper cams so i can fit the dowel's
pipercams
drilled the hole in the pully
pully on and locked with the dowel in place
al timed up
a new ford timing belt
i painted the timing covers and moddet the upper cover so you can see the pully's
than started on the inlet manifold
gasket in place
the sandwichplate and injectors in place
the other gasket
and the HO inlet on
and this is how it will look :D
a few litlle things and its ready
gReetS
dj_yd
Re: belgian xr2i 1.8 16v (13/07/10)2.0ZETEC
Postby jonboisescort on Tue Jul 13, 2010 9:44 pm
:Q :Q
awsome mate
love the cam cover :D
jonboisescort
Postby dj_yd on Thu Sep 23, 2010 10:15 pm
a few weeks ago i relocated the batery to the booth.
before
i removed the batterytray
the battery in the booth now mounted on the batterytray also a fuse holder
and a +12v terminal under the bonnet
and this is how it looked
dj_yd
Postby dj_yd on Thu Sep 23, 2010 10:25 pm
than i started the prep for the 2.0 transplant
from this
to this :P
i removed the surface rust, also the jack mount
etchprimer and seamsealer
and final primer
more to come :wink:
greets
dj_yd
Postby dj_yd on Thu Sep 23, 2010 10:31 pm
jonboisescort ::Q :Q
awsome mate
thanks mate :wink:
dj_yd
Re: belgian xr2i 1.8 16v (23/09/10)front end rebuild
Postby Sphinx on Fri Sep 24, 2010 10:05 am
Awesome as usual :aviator:
