518bhp zetec turbo fiesta
1 post • Page 1 of 1
Not really sure if I want to sell this but it's not getting the use it needs and I would like somthing a little more usable.
The car is currently making 518bhp and is very quick.
Car spec●
Engine:
Zetec turbo
Accralite pistions
Farndon rods
Arp head bolts
Arp bottom end bolts
Arp flywheel bolts
Area six big valve, full port and polish head
Area six double valve springs
Area six cams
Area six hd cambelt tensioner
St170 head gasket
Area six inlet
Area six custom exhaust manifold (ian howels old duratec manifold convrted to zt)
Precision turbo 6266gen2
Turbosmart progate 48
Greaddy blow off valve
Siemens injectors
Pectel t2 ecu with full braded loom
Pro alloy rs500 intercooler
Custom alloy rad
Aeromotive a1000 fuel pump and fuel filter
Pro alloy fuel tank
Pro alloy fuel swirl pot
Fully braded fuel lines
Turbosmart fpr
Roose motorsport silicone hoses
Cosworth throttle body
Custom alloy header tank
Titan dry sump pan
Weaver bro's drysump pump
Peterson oil tank
Peterson oil pressure valve
Fully braded oil lines
K&n air filter
Transmission:
Mtx75 conversion
Custom ratios
Custom hubs
Custom drag drive shafts
Sachs race clutch
Focus rs flywheel
Focus rs gear linkage and cables
Suspension:
Avo coilovers
909 motorsport top mounts
Area six rose jointed lower arms
Rose jointed rack ends
Zetec s rear axle with polly bushes
Focus rear hub conversion
Racing puma handbrake cables
Oz wheels 17" superelegras
Brakes:
Ap4pot calipers
330mm ap discs
Custom mk motorsport bells
Focus st170 rear brakes
Braded brake lines throughout
Bias valve
Body:
Mk3.5 shell fiesta turbo kit, vr6lower lip
Custom cages welded in roll cage
Mk5 fiesta dash
Pi systems dash 2
Stack gauges
Sparco seats
Luke 4 point harnses
Carbon door cards
Car is located in southampton looking for £12000 ono or px
Car spec●
Engine:
Zetec turbo
Accralite pistions
Farndon rods
Arp head bolts
Arp flywheel bolts
Area six cams
St170 head gasket
Area six inlet
Siemens injectors
Custom alloy rad
Pro alloy fuel tank
Turbosmart fpr
Titan dry sump pan
Peterson oil tank
K&n air filter
Transmission:
Mtx75 conversion
Custom ratios
Custom hubs
Sachs race clutch
Focus rs flywheel
Suspension:
Avo coilovers
Brakes:
Ap4pot calipers
330mm ap discs
Bias valve
Body:
Mk5 fiesta dash
Pi systems dash 2
Stack gauges
Sparco seats
Carbon door cards
- robp-tt
