47k fiesta rs turbo 11-5 stunning interior :-)
Re: my 46k fiesta rst - couple of new bits!! new radiator 29-4
Postby rob pace on Wed Apr 29, 2009 4:14 pm
just a few new bits ive managed to get round to, had a minor operation a week and half ago and still saw now but managed to fit some new goodies :D :D :D
brand new radiator - old one started to leak :lol:
decided to wet and dry then paint the outer casing of the fan as all the old paint had peeled off :D
and a new cambelt cover - i managed to get the scratch out :D
rob pace
Re: my 46k fiesta rst - new radiator + more 29-4
Postby Dave G fsi on Wed Apr 29, 2009 10:28 pm
Just found this thread mate, your car is absloutely awesome! Soooooooo clean! :Q
Love it! Keep up the good work! :aviator:
Dave G fsi
Your car: Mk1 FRS and FRST
Postby jayrs on Tue May 12, 2009 12:14 am
updates mate :)
your have something new to fit this week :wink:
Re: my 46k fiesta rst - more new goodies! - 22-5-09
Postby rob pace on Fri May 22, 2009 6:17 pm
right guys, had a bit os spare cash so i thought of ordering some new stuffthat im in need of! :)
alternator shield, made by jayrs :D , as my oil return is in the sump, i have moved my alternator forward and using a longer belt so this shield stops the blades slicing the radiator hose which has happened to me before :lol: :lol: will fit this weekend and update with more pictures :D
bargain off ebay, why not! :)
new gearbox gasket as mine leaks a lot, throttle cable clip, new flywheel cover (discontinued) and breather pot hoses :)
full engine sticker set that i managed to find :) not entirely sure where the 3 stickers on the far right go, anyone want to spread some light?? :-? :-?
fully refurbished standard alloys, bargain for these so i had to buy them :lol: (my others are for sale in parts for section :) )
check for some more updates in the next few days as im collecting more stuff on sunday :D :D :D :D :D :D :D :D
rob pace
Postby fiend on Fri May 22, 2009 8:28 pm
I think the white sticker on the far right goes on the left of the rock cover, there should be a small indent on the cover?
EDIT - Found a picture, the throttle cable is covering it slightly...
fiend
Postby jayrs on Sat May 23, 2009 12:06 am
the yellow one i belive goes on the battery, the white one as said above is for rocker cover, and the other too im not sure on aas not all fords came with these as far as i know, from what ive seen they get put in different places, but ive seen them on escorts before though.
you know im tempted to make another one of them shields for my own car :lol:
Postby Ram on Sat May 23, 2009 1:12 am
nice touch going back to standard wheels, if the rest of my car was standard id do that too.
where did you get the sticker set from, i bought a basic kit but wouldnt mind a few of the ones you got there :Q
Ram
Postby rob pace on Sat May 23, 2009 2:15 pm
Ram :nice touch going back to standard wheels, if the rest of my car was standard id do that too.
well im not putting the standard wheels on yet, just saw them at a good price :)
the stickers were bought from tremona garage, £22 for the set whch sounds steep but worth it i think.
just need to find out where them 2 blue stickers go :-? :-?
rob pace
Re: my 46k fiesta rst - ABS removal soon + tiny update 3-6-2009!
Postby rob pace on Wed Jun 03, 2009 7:07 pm
done a few things on the fiesta today as i had some spare time :) :)
alternator shield that jayrs made me, all fitted and perfect, now i wont shread my radiator hose above :lol: :lol:
had to remove the turbo today as the rear water coolant copper washers had started leaking on the T2 :oops: , wasnt going to bother, but it bugged me so i removed the turbo, used a bit of sealant with the new washers and job done :)
brand new genuine ford non ABS master cylinder and brake resivoir :D :D yes the ABS is going as its absolute crap and the brake pedal has no feel :oops:
full set of non-ABS front and rear brake lines in excellent condition and no corrosion, removed from an rs turbo. im going back to the factory non-ABS look here. :D not sure if to use the rear lines, or just remove the ABS spring load valves on the back and just make some copper lines to connect to the drums :)
rob pace
Re: 47k fiesta RST - new non-ABS brake lines + more 3-6-2009!
Postby Dave G fsi on Wed Jun 03, 2009 7:44 pm
Looks good mate! I want that master cylinder! Looks soooooooooo good! :Q
Dave G fsi
Postby jayrs on Wed Jun 03, 2009 8:31 pm
glad your happy with the sheild mate.
did it need any tweeking at all?
fit the whole non abs lines as said in pm mate :Q
Postby rob pace on Thu Jun 04, 2009 5:37 pm
jayrs :glad your happy with the sheild mate.
no, just bolted straight on and perfect mate :D
rob pace
Postby rob pace on Thu Jun 04, 2009 6:45 pm
jayrs :cool :Q
do you have to lower the fuel tank when you fit the rear lines? as the guy said he had to when he removed these :)
rob pace
Postby jayrs on Thu Jun 04, 2009 7:04 pm
could get away without dropping the tank in a way, but dropping it will make the job a lot easier
Re: 47k fiesta RST - rear arch clean 14-6-09
Postby rob pace on Sun Jun 14, 2009 5:21 pm
as the sun was out and i didnt drink 15 pints of strongbow last night :lol: i thought it would be a good idea to give the rear inner arches a good clean with a jet washer on low settings and a good shampoo with turtlewax :D couldnt get every spec of dirt out but has nearly come out looking like new and absolutely no signs of rust anywhere :o :o
drivers side arch :D :D
passenger side arch and fuel filler area :D :D
some quick snaps :D :D
rob pace
Re: 47k fiesta RST - rear arch clean 14-6-09 take a look!! :-)
Postby jonboisescort on Sun Jun 14, 2009 6:52 pm
looks great mate :Q
going to clean my arches tomoz as there filthy
jonboisescort
Car: 1994 Ford Fiesta
Postby rob pace on Sun Jun 14, 2009 6:59 pm
jonboisescort :looks great mate :Q
i thought it would take me 45 minutes, ended up taking about 2 and a half hours :lol:
rob pace
Postby jonboisescort on Sun Jun 14, 2009 7:07 pm
might leave mine probs underseal holding the car together
hope they come out like yours :)
jonboisescort
Postby Dave G fsi on Mon Jun 15, 2009 7:00 pm
Looks brilliant mate! Inspired me to paint mine on the rs now :Q
Dave G fsi
Postby jayrs on Mon Jun 15, 2009 8:27 pm
ive always givent the arches a blast at the jet wash but never to that exstent mate :lol:
tell a lie, i did clean my rear inner arches up when i done the rs up
good to see yours are nice and mint there mate
Postby rob pace on Mon Jun 15, 2009 9:17 pm
jayrs :ive always givent the arches a blast at the jet wash but never to that exstent mate :lol:
i was bored mate so i gave them a good clean! :lol:
rob pace
Postby jayrs on Mon Jun 15, 2009 11:27 pm
dont blaim ya mate
Postby 285Andy on Tue Jun 16, 2009 7:21 pm
alright Rob!.
are you gonna bin the load proportioning vavles :-?
285Andy
Your car: fiesta rs turbo
Postby rob pace on Tue Jun 16, 2009 7:36 pm
285Andy :alright Rob!.
the ABS valves on the rear beam? there coming off as well!
rob pace
Postby Ratspeed on Tue Jun 16, 2009 9:00 pm
Thats soooooooo clean :Q
I wish i could keep mine clean but its hard when its a daily :(
Ratspeed
Postby 285Andy on Tue Jun 16, 2009 9:42 pm
rob pace :
yeah those, there load proportioning valves. why get rid of those? but hey, if your literally going to throw them away, chuck em down this way please buddy :D
285Andy
Postby rob pace on Wed Jun 17, 2009 3:37 pm
285Andy :
rob pace :
im going back to full non-ABS from the factory with all the correct lines that i aqquired, havent taken anything off yet, need to get the car on a ramp ideally to change all the rears and remove the abs. was going to use my mates ramp but hes left the garage he worked for :oops: :oops:
rob pace
Postby XR2i16pfau on Wed Jun 17, 2009 4:12 pm
great car mate! looks very clean!
-Sorry for my bad english...-
my old project: german-frst-project-vt159744/?hilit=xr2i16pfau
my new project: moonstone 3dr cossi...
XR2i16pfau
Your car: Cossi 3dr
Postby Ram on Wed Jun 17, 2009 9:35 pm
arches look great :Q
did you treat and paint them yourself previously or they still factory?
wanna strip back and paint mine this winter as it looks awsome peeping through behind the wheels :Q
Ram
Postby rob pace on Thu Jun 18, 2009 1:27 pm
Ram :arches look great :Q
its all factory mate :) car is never driven in rain so the tin worn wont attack :)
rob pace
Postby knuckles on Sat Jun 20, 2009 1:35 pm
about time you went back to standard alloys :D
p.s - whats the use by date on that ford spray paint you got off ebay ? :bonkers:
knuckles
Your car: Fiesta Rs turbo
Postby rob pace on Sat Jun 20, 2009 3:40 pm
knuckles :about time you went back to standard alloys :D
not sure mate, i wanted it for my front arch scratch but its a bit too dark as i tested some! :( i might go back to standard alloys, but i want to get some genunine suspension but thats going to burn a hole in my pocket :lol:
can i ask where does that fuel sticker go you had? and the ok for shipment sticker? (think it goes on cam cover?) :)
rob pace
Postby knuckles on Mon Jun 22, 2009 1:53 am
the fuel sticker believe it or not goes on the inside of the mk3.5 fuel flap.
the ok for shipment sticker goes ontop of the cam belt cover.
have a look at a few concours bay pics to confirm exact places or even catalogue pics
knuckles
Postby ooral on Fri Jun 26, 2009 7:39 pm
Just read through this, 'stunning condition' looks as though its only going to get better as well!
Well [ERRR]!
ZT now gone, driving a 330ci.....
ooral
