2 Ltr Conversion - Parts List
Postby grandman on Mon Apr 27, 2015 9:17 am
Hi all, I know some of you may think I'm a nuisance, and; every time I post this I disappear. well it was work, but now I'm permanently in UK, so I shan't be disappearing anymore, just to refresh any memories this is a list of the parts I think, I need, to complete a conversion on my little 1.3 HCS to a 2 ltr Zerec:
A. Radiator
B. Radiator Mounting Brackets
C. Radiator Hoses All
D. Radiator Cooling Fan
E. Fan Mounting Brackets
F. Thermostat
G. Thermostat Housing
H. Strut Brace
I. Engine
J. Clutch
K. Gear Box
L. Drive Shafts
M. Hubs
N. Front Brakes
O. Hand brake and cable
P. Engine Mounts
Q. gear Box Mounts
R. Inlet Manifold
S. Outlet Manifold
T. Throttle Body
U. Fuel Rail
V. Injectors and any other parts related to fuel supply.
W. Exhaust and all fittings and gaskets
X. Suspension
Y. Steering Column
z. Steering Rack
1. Starting Motor
2 alternator
3 Power Steering Pump
4. Fuel pump and sender
5. Any and All Vac Pipes, and Air Boxes bolts and nuts
6. Car Loom
7. Engine Loom
8. Fuse Box
9. Fuses and relays
10. All sensors
11. All Belts and cams
12. Air Filter
14. ECU
15. Ignition Barrel plus Pats
16. Ignition Key's
17. All locks and Keys
18. P.A.T.S ECU
19. Central Locking and Alarm ECU
20. Any Other ECUs
if you can help please contact me,
I would really like to drive this little car sometime :(
All these from a ZETEC 2 ltr MK3. Or that, which will allow me to build my own 2 ltr conversion. I have looked at the guides, and not sure I could build my own 2 ltr engine.
Regards Dave
grandman
Re: 2 Ltr Conversion - Parts List
Postby Tweek on Mon Apr 27, 2015 6:42 pm
I have a HO inlet manifold, fuel rail with injectors (also possibly a radiator fan) if that's any good?
£65 posted for the lot
Pretty sure I have a standard downpipe with catalytic converter lying around in the shed too if required.
Your car: VW Golf GTD
Postby grandman on Mon Apr 27, 2015 8:52 pm
Tweek :I have a HO inlet manifold, fuel rail with injectors (also possibly a radiator fan) if that's any good?
Thank you, but I'm really looking to try and get as much, as possible from one source. But will get back to you.. Anyone on here have a large collection of parts?
grandman
Postby AW3K on Sat May 09, 2015 10:41 pm
I have fiesta si full car loom and all engine loom. Deep ecu full lock set with pats key and pats ecu both engine mounts. Gearbox to block sandwich plate. Radiator full water hose set.
Also have a full 1.8 engine with 2.0l cams throttle body maf etc 99% ready to drop in.
AW3K
Postby grandman on Tue May 12, 2015 6:09 pm
AW3K :I have fiesta si full car loom and all engine loom. Deep ecu full lock set with pats key and pats ecu both engine mounts. Gearbox to block sandwich plate. Radiator full water hose set.
Just to let you know I've received your message, not sure I understand what's on offer. What are we talking about? I'm really looking to get as close to 140 bhp as possible, were would this put me, and what else would I need to find to complete this build.. Please reply thank you...
D)
grandman
