2.0 Engine now in but .......
53 posts • Page 1 of 2 • 1, 2
i went to start it for the 1st time and...... POW it fired up ( turned over about 6 times )
lol
i havent changed the ECU yet it was running with the 1.8 ( being changed today )
anyway the problem i have is, it was reving it self up ( like i stared it with foot flat on floor ) but i wasent
could this be because of the 1.8 ecu or somthing else ?
i checked the TPS / MAF / All TB cables, plugs , Ect and it still done it ...
im hoping it might just be the ecu but wanted to ask you guys before i go out and get all dirty
- Xr2i_2.0L_16v
If you used the mondeo tb you might just want to check that its not sticking open, or that it can close properly. Just a complet guess really!
- lucasdemoley
yeh its the 2.0 tb on there .....
it seems ALL perfectly ok....
gimmie 30mins im going to change ecu's over
ill let you know ifit worked or not if not i need some advice llama
Cheer's mate
Cheer's mate
- Xr2i_2.0L_16v
- Sunil_FiestaRS_16V
ok peeps i put ecu on and nothing ..........
car will only start with 1800 ecu ( NEON )
it runs fine with it ? lol how weird
anyway i got it going all ticking over and bang the thermostat house cracked
im doing that in a min after bit of lunch
Weird how it will only run on the 1.8 ecu innit
- Xr2i_2.0L_16v
but surly a 2.0 would work better with a 2.0 ecu ( DEEP is what i got )
it wont even spark with the DEEP
with the NEON 1.8 ifts fine but ticks over abit low that could be 101 things tho ...
still not sure why that thermostat housing cracked .... hoppfuly it was just knackerd and not somthing else making it crack
Ps reving problem now ok,
The Tb was open ( forgot a spring )
sorted now ... execpt that thermostat GRRRRRRRR
Fast tho aint they LOL i took it up rd havent smiled like that for ages hahaha
- Xr2i_2.0L_16v
ok mate fair dooz,
ya think it will all be ok if i left the NEON on there .. or should i get another 2.0 ecu ?
- Xr2i_2.0L_16v
Xr2i_2.0L_16v :ok mate fair dooz,
it will run it but i change to a working DEEP or similiar soon, as the map will be wrong for your car. I ran mine on a 1.6 GURU till i sourced the DEEP
well i changed the thermostat all running ok ,,
seems like it got hot fast but havent really drove it yet ( no insurance )
but whem i get my insurance changed back i can test it out properly,
Thanks for your help guys ...
Ps any one got a WORKING 2.0 ecu for sale
lol
- Xr2i_2.0L_16v
2 ltr con
sounds like air leak. was your car 1800 zetec before 2ltr con.could be something do with loom mate did you replace loom or do any pin changes before you put 2 ltr ecu on.
- JACK THE LAD
the air leak sorted now but thanks anyway ,
and yes it used to be a 1.8 zetec and i never touched the loom or any pin changes
somthing might of been done b4 i owned it but i doubt it ,
- Xr2i_2.0L_16v
2 ltr
check your loom mate before you use 2ltr ecu .i ran mine on 1800 loom mate wouldnt run right.so i sorted loom and put 2 ltr ecu on and i can honestly say it goes like s**t off a shovel. well chuffedXr2i_2.0L_16v :the air leak sorted now but thanks anyway ,
- JACK THE LAD
Re: 2 ltr
the loom is different for 2ltr mate if it hasnt been changed and you thinking of doing it good luck. i had problems doing my loom.but with a lot of help off here i sorted it . so if you want the pin changes for this let me no i have themJACK THE LAD :check your loom mate before you use 2ltr ecu .i ran mine on 1800 loom mate wouldnt run right.so i sorted loom and put 2 ltr ecu on and i can honestly say it goes like poo off a shovel. well chuffedXr2i_2.0L_16v :the air leak sorted now but thanks anyway ,
- JACK THE LAD
i'm assuming your car is an Xr2i 16v???
if so then your loom for the 1.8 engine will have external EDIS plumbed in, you'll need to remove that part, the ECU controls the EDIS internally on the 'DE' prefix ECU's
JJ
JJ
Is that the best you can do?
- jdfiesta
- Your car: V70 T5
lol now im confussed :S
<<<< no good with eletric's
and yes please guys .. it does need doing so any help would be greatfull ,
cause im not sure ifits the ecu but the car ticks over for about 5 minz then will just cut out .... its nothing realy but its not right
so yes any pin changes / anythin that needs chagein please let me know as like i said it will need doing
Thanks in advance
Thanks in advance
- Xr2i_2.0L_16v
like stated, if your car is the 16v xr2i then it will probably be controlled with an external edis ecu, all mondeo ecus are internal edis so to make it work you will neeb to change the wiring loom for an internal edis before the mondeo 2ltr ecu will work. a loom from a Nreg fiesta si will work i think as its internal edis. hope this helps
- benks_si
someone said something about pins changes ?
whats eaiser loom change or pins change or keep the 1.8 ecu lol
i see on some guide about the bank of wires (:::::::) look like that behind EFI inlet need chaging about ...
is this what i need to do or was that something else ?
sorry for being abit blonde but its confusing the fook outa me
- Xr2i_2.0L_16v
dont really think changing the pins will make a difference, end of the day you have an external edis wiring loom and an internal edis ecu, it wont work. really think you need to change the loom if you want the mondeo ecu.
- benks_si
2 ltr con
the easiest way is using the si loom i couldnt get old of 1 so i used 1800 loom yeh it was a pain . but with help from sailorbob we sorted it. took me along time to get my head around it .but its running nice now.if i was you go for the 1600 si loom.but if you want to stick with your 1800 loom i will try and sort you the pin outs ..
- JACK THE LAD
yeh would really prefer to keep the 1.8 loom as its in and all ok
but yeh mate if you could that would be a GREAT help !!!
- Xr2i_2.0L_16v
no, what will that do ?
i mean whats the reason behind doing that.
sorry man im just new to All this new electrical stuff
lol
but its the way forward so i gotta lern somewhere lol ( trial n error innit )
- Xr2i_2.0L_16v
The thinking behind it was that if the 2 litre ecu uses internal edis and the xr2i uses external then by unplugging the edis module on the bulkhead and using the 2litre ecu with internal edis it might work.
Its just an idea though but id be interested to know if it works?
- paradox
2 ltr con
hi mate write these down i cant find the pin outs at moment dont no what ive done with them. the eddis wires you DONT USE are 3 4 8 9 .number 7 goes to 40 or 60 of ecu. 58 inj 1 move to 51. 59 inj 2 move to 52. bear with me on the others mate. but dont attempt till you got them all.
- JACK THE LAD
Hi mate, if your car isnt running with the 2.0 ecu, have you checked to see if it needs the PAT system, you know the key with the chip in it, will stop the car from sparking. To bypass this you need to add 4 pins to your ecu connector and you need a pin out data book cause cant remember what pin numbers it was. Cheers.
- fiestaescort
