Fiesta zetec turbo - now for sale!
hey all, most of you already know the car, i got it near end of last year. just cleaned and polished it so thought id take some good pics and start a thread on it as ill be changing some bits here and there.
my plans so far are orignal wing mirrors, differant seats as the ones in it weight a tonne, roll cage, GT25 turbo and some management.
car just now has t2, low comp bottom end, stage 3 head i was told, grs cooler, alloy rad, avo coilovers, cosworth front and rear discs, adjustable bottom arms and cosworth wheels.
suspension is solid and is a seriously rought drive if road isnt flat, which up in aberdeen is never!
fitting the turbo is what am working on just now, need to modify a t3 manifold with a t25 flange, making a elbow for turbo, sorting oil feed/return and some water pipes. also new oil and filter
got all the bits just putting them together. will get pictures of it all tomorrow.
- cowie20
Re: My Fiesta Turbo
I remember this car
how can you forget it with them wheels and intercooler
look foward to seeing how you spice it up even more
as totally agree on them wing mirrors lol
Cruisers dont die they just keep cruisin
- CrAzY kAyLL
Re: My Fiesta Turbo
my all time fave how you findin the seats comfy? whats the drive like on the alloys?
any planns for mods in the future?
also whats the dump walve? it looks fukin huge haha
Phil.
Phil.
- Philie*RST
Re: My Fiesta Turbo
haha just read the thread again and you anserd the Qs i asked
lol should have read it before skippin to pictures
pm me a price on the seats mate if you want rid
- Philie*RST
Re: My Fiesta Turbo
I love this car, was very tempted hwen i saw it on ebay
Coilovers and cage wanted
XR2i track car in the making.
- crazyshad1
Re: My Fiesta Turbo
hi mate what you doing to the turbo??.. as far as remember its a hybrid t2 on there...
- FRSJON
Re: My Fiesta Turbo
I do love mk3's on cossie rims *drool*. Good news about the wing mirrors. Any plans to change the steering wheel?
- Makaveli
Re: My Fiesta Turbo
spot on mate, think the cossie rims suit FRST down to a tee!
agree with changing the mirrors, id probably go for the Mk3.5 mirrors over the the orginal elephant ears though, other then that I think it looks top.
Rusey
Rusey
- Rusey
Re: My Fiesta Turbo
the seals have started to go on turbo and i wanted to change it. i bouhgt a GT2554r from garrett. so am making it it fit just now but am away offshore on friday so it wont go on for another 3 weeks.
mk3.5 wing mirrors is more than likly what will go on. and yes the steering wheel is being taken off soon as i find a replacement i like. car needs a new steering lock as its broken.
cheers for comments
cheers for comments
- cowie20
Re: My Fiesta Turbo, building up GT25!
right, got all the bits i needed at last from garrett, got a flange to weld onto t3 manifold, once welded had to smooth down edges of hole as the hole is smaller than the t3 hole. made up a exhaust elbow with a lamda sensor plug for management later on.
the exhaust housing on turbo had to be spun round to be same way as a t3, had to modify a bracket for actuator to be mounted.
i also bought a oil return kit from garret which came with a nice thick bit of oil hose. should do trick nicely
the water pipes from t2 fit onto the gt25 but the oil feed wont fit, so i have a adaptor to go into the turbo then using a t3 braided oil feed pipe.
here is some pictures of it all together.
am not offshore till next week so am going to get it fitted on satuarday. just wandering if ill get away with setting boost same as hybrid t2 which is 15psi.
i will take it to tuner once i find one i like.
- cowie20
Re: My Fiesta Turbo, build up gt25 !!
i love that car it is from hull were i live i wanted it lol.
- stembo21
Re: My Fiesta Turbo, built up gt25 !!
got the turbo fitted to car, took two days, its not totally finished, got exhaust leaks at down pipe and where downpipe meets exhaust, also oil return has a slight leak, but to get to pipe i have to remove starter and downpipe! to tired to do it.join between downpipe and exhaust is a temp thing as it was all i had
had to remove intercooler and rad and move rad as far forward as it would come, original t2 oil feed was relocated to come over the gearbox and bolted onto new turbo, t2 water hoses fitted onto it also, well once a bit of careful heat and some gentle bending and shaping.
car now doesnt smoke except from heat paint on manifold and some greasy oily hand prints all over exhaust and turbo!
car seems to idle better and got better oil pressure used to sit at 60psi from start up cold, now its 70psi. maybe due to oil/filter change. unsure
turbo has a really loud on spool up, sounds like a jet. going to drive easy for a few days, break turbo in gentle!
- cowie20
- FRSJON
Re: My Fiesta Turbo, GT25 FITTED!!!
class car mate
what would be the price on the seats?
- andymcd
not sure mate, not had them out the car yet to see if there heavy.
- cowie20
nice one mate aint seen this going around aberdeen yet, car looks really good, hope my one looks as good once its finnished
turbo restoration in progress
painted, interior half in, windows in let the rebuild continue
http://www.fiestaturbo.com/forums/post1715280/#p1715280
http://www.kinghorn1.wordpress.com
- KINGHORN
Love the look of this car
dontpannic :Mikey B knows as much about directions as a chinchilla knows about tapdancing!
- M1K3Y_B
Car: 1996 Ford Fiesta Classic
its been going around aberdeen for about 3 months mate. spends most it time in garage.hahah
- cowie20
LOL MINE aint seen a road in 5/6 years, haha
looks seriously good mate, you dont by any chance have a grey one to do u
- KINGHORN
not a grey one, got a black one. mate has a grey one with cosworth wheels but its in bits just now. 5/6 years......thats a fair bit of time!!!
- cowie20
there is anothe red one going round town, with cossie rims and im sure its a chick that owns it and she used to have a grey one, and have been told she still does, just thought it was maybe same car,
yeah i have owned it just over 2 years, the car was taken off the road so someone could build a 2.0 zvh for it and it never run lol,
i bought it without loking at it being told it was mint, never even tried to get the engine running just took it out and fitted a 1.6 turbo with a few bits n pieces, then decided to tidy it up, removed body kit and spotted th dreded rot, and kept finding it everywhere, almost reshelled but all welding is now finished and it will be pained in a few weeks, the will get it all fitted up, still got a few bits to source, but gettin there
- KINGHORN
you sure its not my car, as my girlfriend drives my car (red) when am offshore then when onshore she drives the black one. i aint seen any other fiesta going about with cosworth wheels.
nice one that you restored it, were fixing up a xrv van just now. taking its time but getting there
- cowie20
no defo a grey one the one with the cossie rims was in dundee before it came up here, think she stays in stony, my bird said she would drive the rs when its finnished, lol i just laughed at her, spent to much time money and effort to let a chick break it, hehe
- KINGHORN
i love this car when i first saw it i was in ireland and i wanted it but i couldnt have it so i built my own its not finished yet but its not far off
- stevo™
top work mate, you did a good job making it the same. id rather have yours as you have better wing mirrors.
did you cut the the bumper for intercooler as neat as the one on mine. its the neatest ive seen.
- cowie20
think i have a set of 3.5 mirrors kicking about somewhere mate, yours for a small fee if i can find em
- KINGHORN
lol na its not very neat im not to bothered tho s the bumper wernt brilliant to start with. my engine spec isnt as good as yours yet iv got beiges a hybrid t3 and a chip and cam next is low comp bottom end and stage 3 head
- stevo™
im thinking about taking it to yano to get cossie managment what are you gona go for?
are you going to ford fair would be good to see it there possibley get a pic of the 2 together
- stevo™
where is ford fair mate, i stay in aberdeen and all these things are usually miles away from me. would be pretty cool getting a pic of them together.
i aint got a clue what am going to go for, was going to go for gotech but tuners near me dont touch it. i wouldnt mind cosworth management. maybe going to go for emerald
- cowie20
LOL NO ONE Up here touches anything mate unless they are a dealer for it.
- KINGHORN
spot on mate.
when you had a good drive in it let me kow what performance is like turbo wise compaired to the T2 as i did think about a T25 for my rs not long ago, and im still thinking of it
ive done 50 miles so far and been taking it easy the actuator on turbo is only a 8 psi garrett one, but am in middle of getting a -31 to get boost up to a bar as thats where t2 was sitting at. car is hopeless in the rain, just spins even if you try be gentle, paddle clutch a pain!
jay, you said the seal that had gone in my t2 was a cold seal? is that the big o ring seal that seals the compressor housing to the body of turbo?
- cowie20
