Megasquirt ECU Fitted!Throttle Bodies Running!New Head!!PG10
Postby Asad on Fri Apr 29, 2005 12:50 am
Can you guess what it is?
Clue in my sig!
Asad
Postby andyhardy on Fri Apr 29, 2005 1:00 am
Your megasquirt ECU kit - hope you have a steady hand and a decent soldering iron!
For those that don't know what this megasquirt business is all about - read up on it here:
Megasquirt website llama - wrong website to begin with! :aaah: (google megasquirt and see what comes up!)
I think this would interest alot of people who have carried out 2.0 Zetec conversions and were having problems with choosing a good value for money ECU setup :)
Keep us updated with the project mate :)
Postby EvilDes on Fri Apr 29, 2005 1:07 am
That site has confused me somewhat, speaking of boats, and the like :)
What exactly does it do and how would it help a 2.0 setup? Benefits, disadvantages?
Cheers :D
****Man, that's really f**king orangy!****
EvilDes
Postby andyhardy on Fri Apr 29, 2005 1:15 am
EvilDes :That site has confused me somewhat, speaking of boats, and the like :)
Cheers :D
Basically it's an aftermarket ECU system that is bought part constructed. The design is public domain (open source) meaning that you can use it without paying any licence fees.
It includes interfacing software for plugging a laptop into it allowing you to map the car yourself (this is something you will have to take some time over to learn) and also to monitor engine data in real time and also data-log your ECU readouts meaning that you can optimise the engine and fault-find alot easier than with using say something like the standard EEC-IV setup (which comes without OBD2 diagnostics or better).
Sorry - I'll have to make a glossary up for posts like that I think!
For more information on the system itself read the introduction to the manual here:
Megasquirt manual introduction
I'm not saying this is the ultimate ECU or anything, it isn't, but it's very very good value for money if you are experienced with electronics and soldering whilst having a keen interest in learning how ECU's work etc.
You may well need someone with fuel injection experience to help setup the car initially but I believe alot of the rudimentary stuff is explained within the construction/installation manual.
Postby mike_wall15 on Fri Apr 29, 2005 1:43 am
Ok, now the important bit, how much bhp will it add?
mike_wall15
Postby andyhardy on Fri Apr 29, 2005 1:53 am
mike_wall15 :Ok, now the important bit, how much bhp will it add?
Dunno - depends what you've done to the engine and the condition of the engine itself.
It's all very well adding bolt on bits to a standard engine with standard management but there comes a point when the standard ECU will restrict you - remember that the ECU is set for economy as well as performance so there is always more that can be had out of them, a fully mappable ECU wins over a Superchip hands down ;)
So basically - the bhp increase will depend on the mods you do (cam durations, throttle body size, injectors) :)
An extra point to note - this system will not be for someone with no electronics or computer experience, it's a DIY kit for enthusiasts who want to learn more. The performance enhancements you can make with it will depend on how skillful you get and how much effort you put in :)
Postby Asad on Fri Apr 29, 2005 1:56 am
Read up on it much andy? :D
Yeah basically an ECU.
Im planning on connecting it to my loom and retaining the original ford ECU plug. As it is compatible with EDIS, I want to be able to swap between standard and the megasquirt.
I will hopefully be using a rolling road for setup, and as andy says, i can use a laptop.
http://www.mez.co.uk/megasquirt.html
I work with this guy and he is using it to run a twin turbo V8 so I will be picking his brains.
Beauty of this ECU is you can control all aspects, from target fuel ratio, to how much you want it to idle during warm up.
It has two injector drivers, so you could run fuel on 1 and water on the other. It has a built in map sensor for turbos as well. Plus the fact you can reprogram it over 10,000 times.
Should be interesting to learn and get it working.
As for BHP, i think it should work along the lines of a superchip, ie better mapping of the ECU to the engine. Plus, it only cost me £140 which i think is around the same for a superchip.
Really dont know how much to expect.... maybe 150bhp?
We'll have to see!
Asad
Postby andyhardy on Fri Apr 29, 2005 2:00 am
Yeah - I was reading through the manual and noticed the vacuum hose going into the ECU box itself, neat idea that 'internal MAP sensor' :D
Ok mate - I'd say get a 4-2-1 manifold, bigger throttle body and better inlet manifold and suitably specced injectors and then map it all up. You'll see 160bhp easily - oh and don't forget to get different cams.
With the standard engine and ancillaries you should get in the high 140s to 150 bhp - call that my prediction :)
Of course - if you have a carputer you could interface with that instead of a laptop ;)
Postby mike_wall15 on Fri Apr 29, 2005 2:09 am
:lol: Sorry Andy, my question was of humour, I should have worded it better...
Not bad for £140, is that a price for anyone or did you get it on a discount? :wink:
Get yourself a Focus ST170 Inlet manifold :wink: :Q
mike_wall15
Postby PaulC on Fri Apr 29, 2005 8:57 am
Let us know how you get on Asad, looks like myself and MMo will be building one sometime soon :D
Postby Asad on Fri Apr 29, 2005 9:08 am
Will definitely keep you updated! Hopefully it should be in one piece and running off a stimulator in a week!
Andy - at the moment I have a full exhaust and air filter. I doubt I will get much more, but my thinking was it would be useful if I was to turbo later on :)
Saying that, I am keeping my eye on some throttle bodies....
As for the carputer, I've already thought about it and spec'd up one! Would be great to have a live readout of what the engine is doing as im driving! Not to mention on the fly adjustments! We'll have to see!
Mike - That price is for the kit and is for anyone. I think its £190 assembled. Then you can start adding other stuff like the Megaview, which outputs to a small display which you can mount in your car.
PaulC - Sounds good! we could swap maps/ideas! Where you getting yours from?
Asad
Asad
Postby Ollybee on Fri Apr 29, 2005 10:28 am
I wouldn't mind doing this myself. FiestaZetecE has one of these and he really rates them.
Ollybee
Postby PaulC on Fri Apr 29, 2005 10:37 am
Asad, its nothing definate yet, just an idea I threw at MMo for just latest venture ;)
Postby FezzR on Fri Apr 29, 2005 10:38 am
an aftermarket ecu will not "gain" you any power,
you can only "reclaim" power that your loosing from not having optimal fueling and ignition settings
you would be far better remapping the Ford EEC in my view, but you have major issues of knowledge and budget to contend with then (of which i have niether :aviator: )
megasquirt has always interested me and i would have "fettled" with it long ago if i had the fund, present situation £150 is a lot of money :cry:
FezzR
God Damn Lazy
God Damn Lazy
Postby Al on Fri Apr 29, 2005 1:25 pm
andyhardy :Of course - if you have a carputer you could interface with that instead of a laptop ;)
That would be quality!
Postby Percy! on Fri Apr 29, 2005 1:34 pm
This looks like it could be fun.
May have a look into one for mine as it needs a setup with the cams I have.
Percy!
Your car: Citreon
Postby Asad on Fri Apr 29, 2005 1:57 pm
Heres a screenshot of the programming/display software....
Imagine that on a carputer? :D
Good thing about these are the upgrades that you can do at any time.
You can add traction control (very basic), throttle change, boost control, water injection control, NOS control etc. Most just with firmware upgrade, some hardware.
It's gonna be interesting to learn! cant wait to get stuck in!
Asad
Asad
Postby DaveZetec on Fri Apr 29, 2005 2:16 pm
I've always been interested in these, whereabouts did you get the kit?
I might build one for the sack, for a summer project :)
Dave
DaveZetec
Postby Asad on Wed May 04, 2005 11:21 pm
Small update -
I started on building it today!
Got the connectors on and a few diodes, caps and resistors. Will continue tomorrow and hopefully test the power.
Looking to have it done by the end of the week!
More updates soon!
Dave> I bought it from this site :-
http://www.americanv8engines.co.uk
I think he has some stock, but if you planning on doing it later, you might as well wait for the new pcb and Megasquirt II
Asad
Asad
Postby Zetecfiesta on Wed May 04, 2005 11:38 pm
ive seen megasquirt before, it is quite good. a lad called MarkXR2-40 has it on his 2.0 mk2 fez, he was setting it up last year at the fordsport weekender,it looked so complicated but after a while of messing with it you should have seen his car go! it started not even idleing and by the end was running nearly spot on! he set it up with another lad and they got carried away setting it up on the road and ended up driving to miltonkeynes! it looks too complecated for me!
Zetecfiesta
Postby Excursion on Wed May 04, 2005 11:59 pm
Good on you Asad, that is something which I would very much enjoy doing if I had the time! Fantastic project.
Can you do me a favour and let me know if you have any joy sourcing ford EECIV multiplugs. I would like a few myself.
Cheers!
Mark
Postby DaveZetec on Thu May 05, 2005 12:08 am
Excursion :Good on you Asad, that is something which I would very much enjoy doing if I had the time! Fantastic project.
Cheers!
Mark
What about baxtered them off cheap scrappy ECUs?
DaveZetec
Postby Excursion on Thu May 05, 2005 12:15 am
DaveZetec :
Cheers!
Mark
I want brand new mate. The pins are single use only anyway ;)
Postby DaveZetec on Thu May 05, 2005 12:22 am
Excursion :
DaveZetec :
Cheers!
Mark
Bah, you got no sense of adventure! Go on, live a little - three hours and a knackered solder sucker later could see you earning your wicked way with one of them
DaveZetec
Postby Asad on Thu May 05, 2005 7:41 pm
Cheers!
Mark
Cheers mate. I was thinking along the lines of getting a dead ECU and taking it from there!
Heres an update:-
Power supply circuit is done
And the Volatge regulator, at the top:-
And finally the Serial port circuit, left hand side:-
I will be using a stim to test the circuits tomorrow, and more soldering!
Asad
Asad
Postby Asad on Thu May 05, 2005 7:42 pm
And before anyone says "is that all...." only got and hour at lunch to do it and no stim to check my progress!
:bonkers:
Asad
Postby MotorcyclesFish on Thu May 05, 2005 7:51 pm
Very impressed mate, v. interested as well. How many injectors can it handle? I'd be interested even more if it can handle 8. :)
MotorcyclesFish
Your car: 2004 Z4 3.0i SE
Car: 1984 Ford Capri
Postby Asad on Thu May 05, 2005 7:57 pm
Asad
Postby Asad on Fri May 06, 2005 6:25 pm
Another update!
I got the stimulator today, so got a chance to test my progress so far.
Power to chip is fine. Tested the Serial connection with Hyperterminal and that worked fine too!
Here is a close up of the stim:-
You can see the pentos', each representing a different sensor. TPS, HEGO etc.
I got my own iron now so I will be cracking on with it tonight and tomorrow.
Asad
Asad
Postby Ruishy1 on Fri May 06, 2005 6:53 pm
very cool matey :D guy i work with is building an RS500 rep with cossie v6 engine and 4 wheel drive. and running it all on megasquirt.
Keep everyone updated :D
Ruishy1
Postby Asad on Fri May 06, 2005 10:46 pm
Another update.
Fitted the CPU:-
Been soldering away, and testing step by step:-
And here is me testing the sensor circuit:-
Now all the sensors on the Stim produce an output! RPM, water temp, all working!
Asad
Postby heeman10 on Fri May 06, 2005 10:51 pm
Cool thread, good progress! :D
Postby FezzR on Fri May 06, 2005 11:14 pm
good to see quick progress :D
only thing that puts me off about megasquirt still is the one thing that everyone loves about it! the simplicity
oh well hopefully in a few months ill have different solution for half the price and twice the intellagence :devil:
keep the updates coming
FezzR
God Damn Lazy
God Damn Lazy
Postby Asad on Sat May 07, 2005 1:25 am
What you getting then? Whats it do?
Im almost finished....
Most components in place:-
This is the MAP sensor:-
Just LEDs and a couple of FETs to go!
Asad
Asad
Postby andyhardy on Sat May 07, 2005 1:31 am
Great stuff mate - very quick progress!
