fiesta turbo ecu wireing???????????? NEEDED ASAP FOR 2MORRA!
19 posts • Page 1 of 1
im now converting a mk5 escort van 2 fiesta turbo running gear & have a complete running package.
my problem is: how do i do the wireing??????
i am runing OFAB ecu & have complete engine loom.
i know its just a case of useing 3-4 wires from the engine loom & tap them into my old loom but can sum1 tell me what colour wires need 2 go where????????
- lockie
samantha :red - +batt, black - ign, brown - earth, green - rev/count, blk/green - f/pump, brn/green - oil press, this is what i would THINK anyway, somone may confirm
red----------------- constant 12v live
black--------------- inginition??????????? (what do u mean ignition? live?? earth?)
brown---------------earth
green---------------rev counter
black/green--------fuel pump??? (direct 2 fuel pump?) what about relay?
brown/grenn-------oil pressure (is this to light on dash clocks?) carnt i use the original van wire?
sorry for all the questions but want to be 100% clear on this as only want to do it once! lol
- lockie
I HAVE LOOKED AT THE PLUG & CAN SEE THE WIRES NEEDED BUT IM NOT SURE ON WHERE THESE WIRES GO????????
2X BROWNS?????
BLACK/GREEN??????? direct to fuel pump?????? to fuel pump relay???????
needed for 2moora if any1 can help?
i know the chap above says browns are earths but on other link ive been sent it says there for:
fuel pump relay?
ecu currant return????
can any1 help?
2X BROWNS?????
fuel pump relay?
can any1 help?
- lockie
PIN 1 - Blank
PIN 2 - RED - Power
PIN 3 - BR/GR - Oil pressure, no need to use this
PIN 4 - BLK / GR - ??? - comes from PIN 4 on the E-DIS module
PIN 5 - BR - Current return
PIN 6 - GR - ??? - comes from PIN 1 on the dissy pack, PIN 3 on E-DIS
PIN 7 - BR - Fuel pump relay
PIN 8 - BLK - ??? - comes from PIN 2 on dissy pack
PIN 6 (GR) does sound like a sensible choice for the rev counter, as for the other 2...i've no idea. Gonna do some searchin today, ill post up results if i get anywheres...
- an1mal_69
:devil: here we go...dunno if you've had this already..?? Check Series2...then EFi conversion..
http://www.rsbible.co.uk/
- an1mal_69
yes had that mate.
can sum1 tell me where the 2x brown wores go????? (earths???)
also where the black/green wire goes?????/ (is this 2 the fuel pump relay?) if so what colour on thge fuel pump relay? (im useing an escvort fuel relay)
- lockie
PIN 1 - Blank
PIN 2 - RED - Power (constant 12V)
PIN 3 - BR/GR - Oil pressure (no need to use this)
PIN 4 - BLK / GR - Fuel Injector Relay
PIN 5 - BR - Current Return (earth)
PIN 6 - GR - Rev Counter
PIN 7 - BR - Fuel Pump Relay
PIN 8 - BLK - Ignition Live
As for the relays...looks like you connect to No87 on the injector relay, & No85 on the fuel pump relay...not 100% on that tho.
Let us know how you get on...
- an1mal_69
van is all done but no spark???????????
must be this ecu wireing crap??????
i have:
red on live
black on ignition live
both browns 2 earth
green/brown to oil pressure light on dash
i havent wired up the green 2 the rev counter yet as havent got a set of efi clocks at the min!
also i havent wired up the black/green wire???????
i have:
red on live
both browns 2 earth
- lockie
an1mal_69 :is that a good thing..lol..
Yeah, its my site mate! Good to see its getting some good use.
lockesRSparts :van is all done but no spark???????????
i have:
red on live
both browns 2 earth
You got any pictures?
What engine loom are you using?
Do you have matching sensors & ecu?
What type of loom is in the van?
- Captain Tightpants
- an1mal_69
van is all done & up & running!!!!!!!!!!
incase any1 wants 2 know
RED---------------------------+12V LIVE
2XBROWNS-------------------EARTHS
BLACK------------------------IGNITION LIVE
BLACK/GREEN----------------IGNITION LIVE
GREEN-------------------------REV COUNTER
BROWM/GREEN---------------OIL PRESSURE LIGHT ON DASH
if any1 wants 2 see pics of the van & conversion then just ask?
- lockie
ive put fuel pump on ignition live untill i work out how 2 wire up a seperate fuel relay!
in total its taken use 14 hours 2 fully convert the van from 1.8 diesel to full on fiesta turbo (includeing petrol tank & exhaust)
- lockie
.jpg)
