2.0 MAF Sensor
2.0 MAF Sensor
Postby SWRT on Fri Feb 18, 2005 5:05 pm
If i changed my 1.6 si MAF sensor to a 2.0 one what would be gained/lost from doing this if anything.
Cheers :wink:
SWRT
Postby Si16_valve on Sat Feb 19, 2005 10:56 pm
put a 2.0 throttle body and maf sensor on my Si and its fast as f**k now. u get crap m.p.g. but its worth it :devil: . My mate done it to his 1.6 mondeo and he said when he got it on the rolling road it had 110 bhp. I believe him.
:Q Si_16valve :Q
Si16_valve
Postby Syorme on Sun Feb 20, 2005 12:49 pm
whats the maf sensor
Syorme
Postby SWRT on Sun Feb 20, 2005 1:56 pm
Mass Air Flow mate . Its the block that is on the induction pipe with air flow and a arrow on it. :wink:
SWRT
Postby Syorme on Sun Feb 20, 2005 3:34 pm
Would a RS1800 MAF sensor work or would it be better getting 2,0ltr sensor
Syorme
Postby Si16_valve on Sun Feb 20, 2005 6:51 pm
dont know mate. probably do the same but just not as well as the 2.0. sensor
Si16_valve
Postby sailorbob on Sun Feb 27, 2005 9:39 pm
A word of caution, the eec has a calibration table matched to the MAF. If you changed the MAF without changing the calibration to suit you will get wrong fuelling because the ecu no longer knows the correct amount of air going in and cannot calculate injector pulsewidth correctly.
sailorbob
2.0 throttle and maf sensor
Postby Si16_valve on Sun Feb 27, 2005 10:33 pm
When changing the 1.6 throttle and maf sensor to 2.0 ones nothing happens for the first 7 or 8 miles. in this time the ecu gets used to the new air/fuel rato and resets itself. anyway all this does is makes it run lean and when the lambda sensor detects this it whacks more fuel in.
:Q Si16_valve :Q
Si16_valve
Postby krsi on Mon Feb 28, 2005 11:03 am
I tried a brand new RS1800 MAF sensor on my 1.6 16v Si and all it does is coughs and splatters and usually stalls.
HTH :)
krsi
Postby sailorbob on Mon Feb 28, 2005 12:13 pm
What Si16_valve says is fine for idle, where the closed loop operation compensates for the misread airflow, but in open loop mode the fuel calculation is not using HEGO feedback. Some of the closed loop info is used in the open loop calculation but it only caters for mild discrepancies and I still would err on the side of caution.
This all said, theres nothing to stop you doing a chip for the car to tell it the new MAF size if you have the calibration data.
I'd like to see 'before and after' wideband ego sensor data if someone has done this conversion and checked it. It would be nice to know how adaptive the eec is.
sailorbob
Postby jdfiesta on Thu Mar 17, 2005 1:51 am
2ltr MAF sensor
unplug it.
simple as just runs on base map, it wont blow itself to bits, lambda takes care of it
mine runs fine with it unplugged, pulls like a train and seems a little louder on the induction side of things
Postby jdfiesta on Thu Mar 17, 2005 1:53 am
or you could just change the element for the 1.6 one, but you'll find it hits a flat spot at 4000RPM.
hence why mines unplugged, no flatspots
