My Fiesta Cossie
My Fiesta Cossie
Postby fiecos dan on Mon Dec 27, 2004 3:24 pm
My Fiesta cossie
AT the moment the cossie's off the road, and in the middle of a engine rebuild, and a few little mod's.
mk3 2i originally, with djm conversion(2000)
running escort cossie running gear,
Had the Fiecos wiegh'd @ a local wiegh bridge 3-2-2006
come in @ 1280kg in road trim inc full fuel tank, but no driver (i wiegh 80kg's)
as trackday trim = 1220kg
Spec list.
Engine dyno'd 505bhp, and 447lb/ft at 31 peak, 26 held psi,8/04
2.0ltr yb, Mahles pocket'd, l&b, arp long studs, Arp big end bolts,
Touring car spec head, Piper 509 inlet cam, k2 ex, verniers,
Dyno'd by David hills,
Cometic full engine gasket set,
AET GT30 turbo, internal wastegate,
RS500 inlet (modified elbow, and plenium spacer inc 2nd injector port mod's) 4x 1000cc rochester injectors,
Sec's S8 ecu with My own live mapped setup, Dingy (steve) engine loom,
My own big wing sump(6 1/2 ltrs) and a wrc baffle tray,
R+D 6 speed dog box, 50nm centre vicous,
Dome platted front diff in thick housin (rebuilt 7-07), Quaife Atb rear diff with shoot pined internals,
6 pot AP's 330mm front brakes, std uprated escos rears, braided hoses, wilwood rear bia valve fitted in car
8/07 New spec AH fab intercooler and radiator with twin spal fans,
Alloy tanks, baileys breather,
My own stainless 63mm boost pipes,
My own 3" twin exit zorst , with 2wd mani
Avo coilovers and 450lb/ft fronts, 240 rear springs, and poly bushes, Adjustable tca's,
Psg bodykit and bumpers, 17" team dynamic alloys,
Cobra seats, harnesses, 03-07, New race bucket seats brought..
T-E Wide band AFR meter, Autometer boost and tacho,
Racetech oil press+temp & fuel press gauges, Defi egt gauge and link unit.
S.E.C's ecu monitor, and Laptop.
Performance
All times set with full trim, Full tank of fuel, and Nankang tyres
183mph top speed at 7700rpm in 6th speed on gps in 1.5 mile private road,
With Mega rich fueling problems @ bruntingthorpe 11/05 done 173mph at 7500rpm @1.1 mile mark. (running about 430bhp @ 23psi)
2x 11.1's@123-4mph on 25psi at santa pod on redline rumble 5/05
2x 11.1's@124mph at bruntingthorpe, wiith redline/fast ford mags 6/05
0-60 in 3.04 secs, 0-100 in 6.88, 0-150 in 18.9 secs.
11/05 at Brunters, with 23psi, and transmission problems and in the rain,
0-60 in 3.6.
newer spec which should be running in next few month, inc's
1000cc inj's
new inlet,
new down pipe,
New rear diff mount, and solid beam mounts,
I'm after a 480 bhp in car, as at mo i guess its only ever run 440-460bhp in car due to problems and boost.
lookin for 10's quarter, and 130mph terminals
and even tho i've seen 180 mph gps on the road, i want to prove it at a thrash.
My cossie engine dyno read out 8/04
engine in dyno cell 8/04
The running gear just gettin fitted.
3" stainless system
6 pot 330 mm AP's
The cockpit
Rear end, beam and diff set up.
My Xr2tt
G reg xr2, in mercury grey.
1.6 cvh engine, rst pistons, 8.2:1 c/r, ARP bolts, L+B bottomend, and my own Baffle'd sump (3-07).
12-06, my own P+F'd hemi head, std valves, with valve guilds flushed to ports, 6-07 Kent 35 cam timed with Kent vernier,
8-07, 4wd T3 turbo, My own modifed rst exhaust manifold to cure room issue's, my own 2.5" s/s down pipe, 2" magnex zorst,
9-07, My new own intercooler setup, with s/s boost pipes,
9-07, Cosworth rad with my fitting kit,
9-06, Reno 5 turbo carb, on my own inlet mani,
8-07,EMS 5 micro dynamics ignition system,
Rebuilt early xr2 gearbox with a quiffe ATB diff, Deflex (my spec) gearbox mounts
Escort cossie front disc's and calipers, fitted with my Kit, rs1800 master/servo, braided hoses.
15" zetec s wheels on 195/45/15 Goodyear F1's, Dunlop slicks for track.
- Gaz front coilovers, 300lb springs, -50mm front, -60mm and spax adj rear, poly bushed.
-Fronts, 4' castor, 2.5' camber, 2mm toe in for track, 0.5' camber, 1mm toe out for sprints.
-Rears, 0.5' camber, 1mm toe out.
90 spec rs seats, momo s-wheel and gear nob, and bucket seat and harness for trackdays,
Mocal boost, and oil pressure/temp gauges, and R&B ACT gauge, and auto meter EGT gauge.
Mocal 16 row oil cooler and state.
All built, and tuned by myself.
POWER,
Had the xr2tt on Surrey RR on 3/6/06
Big thanks goes to Charlie @ Surrey RR, Top bloke and service
- Was running stg3 head, cvh 36 cam, and T25 turbo.
With safe ign (no det), and fuel setting (not perfect)
12psi- 179 Bhp/fly, 170 lbft/fly, 148 Bhp/wheel, 140 lbft/wheel
15psi- 186 Bhp/fly, 184 lbft/fly, 155 Bhp/wheel, 156 lbft/wheel
18psi- 191 Bhp/fly, 194 lbft/fly, 159 Bhp/wheel, 161 lbft/wheel
21psi- 198 Bhp/fly, 199 lbft/fly, 166 Bhp/wheel, 167 lbft/wheel
The Most it made was @ 21 psi, but ignition was advanced 4 degrees more than what i can run on the road with out det,
21psi- 203 Bhp/fly, 204 lbft/fly, 169 Bhp/wheel, 170 lbft/wheel
They were all recorded , in 28+oC ambients, and the car run 14 runs in total in 15-20 mins with out proper cool down stops, But ACT's, coolant and oil temps all stayed @ fine temps.
Thats compared to what it got on PTS RR in 4/2004,
on same bottom end, but different head,cam, downpipe, inter, But was on 9.3:1 c/r.
@ 13psi = 199bhp/fly, 174bhp/wheels ,228lb/ft
@ 10psi = 182bhp/fly, 152bhp/wheels, 199lb/ft
Wieght
as on road 1035kg (inc me at 85kg) with tools,spare and stuff.
as wen i got 13.8 1/4 = 985kg with me.
Performance
Avon raceway 10-06, 9x 13's, best at 13.6 @100mph, on road tyres and about 180bhp.
4 x 13.8's @ 102-104 mph at pod 8/04 with 27-29 0C ambients
Top speed on gps is 140mph at 6.6k in 5th. in under a mile.on old engine spec
6/06 @ Brunters for PF thrash, on new spec engine, did 133mph @ 6300rpm, but wouldn't rev any more, on 12psi and in under a mile from stand still. i also done 14.9@99mph in the wet, and 0-60 in 6.2.
Image Image
Image Image
Future plans/ specs
New bonnet with pulser side vents. got both, just need sorting
Aimin for 240bhp, low 13's @ 110 mph.
add more rear camber.
A new 2.5' zorst,
Escort Cossie front brakes
Heres a few more pics of my xr2tt taken 4/06. and 6/06
And some Engine bay pics, 19-03-07
Cossie 11.1@124 - xr2tt 13.6@100mph
fiecos dan
Postby Ben_frst on Mon Dec 27, 2004 3:32 pm
nutter
Ben_frst
Postby NU773R on Mon Dec 27, 2004 3:37 pm
:o :o :o
fiesta cosworth how much did that cost ya?????
wanna sell it to ME
NU773R
Postby Ben_frst on Mon Dec 27, 2004 3:41 pm
as said in other post 1 million questions to follow
Ben_frst
Postby Xr2i_Boy on Mon Dec 27, 2004 3:50 pm
:aaah:
Xr2i_Boy
Location: Bognor Regis Project: Xr2iCE Completion Date: ???? Car Location: DriveWay Targeted BHP: 200
Postby ianFRST on Mon Dec 27, 2004 4:35 pm
:o :o :o awesome
thats the biggest intercooler i think ive ever seen :lol:
Postby Ry on Mon Dec 27, 2004 4:53 pm
wow very impressive dude, welcome to the site :)
Ry
Postby Swanick on Mon Dec 27, 2004 5:00 pm
welcome to the site mate, top cars u got :D
Swanick
Escort RS Turbo
Escort RS Turbo
Postby chumkila on Mon Dec 27, 2004 5:16 pm
both cars are absolutely fabulous. i remember the 4x4. 8)
Postby Max M4X WW on Mon Dec 27, 2004 5:32 pm
Oh my god! And 183mph! Why havent we seen this before?! :D
Postby Sphinx on Mon Dec 27, 2004 6:44 pm
Pure Class! :D
Postby fiecos dan on Mon Dec 27, 2004 7:34 pm
cheers for the welcome,
it cost alot mate, aint plannin on selling it at all at mo,
i've had a xr2tt for over 3 years, i built it, drove it, proved a carb turbo xr2 ability's, and not thinkin of sellin that either.
its something i do, build and keep, as i know how much time and money goes into them, and if i sold them, yourll not even get half of wot i put in bk,
fiecos dan
Postby Robin on Mon Dec 27, 2004 7:42 pm
both very sweet, have to get that cossie fezz down the runway with sunny and paul that would be a whicked site
Robin
Arsenal We Love You!
Postby javablu on Mon Dec 27, 2004 7:44 pm
except sunny and paul are Fwd ;)
I take it thats 4wd or Rwd being a cosworth right?
Nice looking too, bet it goes like s**t off a fan ;)
javablu
Postby Adam_R on Mon Dec 27, 2004 7:46 pm
read the title flip :p
Adam_R
Postby chris-fiesta on Mon Dec 27, 2004 10:22 pm
SHHHWEEETTTT :bonkers:
chris-fiesta
Postby fiecos dan on Tue Dec 28, 2004 1:03 am
see above for more pics of xr2tt taken 1/05
edited for above 20/2/05
cheers danny
fiecos dan
Postby Asad on Tue Dec 28, 2004 1:20 am
OMG!
WHERE DID YOU GET THAT WHEEL CLAMP FROM????
j/k :)
Very Very nice!
Asad
Asad
Postby fiecos dan on Tue Dec 28, 2004 1:31 am
i got the wheel clamp from 'machine mart' £40 ish
cheers danny
fiecos dan
Postby Capri on Tue Dec 28, 2004 11:55 am
Very very nice indeed mate, and that goes for both cars. Well done, they both look fantastic! :D
Capri
Postby RS_Rawli on Tue Dec 28, 2004 5:52 pm
looks well lush, much better t han wen it was featured :)
Postby BUTRE on Tue Dec 28, 2004 6:22 pm
DAMN!!! :aaah:
I see here 4x4...
This is good stuff!
Ace moded Fords fiecos dan :D
btw, how did you got 199bhp @ fly from a 1.6 CVH running only 13psi?!
BUTRE
Postby Spanthefestaman on Tue Dec 28, 2004 8:32 pm
We need videos of them in action mate as they are the mutz nutz. You must be the happiest lad alive, you have every member on heres dream car and then some.
Keep it up mate.
Spanthefestaman
Postby fiecos dan on Tue Dec 28, 2004 8:39 pm
cheers again for the comments.
it was 9.6:1 c/r mate, d.i.y flowed lean burn head, and mani's, t25 turbo,
but on day woz dettin @ 13psi, and woz lean
now run 14 psi held, with good fuelin and 6 dee less ign(no det), with bigger carb.
fiecos dan
Postby Mulder on Tue Jan 04, 2005 2:43 am
Madness... :o
Big r'spec, though, I'd love to see a vid of this baby tearing up the streets.
Audi TT quattro turbo :: 500 bhp :: 700 Nm :: 18" OZ Vela
Fiesta XR2i 8v :: 104 bhp :: 135 Nm :: 14" Dezent D
Mulder
Postby andyhardy on Tue Jan 04, 2005 2:54 am
Both cars look awesome mate - you gonna be at FITP in May?
Just wondered if you fancied convoying up (I'm from near Hastings way).
Postby Monky on Tue Jan 04, 2005 1:58 pm
That is an engine :o
Monky
Location: Bristol, Where all the westers shoot the hengrovers. Own a 1.1 and a Austin Mini!
Postby The Modfather on Tue Jan 04, 2005 6:03 pm
quality cars mate
welcome :)
The Modfather
Postby moulder on Tue Jan 04, 2005 6:40 pm
That cossy is mental!!!!!!!!!!!!
Have you got any more pics of the rear set up and transmission tunnel inside. Must be carzy on the road. I think I spoke to you at Ultimate Street Car 2004 when you were doing phatty times in your Mk2. I spoke to you while you were playing with the carb before your next run, through the fence. I was a bit half cut at the time so its all a blur lol.
Either way you have two cars we all want on this board :D
moulder
Postby fiecos dan on Tue Jan 04, 2005 7:16 pm
cheers lads
if cossie done will most prob go fitp.
yeah i did speak to lots of peeps at usc.
fiecos dan
Postby fiecos dan on Sat Feb 19, 2005 8:41 pm
see above for dyno sheets of both cars, and 1/4 mile slips for xr2tt.
cheers danny
fiecos dan
Postby hoex on Sat Feb 19, 2005 10:38 pm
er ... wow! mint cars buddy :aaah:
hoex
Postby Max M4X WW on Sat Feb 19, 2005 10:47 pm
340ish bhp?! :o Seems like its at quite low revs as welll :-? Good stuff.
Postby fiecos dan on Sun Feb 20, 2005 1:01 pm
cheers lads
fiecos dan
Postby Ben_frst on Sun Feb 20, 2005 7:40 pm
your my sir are a god **tilts hat*
Ben_frst
