Guide to silencing those noisey HCS tappets of yours
Postby RS_Rawli on Sat Nov 22, 2003 7:07 pm
done this today, n it really has worked
so here goes
tools required
ratchet
strong arm
10mm socket
11mm socket
13/14mm socket (cant remmeber which)
19mm spanner
feeler gauges
grinder and a steady hand or a grinding stone
- MAKE SURE CAR IS COLD
Remove air box from top of carb, (3 screws)
Un clip the breather pipes from the air box
take off the plug leads (remember where these go thought - might be wise to check that they are in order - Left to right on the clip that mounts on the rocker cover
Undo the rocker cover (4 10mm bolts)
remove the rocker cover - being careful not to damage the gasket if there is one on yours
you will now see 8 rockers, 4 14mm bolts, 8 valves and 8 11mm bolts
undo the 4 14mm bolts with the ratchet or use the strong arm if they are too tight
lift out the bolts, and lift up the rocker shaft - being careful to leave all 8 pushrods behind (the long black giant golf ball style things) at the back.
you now hold the rocker shaft
if you look at the faces of the rockers (the tappet parts) you will notice an indentation on each one, this is due to the valves wearing away at the face and hence why even when you set the tappets they are still loud (because of the indentation that you dont read)
you are now faced with two options
struggle to grind them flat whilst in situe on the shaft
or
remove the split pin from either end and slide off all the springs and the rockers (being careful to remmber where they go cos afair they are numbered differnetly :-? )
then using either a grinding stone, or a steady hand and an angle grinder grind the surface off the face to remove the indentation (dont go daft) just literally skim across the surface so its flat or as best you can get it (be sure to use saftey s**t for this i dont want any complaints :lol:
when done put em back on the shaft in order that you removed them
place the shaft back onto the head, line the bolt holes up and make sure that all of the push rods are sat nicely under the rockers (usually they will spin pretty easily if they are) (its important to make sure that they are seated propperly cos you could bend em if they aint)
when your confident that they are all sat in nicely tighten the middle two 14mm bolts, then the outer two and then check em all for tightness (probs best doin this with a torque wrench but im lazy)
then refer to the haynes to set the tappets (cos i cant be bothered explaining it)
might be an idea to do the valve stem seals in situe while your at it
stick it back together
start it up, voila, silence ;)
rawli
- i dont accept resonsibility for anything going funlumps up :)
Postby AndyRS1800 on Sat Nov 22, 2003 7:31 pm
Just got back from Mr Rawli's... car runnin quiet as... thought he had stuck a Zetec in there on the sly... Nice 1... :D
AndyRS1800
Postby RS_Rawli on Sat Nov 22, 2003 7:32 pm
AndyRS1800 :Just got back from Mr Rawli's... car runnin quiet as... thought he had stuck a Zetec in there on the sly... Nice 1... :D
all ya can hear is the belts :D gonna do summut else to make it that bit quieter 2moz ;)
Postby Stoned on Sat Nov 22, 2003 7:55 pm
What the heck is a nice car like yours doing with such a rubbish engine in it!!
Stoned
Postby AndyRS1800 on Sat Nov 22, 2003 7:57 pm
Waiting for the right FRST engine...
AndyRS1800
Postby PaulC on Sat Nov 22, 2003 10:05 pm
Rebuilt a head on a HCS escort a few weeks back, and set the tappets. Didnt bother taking the rocker shaft off, just reset them and its as quiet as a new engine.
One thing to watch out for is the inlet/exhausts swap half way, the middle valves (4 + 4) are both exhaust.
Also, HCS valves cant be done in situ I dont think, CVH can, but I wouldnt suggest it unless you want to start snapping studs in the head like I did on mine :(
Postby RS_Rawli on Sun Nov 23, 2003 11:03 am
PaulC :Rebuilt a head on a HCS escort a few weeks back, and set the tappets. Didnt bother taking the rocker shaft off, just reset them and its as quiet as a new engine.
usually when just setting the tappets the noise comes back within a few hundred miles
its due to the fact that the valves wear a nice dome shape into the rocker face resulting in accurate clearance being unmeasurable using feeler gauges ;)
Postby Liebo on Sun Nov 23, 2003 11:36 am
You can set the clearences to be smaller than they should be, Fiesta_Steve knows more about this...
Liebo
Postby RS_Rawli on Sun Nov 23, 2003 1:41 pm
Liebo :You can set the clearences to be smaller than they should be, Fiesta_Steve knows more about this...
this will result in loss of power though :p
Postby Liebo on Sun Nov 23, 2003 1:47 pm
i thought it would be more power?
Liebo
Postby Liebo on Sun Nov 23, 2003 1:49 pm
Also, instead of grinding them flat, why dont you just buy new ones from Ford that will be flat if they are spose to be flat new anyway?
Liebo
Postby RS_Rawli on Sun Nov 23, 2003 1:59 pm
Liebo :Also, instead of grinding them flat, why dont you just buy new ones from Ford that will be flat if they are spose to be flat new anyway?
grinding is free :rolleyes:
less power as the valves have less room to move up :rolleyes:
Postby Liebo on Sun Nov 23, 2003 2:14 pm
i thought setting the valves closer down would mean there is more space above them to move up :/
Liebo
Postby RS_Rawli on Sun Nov 23, 2003 4:23 pm
Liebo :i thought setting the valves closer down would mean there is more space above them to move up :/
you work that one out then :lol:
youve just said - smaller gap means that they can move more :lol:
Postby Liebo on Sun Nov 23, 2003 4:34 pm
look, i dont know what the f**k i am talking about half the time...
Liebo
Postby RS_Rawli on Sun Nov 23, 2003 4:35 pm
Liebo :look, i dont know what the dickens i am talking about half the time...
why post then :-?
Postby Liebo on Sun Nov 23, 2003 4:39 pm
An idea?
I was told having smaller than standard was better for performance.
This must be wrong.
Liebo
Postby RS_Rawli on Sun Nov 23, 2003 4:40 pm
Liebo :An idea?
This must be wrong.
no idea, afaik it reduces performance :D
Postby PaulC on Sun Nov 23, 2003 6:58 pm
Liebo :I was told having smaller than standard was better for performance.
Smaller gap = larger valve opening.
The rod still pushes the same, so a smaller gap will mean the valves will open further. It affects performance, but thats it I think. If the gaps are too big then thats when you start damaging things because the valves arent open enough.
Postby PaulC on Sun Nov 23, 2003 7:00 pm
I'd hate to think what just one would cost! Was getting a speedo cable the other week and a women wanting a wheel trim for a mondeo had a heart attack.. £25 each!
Postby dan_turner on Wed Nov 26, 2003 6:25 pm
Hi Guys
Reason for not over tightening the valves is basically you are supposed to adjust the valves from cold. The gap is there so that there is room for expansion as the metal gets hot. If they are too tight the valves will not shut properly causing a loss in compression. Result.... Flat, slow engine
Hope this helps
dan_turner
Postby bluefiestamk3 on Mon Jan 26, 2004 11:57 pm
cheers rawli, just found this, im gon have a go tommoro :D
The ends should be totally flat not rounded off or dome shaped as you put it?
cheers :D
bluefiestamk3
BANNED MEMBER
Postby Meths on Fri Feb 13, 2004 11:36 pm
Asked while I was in the parts shop this afternoon....
£9 each (£72 per set of 8 ).
EDIT: Smilie instead of 8 !
Meths
Postby badj on Thu Apr 22, 2004 11:32 pm
dun this, with a minor setback of forgetting to align the pushrods *dont forget* lol.
runs alot quieter, [ERRR] go even quieter wen i adjust the tappets properly
got pics tho! -
Before - Worn tappets
Ater - Smooth tappet
badj
Postby RS_Rawli on Thu Apr 22, 2004 11:37 pm
thats the way, u will have noticed that they where propper indented
Postby badj on Thu Apr 22, 2004 11:43 pm
lol glad u didnt say id grinded the wrong things!
badj
Postby Liebo on Fri Apr 23, 2004 9:46 pm
RS_Rawli :this will result in loss of power though :p
PaulC :Smaller gap = larger valve opening.
So I was right? small gap better performance?
anyone know the optimal setting? I believe Fiesta_Steve does?
Liebo
Postby badj on Fri Apr 23, 2004 10:25 pm
ok its a bit noisey today but thats prolly cos i havnt got a feeler guage to set the rockers... spent all today sorting out sum rust n fitting my backbox properly, then cleaning and polishing the focka.
any otha ideas on how to silence the bugger down a bit?
oh an has any1 else got a manual choke?? how annoying :x
badj
Postby Liebo on Sat Apr 24, 2004 2:37 pm
manual choke = pre 1993 engine
Liebo
Postby badj on Sun Apr 25, 2004 12:36 pm
ye i kno, no s**t sherlock! (sorry for sarcasm)
dus ne1 else hav a G reg n find this annoyin? lol
badj
Postby Lolly on Fri May 14, 2004 11:07 am
how can i quiet my 1.1's tappets?! :lol: :-?
Lolly
Postby Marc D on Sat May 15, 2004 7:10 pm
says in the first post
At least i dont drive a saxo!!
Marc D
Your car: fiesta xr2, xr2i and rs turbo
Postby Badgerboy on Tue Jul 13, 2004 10:34 pm
I did this yesterday, and while I was at it cleaned everything up nicely and gave it a glaze of engine oil putting it back together.
After grinding the rockers down, I reassembled everything, and set the tappets correctly. Turned the engine over and...
Well, rather disapointed to be fair. Its a little quieter but still sounds like a HCS bag of nails. (Like new then!) I was under the impression from the above posts that it would be noticable difference.
Meh, the engines only got to last 6 more months hopfully, and then we go turbo!
Badgerboy
Postby Max M4X WW on Sat Jul 17, 2004 11:58 pm
Did you adjust valve clearances after smoothing them?
Postby Badgerboy on Sun Jul 18, 2004 3:09 pm
Max M4X WW :Did you adjust valve clearances after smoothing them?
After grinding the rockers down, I reassembled everything, and set the tappets correctly . Turned the engine over and...
Yes, did them properly. Done them a few times over the years now.
Badgerboy
