MAX T3 BOOST ON BLUE INJECTORS?
Postby MIK3Y on Sat Aug 09, 2003 4:40 am
What would every1 say was the max boost level i can run with standard injectors, uprated fuel pump, 195 chip?
Im thinking 12psi as thats about the same as 15psi on a T2 but am not sure.
CheeRS, Mikey.
Life moves pretty fast. If you don't stop to look around once in a while, you could miss it.
MIK3Y
Postby MIK3Y on Sat Aug 09, 2003 12:36 pm
Any1?
MIK3Y
Postby snake on Sat Aug 09, 2003 1:00 pm
195 chip is designed to run beige injectors, all engines slightly differ only way to find out exactly is to get it checked. bhp tems your lookin at 175-180 max on blues
snake
Trainee Burger Flipper
Your car: ford
