FRST t2 turbo exhaust housing. cheap as.
Need a certain part or accessory?
Postby rob pace on Sun May 21, 2006 7:10 pm
as title, need this, exhaust downpipe thread is f**cked.
rob
rob pace
Re: FRST t2 turbo exhaust housing. cheap as.
Postby rst in progress on Sun May 21, 2006 7:58 pm
rob pace :as title, need this, exhaust downpipe thread is fouquette.
rob
think i mite have one of these but not sure will have to check
rst in progress
Postby jayrs on Mon May 22, 2006 12:35 am
grind down the side of a bolt so it fits in the hole and use that.
of get it re-tapped.
if you do decide to get another let me have the old one :)
Postby Pez on Mon May 22, 2006 1:08 am
If you are in need of the housing being drilled and tapped i can sort that out for you buddy. Just discovered yesterday High Wycombe isnt that far away really. Let me know if you want any help :)
Pez
Postby rob pace on Mon May 22, 2006 7:55 pm
bump
rob pace
Postby Liams on Mon May 22, 2006 10:45 pm
I have one mate, only other side of croydon!! Just gota take it off! :D
Drive it like ya stole it!! You'l never see rust go so fast :)
Liams
Postby AndyBlackFRST on Tue May 23, 2006 10:27 am
There is a guy posted in the general thread asking if his knackered T2 is worth anything.. Maybe worth a try
Car is back...
AndyBlackFRST
BANNED SELLER
Postby jayrs on Tue May 23, 2006 5:46 pm
get it drilled and tapped, thats what i was gunna do if i was to get it mate :wink:
Postby rob pace on Tue May 23, 2006 5:54 pm
jayrs :get it drilled and tapped, thats what i was gunna do if i was to get it mate :wink:
liams who replyed in this post live about 2 miles from me and he has one on a knackered t2 turbo unit.
im awaiting his reply. or pez is going to do it for a charge.
rob
rob pace
Postby jayrs on Tue May 23, 2006 6:38 pm
fair does mate
Postby shiftelec on Tue May 23, 2006 6:59 pm
tell me the size of the thread and ill post u a set of taps!! my guess is 10mm
back with the rs badge after a 12yr absence!!!
shiftelec
Your car: did have a '90 Fiesta rs turbo
Postby rob pace on Tue May 23, 2006 7:07 pm
shiftelec :tell me the size of the thread and ill post u a set of taps!! my guess is 10mm
would not know at this precise moment.
rob pace
Postby shiftelec on Tue May 23, 2006 7:23 pm
corect me if im wrong was it not a 17mm spaner to undo it?
shiftelec
Postby rob pace on Tue May 23, 2006 7:27 pm
shiftelec :corect me if im wrong was it not a 17mm spaner to undo it?
what it is, its a stud, you screw it into the housing by hand, connect the downpipe up and screw a 17mm nut onto it.
i can pm my address if its ok?
rob
rob pace
Postby shiftelec on Tue May 23, 2006 7:37 pm
lol the stud is 10mm thread which is a 17mm spanner/socket which u use to undo it the stud its self should be like an exhaust manifold stud threaded at both ends and a shank in the middle, which do you need a die nut or the taps?????
shiftelec
Postby rob pace on Tue May 23, 2006 8:03 pm
shiftelec :lol the stud is 10mm thread which is a 17mm spanner/socket which u use to undo it the stud its self should be like an exhaust manifold stud threaded at both ends and a shank in the middle, which do you need a die nut or the taps?????
the thread is buggered in the housing, i try and screw a perfect exhaust stud into it and i can turn it a little and it wont move.
sorry not sure of the term "die nut"
rob pace
Postby jayrs on Tue May 23, 2006 8:16 pm
you have a tap and die, the tap you use to put a thread in a hole a die is used to put a thread on a bit of bar so you need the tap.
bear in mind its a corse thread mate.
just to throw a spanner in the works the nut on the studs on my FRST and the 1 i stripped and a FRST i got turbo from the other month had 19mm nuts on them :P :lol:
i got a thread gauge and 3 T2's in the shed, if you want i will tell you the size and TPI so you know what thread to put in it.
oh yeah, dont break the tap or your be in the shi t
Postby shiftelec on Tue May 23, 2006 8:43 pm
"to throw a spanner in the works" the socket which fits my T2 IS 17mm which make the teeth per inch thread size 10mm and to quote microcat "10mm" nut and i have just got bloody wet to check this!!!!!
shiftelec
Postby jayrs on Tue May 23, 2006 8:49 pm
shiftelec :"to throw a spanner in the works" the socket which fits my T2 IS 17mm which make the teeth per inch thread size 10mm and to quote microcat "10mm" nut and i have just got bloody wet to check this!!!!!
:lol: :lol: :lol: i was nice and dry when i said about mine being a 19mm, and i know its a 19mm as i always use the deep impact socket i borrowed :wink: from work
Postby shiftelec on Tue May 23, 2006 9:09 pm
one 10mm nut with one 17mm socket fitted to it!
shiftelec
Postby jayrs on Tue May 23, 2006 9:41 pm
mate im not saying your a lier or wrong, im saying that the few i have use a 19mm nut. :P
have to say i just checked on a stripped focked one i got and that has 17mm nuts :oooh: so fock knows whats going on :lol: :lol:
maybe the ones ive got with bigger nuts have been refurbed by turbo compaines :-? :lol:
