RS1800 SUPERCHARGER PROJECT
Postby hemingway on Mon Dec 26, 2005 11:58 am
Finally I got it my second hand Supercharger.
It is roots type of blower, Eaton M62.
New injectors 440cc :
Throttlebody 75mm:
Intecooler:
I will run MEGASQUIRT engine managemant system.
My goal is to run 13psi.
If you have any experiance with supercharging please give me your advice of installation.
hemingway
Postby Asad on Mon Dec 26, 2005 12:28 pm
hi mate,
I looked into this, is that the Supercharger of a BMW mini? If so, they are not very well suited for larger engines.
And where are you planning on fitting it and running it? You have a direct path for the belt?
Asad
Asad
Postby j7aoc on Mon Dec 26, 2005 12:36 pm
Looking good how much was the supercharge
j7aoc
Postby Ben_frst on Mon Dec 26, 2005 12:55 pm
what are you doing with the compression ratio? how far are you going to drop it? and how do u intend on doing this?
what c/r does the rs1800 run standard?
Ben_frst
Postby hemingway on Mon Dec 26, 2005 1:00 pm
It is taken from Mercedes engine and not from mini which use m45 unit. Comp. ratio will be 9:1 standard it is 10:1.
That unit cost me a 500 EURO and I order it from USA.
hemingway
Postby hemingway on Mon Dec 26, 2005 1:18 pm
Asad :hi mate,
Asad
I dont know exactly all details yet, but i have some solutions in my mind. I dont have direct path for the belt it must be custom built...
hemingway
Postby XRMike on Mon Dec 26, 2005 2:12 pm
nice interesting project mate :D
XRMike
Postby Ben_frst on Mon Dec 26, 2005 2:23 pm
hemingway :It is taken from Mercedes engine and not from mini which use m45 unit. Comp. ratio will be 9:1 standard it is 10:1.
how do you intend on lowering the comp by the pistion or via a spacer plate
9:1 may seen abit high for some ppl but i think it will make a very quick car nice and responsive to drive
i really want to see the outcome of this
keep us posted :Q
Ben_frst
Postby Asad on Mon Dec 26, 2005 2:35 pm
I had a look at the dimensions of the mercedes one too. Found it to be too large.
i was thinking about under the inlet manifold, but there is no direct path for the belt - the wing is in the way.
Was also thinking from the front but the exhaust manifold would get in the way.
The best solution I found was a Rotrex C60 supercharger. It would fit on the front and is small in size.
Would be interested in how you will mount it.
Asad
Asad
Postby hemingway on Mon Dec 26, 2005 2:36 pm
I will do my best to show you my progress. 9:1 is a bit a high compression but i will use colder denso iridium sparks and some retard ignition and i think that there will no be any problem with knocking.
I will lowering my comp ratio with forged ross pistons.
Last sumer I run 90Hp nitrous system on 10:1 compression ratio with standard motorcraft sparks with no problem and run 13.9 on 1/4 mile.
hemingway
Postby Ben_frst on Mon Dec 26, 2005 2:38 pm
i take it u will still be using the nitrous along with the superchager ?
Ben_frst
Postby hemingway on Mon Dec 26, 2005 2:44 pm
Yes but when I replace standard conection rods... But only 50 or mybe 75 hp shoot
hemingway
Postby Ben_frst on Mon Dec 26, 2005 2:53 pm
ive seen mx5s running a 1.6 dohc (compression ratio 9:1) with a supercharger running 12-14 psi making very healthy power 240 bhp but they are very quick running low 13's
what sort of power are you after?
Ben_frst
Postby hemingway on Mon Dec 26, 2005 2:56 pm
On focus 2.0 zetec with jacksonracing kit they produce 237 wheel HP on 13psi withouth intecooler. So my goal is some in that range.
hemingway
Postby FedeArg on Mon Dec 26, 2005 6:33 pm
It looks like an excellent project but I have one question. If I'm not wrong that type of charger is bolted directly to the inlet manifold. If you do it so, where do you plan to use the intercooler??? I believe it will be of no use.
One thing I noticed is that the charger has a magnetic clutch on the pulley so you can use a two stage inyection maping and use the car all the time with the charger off and when you are in the mood or you feel you need the extra power you can switch it on. And if you feel you are Mr. Cosworth you can turbocharge and supercharge the car and use the superchager at low RPM's and a mean turbocharger for the upper RPM's. Take a look at the new engines VW are going to be selling in a near future, they are supercharged and turbocharged like some of the Group B Rally Cars.
Fahr nicht schneller als dein Schutzengel fliegen kann
FedeArg
Postby Ben_frst on Mon Dec 26, 2005 6:36 pm
FedeArg :It looks like an excellent project but I have one question. If I'm not wrong that type of charger is bolted directly to the inlet manifold.
this is no problem as a flange can be made to accept pipework for remote fitting
Ben_frst
Postby XRMike on Mon Dec 26, 2005 6:48 pm
does a supercharger unit have its own oil supply, or is it like a turbo where it shares the engines oil? and are they intgrated into a custom inlet manifold.quite interesting this,i wonder if you could get one of those supercharger kits for the 2.0 focus on a 2.0 engined fiesta, they are quite costly for me :(
XRMike
Postby hemingway on Mon Dec 26, 2005 7:18 pm
Ben_frst :
I do it that way like Ben_frst say. I do not built supercharger+turbo yet. Clutch is no in the game becouse i run diferent pulley like the original was so i remove the clutch.
hemingway
Postby hemingway on Mon Dec 26, 2005 7:19 pm
For Eaton roots supercharger you dont need oil suply.
hemingway
Postby turbodaily on Tue Dec 27, 2005 10:56 am
my mini used to run a similar setup but using the m45 from the bmw mini,running a stage 4 head and straight cut gearbox on 10psi she did a 13.8 1/4 mile and made 152bhp on the rollers :Q was very fun to drive to say the least :devil:
my old frst: 185bhp @11psi stage 1
my new frst: unknown...
turbodaily
Postby robbie s on Tue Dec 27, 2005 8:08 pm
Ah Mr hemmingway, Looks like your going to have yourself some serious power there, nice one.
Was also wondering how much it was you said, for you to build me one of those 4-2-1 manifolds if you can do it for £300 I will have one :D
robbie s
Postby hemingway on Tue Dec 27, 2005 10:39 pm
Turbodaily that is nice work from you. I wish that I manage my car in something like you do... can you give me closer pictures of bypass valve and installing of it please.
hemingway
Postby paulharris on Wed Dec 28, 2005 8:03 pm
@turbo daily : 13.8 1/4 mile 152bhp, lol only possible in a mini
paulharris
Postby leon si on Wed Dec 28, 2005 8:26 pm
Impressed at your English by the way mate. Looks like a pretty interesting project, can't wait to see what it'll do power-wise at the end.
leon si
Postby hemingway on Wed Dec 28, 2005 8:30 pm
Sory on my loanguage mate :) . I wish all of you happy new year.
Pics of progres coming soon.
hemingway
Postby hemingway on Mon Jan 02, 2006 6:08 pm
So there is my theory where to put supercharger.
I put away batery anf batery holder to make place for supercharger.
hemingway
Postby freak power on Mon Jan 02, 2006 6:30 pm
I was going to say how you going to fit the charger but you beat me to it, Looks like you got the idea of fitting it from the V6 mondeo and Focus ST170 supercharger conversions.
Well done keep it up
Now driving a 1999 Audi S3 with 2.1 20v OD HTAGT3582r Turbo
Bring on the 650+Bhp 4x4 monster
freak power
Postby escortbreakers.co.uk on Thu Jan 05, 2006 1:02 pm
i thought about doing this but it seemed too much work to get one to fit and run properly, [ERRR] you gotta get the gearing right too.
Postby hemingway on Thu Jan 05, 2006 3:48 pm
more goodies :
DENSO iridium colder sparks.
And MEGASQUIRT with sensors and everything.
Now its time to start with real work....
hemingway
Postby Excursion on Thu Jan 05, 2006 3:59 pm
Great! Very interesting 8)
Postby Wooshy on Fri Jan 06, 2006 1:39 am
the girl or the ECU n such ? :P
Project W
XR2i? You bet!
Wooshy
Postby Xr_Dub on Fri Jan 06, 2006 2:52 am
Wooshy :the girl or the ECU n such ? :P
both :lol:
Postby hemingway on Tue Jan 24, 2006 12:01 pm
hemingway
Postby javablu on Tue Jan 24, 2006 12:05 pm
Looking good! shouldn't be too long before this is up and running!
javablu
Postby Asad on Tue Jan 24, 2006 12:08 pm
Hats off to you mate.
Nice idea and good work so far.
Asad
