Quiafe Diff Questions
Postby Project_XR2i_Trackcar on Sun Feb 21, 2010 2:36 pm
Mods - I need a quick response hence the thread being here, please feel free to move when answered.
Question: Would a Quaife diff which is currently fitted to an IB5 gearbox be a straight fit into a BC gearbox (assuming the one on my 1990 XR2i is a BC)?
Thanks in advance
Renault Sport Megane 250 Cup
Ford Fiesta XR2i 2.0 trackcar
Your car: Xr2i
Re: Quiafe Diff Questions
Postby RS rob on Sun Feb 21, 2010 3:23 pm
why not fit the ib5 box instead?
stronger gearset as they have bigger mainshaft bearings apparently
hence the reason cts putting the ib5 gearset in their uprated bc box's
RS rob
Postby Project_XR2i_Trackcar on Sun Feb 21, 2010 3:34 pm
The box the quaife is in now has knackered bearings.
How much would new bearings for an IB5 cost?
Edit - would the internals from the IB5 fit into my BC box, are the bearings the same
Your car: Xr2i
Postby JPA on Sun Feb 21, 2010 9:00 pm
diff would fit your bc box
ib5 internals can be fitted to bc but casing needs machined out to take bigger bearings
better just putting ib5 in as said above
john
KAMES 89.60 SECS
KNOCKHILL 55.45 SECS
JPA
Postby Project_XR2i_Trackcar on Sun Feb 21, 2010 9:47 pm
The IB5 needs stripping anyway, the bearings are fecked.
BC and IB5 are mounted differently are they not?
Your car: Xr2i
Postby JPA on Mon Feb 22, 2010 1:45 am
you can swap the mounts from bc onto ib5 , ive got one in my track car , goes straight in no probs
only thing you'll need is the thrust bearing from ib5 as bc one is different and wont fit
its a better box all round and its got built in sprung neutral position and dosent rely on gear-linkage for spring
never looked back since i put mine in with s2 diff
john :wink:
KAMES 89.60 SECS
JPA
Postby Excursion on Wed Feb 24, 2010 6:42 pm
Depends on how many bolts your BC box has. iB5's are 8 bolt but some early Mk3 'boxes are 6.
Postby Project_XR2i_Trackcar on Wed Feb 24, 2010 7:12 pm
Excursion :Depends on how many bolts your BC box has. iB5's are 8 bolt but some early Mk3 'boxes are 6.
Which bolts?
Your car: Xr2i
Postby Rhinopower on Wed Feb 24, 2010 8:15 pm
Crown wheel
Rhinopower
Your car: Volvo FH330
Postby Excursion on Wed Feb 24, 2010 10:07 pm
Sorry, yep, what Rhino said.
Postby JPA on Thu Feb 25, 2010 12:59 am
if the bc box is from a 2i as said , then it should have 8 bolt crown wheel
mk3 escort etc had 6 iirc
john :wink:
KAMES 89.60 SECS
JPA
