loom plug question.
21 posts • Page 1 of 1
loom plug question.
Hi guys,
my name is james and i own a mark rs2000 which i am in the process of getting ready to turbo.
I have been directed to you guys for some help, as people have told me you are the guys to help me.
i have brought a OFAB ECU and engine loom, what i need to know is... there is a milti plug with 10 wires which goes into the car off the engine loom, five browns,one red,one green,coupe of blacks with red strips, and a black.
the problem i have is its been chopped at the plug so need to take them into the car to the correct place, it looks like all the power up connects for ecu.
any ideas guys??????
- james2000
Re: loom plug question.
are you sure its an oab loom mate as im sure the engine loom-car loom plug has only 7 wires
- dangerousdave
looking at it, it has nine in the loom side of the plug. give me a minute i will get a pic up.
- james2000
it doesnt look like the fiesta turbo one to me?? hold on i got an xr2i loom under the bed ill get a pick up of the loom connectors as there the same
- dangerousdave
hold on... do them wires go into 8 pins on the plug??
think thats the injector loom mate is it not??
- dangerousdave
there should be another plug just like it with 7 pins inside it this is the car loom plug
1 2 2 4
O O O O
5 6 7 8
O O O X
Pin 1: Ignition Live
Pin 2: Pin 22 (ECU) to the Fuel Pump Relay
Pin 3: Fed From DIS coil pack to the Rev counter
Pin 4: Pin 20 (ECU) Current return
Pin 5: Pins 57 & 37 (ECU) to the Fuel injection Relay
Pin 6: Oil Pressure
Pin 7: B+ (Constant Live)
shown this a few times this week but this is how me and a mate made a loom for his escort
1 2 2 4
O O O O
5 6 7 8
O O O X
Pin 6: Oil Pressure
- dangerousdave
just had read on a link ive found and i think ive been sold a ofac wiring loom, with a ofab ecu
http://images.google.co.uk/imgres?imgur ... 1%26um%3D1
scroll down my pins on the ecu plug are the same as the ofac one, gutted!!!!!
can i make this into a ofab loom??? do you know what needs to be done?
- james2000
looks like a xr2i 16v zetec loom to be fair mate im pretty sure thats the wrong one, you should only have 2 rows of 4 pins in the plugs one will have 7 one will have 8 pins in
or is it out the rs2000 itsself??
- dangerousdave
no its not the same as the rs2000 loom. he told me he pulled this out of his car which had a 2.1 conversion, he gave me the ofab ecu and the cossie map sensor (one with the plug and pipe on the front) and the mounting bracket they both mount on.
im lost.
im lost.
- james2000
yeah! so its been made to run and plug into a zetec car loom!???
- dangerousdave
but the loom hasnt been chopped about, he said he extended the water temp sensor if i remember and that was it??
- james2000
correcton you maybe right mate, pic to follow, cheers for your help in this mate
- james2000
what colour wire do you have going into each pin of the plug, if this could be answered i think i maybe ok
also checked all the ecu pins and they are all the same as the ofab connector apart from i have nothing connected in PIN 30 BROWN CURRENT RETURN???
- james2000
on my xr2i loom i havew here looking at the plug like 1 2 3 4
5 6 7 8
1, black
2, brown
3, green
4, brown
5, black and green
6, brown and green
7, red
8, empty
5 6 7 8
1, black
2, brown
3, green
4, brown
5, black and green
6, brown and green
7, red
8, empty
- dangerousdave
mate you are a star!!!!!!!
thats the colours i have so if i just connect as the diagram above says im away?
- james2000
yeah mate make that small sub loom on that diagram with the 2 relays and your sorted
edit!.... unles you have the multiplug that has 7 wires on the rs2k car loom?? not sure if its the same
- dangerousdave
cheers for your help on this mate,you have saved me a lot of stress.
- james2000
no worry mate
- dangerousdave
