Postby ianFRST on Wed Jun 07, 2006 11:10 am
heeman10 :
ianFRST :nice rack :D:Q
Cheers babe :lol:
Mm guessing tends not to work too well! :lol: :bonkers: Will write a guide to tracking later on matey :)
im still waiting.......................................... :lol: :wink:
ianFRST
Postby heeman10 on Wed Jun 07, 2006 12:41 pm
Dammit! So many things to remember!!
My guide to tracking
Why is it done?
Tracking is carried out to ensure both front road wheels are angled correctly, and angled symmetrically. If they are incorrectly angled, steering feel will be poor an tyre wear will be accelerated. If they are not symmetrical, the car will try to pull to one side. We speak of "toe-out" (when a wheel is pointing outwards from the "straight ahead" position) and "toe-in" (where a wheel is angled in towards the centreline of the car). Tracking is adjusted by winding the track rods on the steering rack into or out of the track rod ends which bolt to the hub carrier. This is done by undoing the locking nut and rotating the track rod on each side of the car, usually using a pair of mole grips. Looking from the outside of the car to the centre of the car (i.e. imagine you're sitting next to your wheel, looking into the wheel arch), turning the track rod clockwise will increase toe-in, and turning it anti-clockwise (i.e. screwing the track rod further into the rod end - remember we're looking at it from the rear of the rod end here) will give more toe-out.
Necessary instructions
The car MUST stay on the level ground at all times. Jacking the car up will alter the suspension heights, camber and tracking. The track rods are accessible on my car, which is lowered approximately 45-50mm, and should still be accessible on cars with a 60mm drop.
The two bars must not be disturbed during the tracking process. If you think you may have knocked one, centralise them again by re-measuring as described in the guide below.
The steering wheel MUST be locked in a central position throughout the process.
Please do not attempt to carry out the tracking process if you are unsure of what to do. If you make a mistake, it could be your last.
Equipment: Bars
Right, to start off with, you need a pair of tracking bars. The ones I was using were two length of angle aluminium, with perhaps 20mm sides. They need to be long enough to protrude at least 100mm or so past the wheels on each side when placed centrally on the car. One bar will be secured to the front of the car, one to the rear.
Equipment: Cord
Two lengths of cord (one for each side) are needed. One length of each cord must me secured to the opposite sides of one bar, and once on the car, the cords must be long enough to be unravelled, pulled taut and secured to the other tracking bar by wrapping it round a few times. Cutting a small V-notch in the ends of the bars will ensure the cord locates properly and doesn't move. To summarise, each length of cord should be about a metre longer than the car, and similar to guy rope cord on tents. For the purposes of this guide, we'll assume the cords are attached to the front bar.
Beginning
First off, centralise the steering wheel and remove the key to apply the steering lock. (If the wheels are a long way of "straight ahead" at this point, the steering wheel may need removing using a 15mm socket, and turning to a position that aligns it better with the wheels.) For the perfectionists (and indeed those who want to make sure they won't have to screw the track rod end too far and risk leaving too few threads in contact) it would be good practise to remove the lower universal joint that joins the steering column to the rack, using two 13mm spanners. Undo the locknuts on the track rods and screw both track rods fully into the rod ends (i.e. maximum "toe out"). At this stage, it would be a good idea first to screw the rods right out of the rod ends, wire brush the threads, and apply copper grease to them for ease of adjustment. Now, turn the wheels by hand until they both point in roughly the same direction, even though they will have a lof of toe-out. The steering rack should now be about central, and provided the steering wheel is still straight ahead, the lower universal joint can be clamped onto the steering rack again.
The handbrake should be left off for this operation.
Fixing the equipment to the car
Secure the bars to the car in such a way that (a) they can be adjust left or right to perfectly centralise them, (b) they can be fastened securely to prevent movement once centralised and (c) at a height which will bring the cords as close to the wheel centres as possible. Once the bars are on the car, roughly in the centre, take the cords back to the rear bar one by one (making sure they travel through the notches you cut on both bars), pull them taut and wrap them around the rear bar enough times to keep the tension. It's important that they're tight enough not to sag at all between the front and the rear, but we don't want them so tight the bars are bending and bumper paint is being damaged.
The next job is to remove your wheel centre caps (if you have them), then measure the distance from the hub nut to the cord on the front and rear pairs of wheels using a ruler or tape measure. [You will find that it's critical that you read the distances in the same way - the easiest way being to make sure that the ruler/tape is at 90 degrees to the wheel, and that you read from directly overhead, rather than at an angle. This part of the process must be consistent throughout the tracking procedure.] For example, start with the rear wheels. Using a ruler or tape measure, determine the distance from the hub to the cord on the left wheel, then on the right wheel. Adjust the position of the bar bit by bit until the distances are the same (within a millimetre for now). Now go to the front wheels and carry out the same process, shifting the bar sideways until both readings are the same. Now check the rears again, as they may have altered when you moved the bar at the front. This time, tweak the bar until the distances are precisely the same, to the nearest 0.5mm. Then check the front again and do the same. Hopefully after this second time, both pairs of wheels will remain equal after such small adjustments.
Here is a photo of my car with the tracking bars and cords in position:
The tracking procedure
Now the cords are centralised around the car, the amount of toe-in or toe-out can be measured. This is done by measuring from the rear edge of the wheel rim (i.e. the front face of the wheel, but the side of the rim nearest the rear wheel) to the cord. Next, measure the distance between the front edge of the wheel rim to the cord. These measurements should be taken from as close to the horizontal centreline of the wheel as possible - an easy job if the cord is close to the centre nut.
Here are some example results for these dimensions:
Rear edge of rim to cord = 112mm
Front edge of rim to cord = 107.5mm
This tells us that the front of the wheel is closer to the cord than the rear of the wheel, meaning that the wheel is toeing out, in this case by 4.5mm. It can be easy to mis-interpret these dimensions, so make sure you think them through each time. If the front of the wheel is closer to the cord (i.e. the measurement is smaller than the rear of the wheel) then the wheel is toeing out, and vice versa.
This guide assumes 1mm of toe-in is required. I have yet to experiment with different tracking stances, but this is the degree my car is tracked to. I believe the recommended toe-in can be gained from a tracking station, but it may be given in degrees rather than millimetres. Degrees are a more accurate way of tracking a car, as 1mm toe-in on a 13" wheel gives a greater angle than 1mm toe-in on a 17" wheel.
So with out 4.5mm of toe-out, we must wind the track rod clockwise (looking into the centre of the car) to bring the front of the wheel in. I can't quite remember how many turns are required for 1mm adjustment, but the best thing is to give a few half-turns and re-measure the distances from the front and rear edges to the cord until the desired measurements are reached.
It is crucial that the cord is not disturbed during any of the adjustments, for obvious reasons. The bars must NOT be moved from their centralised position.
Once the desired toe-in is found on that wheel, roll the car backwards and forwards a few times, 10cm or so, to allow the wheels to settle. Make sure the steering wheel is locked centrally. Re-measure the toe-in, and adjust accordinly if it has altered at all.
Follow this process for the opposite wheel.
Once the second wheel has been adjusted, roll the car backwards and forwards a few times (making sure the bars are fully secure), and measure both wheels again. Hopefully both still have the same amount of toe-in, and the job is done.
Remember to tighten the locking nuts onto the rod ends once you have finished.
This completes the tracking process.
I would advise that anyone questioning their abilities continues to take their car to a garage to have the tracking adjusted, as the steering system of a road car is a critical one that can cause fatal accidents if not maintained correctly.
Postby ianFRST on Wed Jun 07, 2006 1:53 pm
:o :o awesome dude. will give it a go now :Q
(that reply you just did was the 666th :o :lol: )
ianFRST
Postby D.J on Wed Jun 07, 2006 1:55 pm
Top guide there mate.
Still wanna ZT my Puma!!!!
D.J
Postby heeman10 on Wed Jun 07, 2006 1:57 pm
ianFRST :(that reply you just did was the 666th :o :lol: )
Fook, seriously?! :o Obviously it's a day late..but still.. :oooh: Did you see that programme about The Omen last night? All the weird stuff that went on during and after filming the original in the 70's? Some funny coincidences going on there, this is just one more!!
Hope it goes well :D
D.J. - Cheers :) The Puma chassis with a Zetec Turbo would be quality fun I bet!
Postby nick050 on Wed Jun 07, 2006 7:04 pm
Looks good mate nicley done. Think im still gona get mine done in a profesional place tho :D they use lasers now too so even more accurate :D
nick050
Postby BUTRE on Wed Jun 07, 2006 7:33 pm
This is good to try different toe and only when the "good" toe is found, laser tracking please!
BUTRE
Postby heeman10 on Wed Jun 07, 2006 7:43 pm
nick050/BUTRE - That's a common misconception, much like people thinking a digital gauge is more accurate than an analogue gauge. Laser alignment systems are only as accurate as the operator. The good thing about using string etc like I did is that you're tracking the car around a centred square, rather than just off the wheels..whichever direction they may be pointing in! (e.g. the rear wheels may be pointing in funny directions, but since laser alignment requires gauges to be hung off the rear wheels, the toe on the front wheels is always set relative to those, rather than to the car itself.
Postby ianFRST on Wed Jun 07, 2006 8:54 pm
heeman10 :
yeah some scary s**t :o
and the fact that you had 6/6/06 in the title, then 666 replies :aaah: :lol:
ianFRST
Postby heeman10 on Wed Jun 07, 2006 10:22 pm
:lol: I'm doomed! I'm certain to crash it whilst at 6,666rpm at 66mph on the A66 (which I fairly regularly use to join the A1!) :lol:
Postby heeman10 on Sun Jun 18, 2006 6:22 pm
Non-Update :lol:
Went home at the weekend and took some photo's of it because there was nothing else to do!! Since I'll be getting a new car soon I've decided to put off the removal of the gearbox (to inspect the release bearing, clutch and flywheel, hunting the cause of my gearshift issue) until I have the new car, otherwise I won't really have any way of getting around. So, the hunt is on!
Anyway, the new stub was welded on the breather pot a couple of weeks ago:
And here are the random photo's I took:
Postby Sphinx on Sun Jun 18, 2006 6:28 pm
Looks stonking mate :D
Postby RS_Rawli on Sun Jun 18, 2006 7:36 pm
looks uber without a plate
RS_Rawli
Postby heeman10 on Sun Jun 18, 2006 7:40 pm
Thanks girls! :D
Postby mike_wall15 on Sun Jun 18, 2006 8:36 pm
Yeah, cool without the plate.... that's the hard thing with an IC and an XR2i/RS bumper, there's just no good place for a plate! :x
I like the ones that take up the Fog&Driving light position, but that's impractical... :(
mike_wall15
Car: 2002 BMW M3
Postby Rhinopower on Sun Jun 18, 2006 9:26 pm
ure IC is wonky
Rhinopower
Your car: Volvo FH330
Postby Captain Tightpants on Wed Jun 21, 2006 12:57 am
Deffo looks cool without the plate!
Looks like Libs is getting a Mk3 as a runaround matey, watch this space! :D
Steve
Captain Tightpants
Postby heeman10 on Wed Jun 21, 2006 3:24 am
Mike - Yup, no space for a plate where it looks good :) I use both my fogs and driving lights, so don't want to disable one side or I run the very real risk of hitting an animal. I'll just have to see what I can do!
Rhino - Go FT!
Stephanie - The Mk3 Fiesta was born to be a runaround! :lol: I saw/heard a standard Mondeo ST24 today btw, sounded quality when he gave it some! :aviator: New car on the cards for me tomorrow hopefully too, watch my space also! :p
Postby heeman10 on Tue Jul 11, 2006 6:18 pm
Update
Since leaving uni last week, I've taken the car out twice! Not much, you may think, but it's nice to save it for the dry, sunny days when it's safe/fun. During this period of boredom/wet weather, I've decided to approach a couple of things I've wanted to for a short while; the braking and front bumper.
Braking
When I fitted the Wilwood brakes up front, the brake pedal travel was increased, and it felt a bit on the spongy side. Also, the car was notably nose-diving, something Kenny at MSD commented on after doing a few high-speed stops. For over a year I've been planning on changing to discs at the back, but for quite a few reasons, it never happened. It didn't seem worth inspecting the rear drums as I've been forever on the verge of bolting discs on the back, but I've had enough now. New shoes will be ordered for the back brakes, and I'll take them apart...not expecting to see much left in there!
Before then, I'll be fitting the Escort Mk5 master cylinder and servo, recently purchased from Pd, though I already had a brand new Mk5 master cylinder which I've fitted to Pd's servo. The ZT's current servo looks brand new, and often gets commented on. At 13 years old many show-goers presume I've painted it, and so I decided to bring the scratty Escort servo up to scratch.
As I received it:
Sanded down, including minor surface corrosion from under the paint:
Primed:
A couple of coats of gloss black later:
And after a night next to the Aga:
Master cylinder fitted, along with vacuum hose grommet:
Job done, should look presentable once fitted to the car. Since the human foot/leg regulates pressure applied more accurately than distance travelled, it is desirable to have a short, firm pedal than a longer, softer travel. I see little point in upgrading a braking system if the control of it is lacking in precision!
Bumper
I bought my bumper from a FT.com member almost two years ago, before the ZT was even bought, let alone in the car. He "kindly" offered to spray it for me for an extra £15...though once bolted onto the car, nasty chips appeared after the first drive, and paint was flaking off at an alarming rate. It then started cracking in a lower corner of the enlarged cutout. A certain FT member stuck black tape on it at FITP this year, which pulled even more paint off it (thanks RS_Rawli!!!!!), and I couldn't bear to look at it anymore.
I pulled it off the car on Sunday and attacked it with the intention of repairing/filling the crack, smoothing the bumper strip recess at long last, and painting it properly.
A before shot, showing the condition of it:
Removing the bumper strip adhesive (no, he didn't even bother doing that before spraying!!):
The fool fibreglassed the rubber lip onto it, so that'll have to stay on during this re-work:
Some prep:
The crack, bottom right:
Largely sanded down, and the top recess which will be filled:
Laying fibreglass in the recess to make up some of the gap:
Fibreglass finished and roughed up:
The first skim of filler, one more to come (currently in progress) then time to sand it all down:
All small scratches/chips have been/will be sanded and/or filled, and I've had some paint mixed up to match the rest of the car, which will go on after a couple of coats of primer. If the colour's a good enough match I may tidy up some other areas of the car that make me cringe while I'm at it - may even have a car worthy of the FT.com stand then! :rolleyes:
Postby mike_wall15 on Tue Jul 11, 2006 6:52 pm
Glad to see you're busy on the car! Broom broom!!
I shall tell you one thing though, I'm amazed at how every time you return to the car and take pics, your fogs and driving light bulbs are still working! My fiesta never lasted two seconds without a bulb blowing! :rolleyes:
Glad that's off my chest, although I feel more bloody full light shots in the months to come! :oops: :lol:
mike_wall15
Car: 2002 BMW M3
Postby Mikee_RS on Tue Jul 11, 2006 7:09 pm
very interesting mate
ill mark u on the bumper when its finished
Image Image Image
Mikee_RS
Car: 1995 Ford Fiesta
Postby YoungDan on Tue Jul 11, 2006 7:10 pm
Looking as good as ever.. :wink:
As for number plate, how about a rallye style vinyl one on the bonnet? Not sure how it'd look though.. :oops:
YoungDan
Postby heeman10 on Tue Jul 11, 2006 7:21 pm
Mike - I replaced the headlight bulbs just over three years ago, and one of my driving light bulbs went a few months back. Other than that, that's it! :)
Mikee - Be gentle, it's my first ever time with fibreglass! :lol: First major surface I've painted too, so will be interesting to see how it turns out. Either way, it can't be worse than it was before!
Ello Dan :) Cheers! The bonnet idea could work fairly well, I just dislike anything that stops it looking like a normal road car really though :-?
Postby MarkRS2K on Tue Jul 11, 2006 7:24 pm
good stuff mate, well dont for tackling it yourself :)
MarkRS2K
Postby rich_frst on Tue Jul 11, 2006 8:29 pm
:aviator: :aviator: :aviator:
My ProjectS..
viewtopic.php?t=97195&start=0
rich
07834862431
rich_frst
Your car: mk1 sierra cos, mk2 escort est
Postby garyhurn77 on Tue Jul 11, 2006 9:35 pm
looking very good james, take ya time as discussed you'll get it looking spot on again!
very impressed so far :D
garyhurn77
Postby random_dav on Wed Jul 12, 2006 7:19 pm
keeping yourself busy then gayboy :P
will look good when done 8)
random_dav
Postby heeman10 on Mon Jul 17, 2006 10:28 pm
Update
Have been away for a day or two with graduation and helping finish build my grandad's Honda Blackbird engine Formula 27 since its rebuild, but attacked the master cylinder etc today.
Fiesta diesel master cylinder/servo on the right, Escort items on the left:
The Escort setup's quite a bit bigger all round.
Old brackets on the right, and a pair I painted up before fitting, on the left:
These are the brackets that both support the master cylinder/servo and the brake bar.
As it all stands at the moment:
The original brake lines are nowhere near the Escort master cylinder, plus the fittings are all wrong, so I'll cut them off at the inner wing and use braided hose from the cylinder to the hard pipes at the inner wing, joined using female fittings on the hard pipes, butting up against flared ends.
Postby rich_frst on Mon Jul 17, 2006 10:37 pm
nice one matey...
keen to know what the outcome is like once all plumbed in :wink: :Q
My ProjectS..
rich
07834862431
rich_frst
Postby mickylee on Mon Jul 17, 2006 10:41 pm
any progress with the bumper?
mickylee
Postby jayrs on Mon Jul 17, 2006 10:44 pm
cool, you going to do a guid for the mods need to fit this?
also let us know what the braking like copmpaired with the old one.
might consider it my self as i have a mk6 escort servo and cylinder sat in shed doing fock all
Postby rich_frst on Mon Jul 17, 2006 10:47 pm
yeah defo a guide needed i think!!!!! :D
My ProjectS..
rich
07834862431
rich_frst
Postby jayrs on Mon Jul 17, 2006 10:52 pm
would save a few people asking from time to time
Postby rich_frst on Mon Jul 17, 2006 10:54 pm
yep!!! :)
My ProjectS..
rich
07834862431
rich_frst
Postby heeman10 on Mon Jul 17, 2006 10:59 pm
Rich - Me too! Will put new shoes on the rear, and have a new set of pads ready to go on the front (burnt them out in 5-6,000 miles, and they're £75 a set! :aaah:). Hopefully with all new pads/shoes and a fatter master cylinder it'll be even sharper under braking. I'm just wondering what springs to order for my coilovers at the moment too, as I'd like something stiffer. Some roads around here caused mild scrubbing when I took a mate out for a blast last week, and I THINK 20% stiffer springs all round would remedy things. Need to drive the car again and see what I think.
mickylee - Not a great deal of progress, other than running out of filler! Half hour drive to Halfords from here, but I'll probably make the trip tomorrow or the day after. I want it all finished and ready to re-fit by the weekend ideally.
jayrs - I bought the servo ready-modified, as I didn't have my car at the time, plus I can't weld yet! *embarassed sulk* The operating rod needs modifying to fit the Fiesta's brake bar. Other than that, it's just a case of getting all the brake lines to line up as far as I can tell so far. Literally spent about 20 minutes playing with it all today, but there didn't appear to be anything else that needed doing. I'll report back about the pedal feel once it's all in and fully bled/tested. A full fluid change will no doubt help it all tighten up as well! :D
