Heater problem MK4
13 posts • Page 1 of 1
Heater problem MK4
My gf's sister has a mk4 fiesta and the heaters have stoped working, fan doesnt even blow, I have checked all the fuses and they are all ok. Next thing to check was the motor but looked under the bonnet and couldnt see it so im guessing its behind the dash. Anyone know if the fan/motor is a dash out job? Also is there a relay for the heaters and which one/where is it located. I said id have a look 4 her when its a bit lighter but dont wanna spend ages on it.
Suggestions welcome please
- rs220bhp
- Sponsored Links
- (not a real person)
Re: Heater problem MK4
blower unit is under the shuttle panel under the bonnet mate, by the wiper motor
- Pastieman
- Your car: Mk3 Fiesta Rs Turbo
hey mate i had this problem not saying its the solution but check the ignition relay its a yellow called V (5) i think..changed it on mine had no problems since .
the engine fan and the reverse light works of the same relay to so check them to
- lyonsfiesta
some one had similar problems
heres it answered:
http://www.fiestaturbo.com/forums/mk4-fiesta-heater-problem-vt181823/
heres it answered:
i have the same fault on my mk4, i checked the reverse light as you said in your post which comes on then go,s straight out but im having trouble finding the relay on the car so i can change that can anyone help cheers
Fiesta Club of Great Britain ( CLUB CHAIRMAN )
- THE GIT
reverse light?
this problem being spoken of is a heater problem lol
Pastieman wrote:blower unit is under the shuttle panel under the bonnet mate, by the wiper motor
if he had a mk3 fiesta that would be helpful.
The mk4 motor is built into the heater box and is controlled by a heater resistor which is screwed on the side and has a mutliplug going into it. Very common for these to burn out over the years and cost around £25 to replace from fords.
- knuckles
- Your car: Rover Mini Cooper
lol im confused, about 2 ppl talkign aobtu completely different things lol
sorry to confuse you fella but someone else said that the same relay powers the heater aswell as the reverse light, so i checked my reverse light and it go,s on then turns off while the gearbox is in reverse gear
- THE GIT
ive changed the resistor pack already
- THE GIT
:s first ive heard it have anything to do with the reverse light, has replacing it solved the problem?
lyonsfiesta wrote:hey mate i had this problem not saying its the solution but check the ignition relay its a yellow called V (5) i think..changed it on mine had no problems since .
this is what i was talking about mate lol
- THE GIT
yea think he was talking about a mk3 lol
23:21, 29th April 2013 web
