14/5/13 all items make me offers all under £5 each
120 posts • Page 1 of 4 • 1, 2, 3, 4
ALL UNPRICED PARTS; OFFERS OF £5 UNDER!
i'll sort a deal with you on multipurchase....
all parts quoted with out postage
large items are corrior (£12 p&p mainland Including lower of scotland) couple of items can be corriored together for that price
very large items i'e pannels, doors etc about £20+ depending
all items old as seen any intrest questions etc just ask.
or call
price list guidelines;
richbrook valvecaps new
cat 1.6 si £65
rs lifting eyes pair
rear door quater pannel trims 2 pairs avalible
door pockets pair with electric window switch holes
electric window switches (6 avalible)
roof grab handles
screen wash cover std
sun visors with mounting brackets
sun visor clip in brackets
mk3 gear nob oem
centre console bracket
hand break handle
fag rear quater inserts
3.5 mirror outer casing
header tanks
egr valves (2 avalible)
blanked off middle pillar trims for harnesses.
nsf passanger footwell bracket (found under carpet)
standard radio
ford steering wheel with airbag.
standard zetec exhaust manifold.
rubber cat hanger rubbers
centeral locking motors attached to interia handle
alarm with remote entry
rear boot wiring
boot motor
various boot parts loose; security covers, rear quater breathers
boot catch
full lock set and ignition and 2x keys
rear seat belts full
blue mk3 door
footwell trim xr2i/ frst style
drivers side front pillar trim
glove box door
mk3 rear pillar trims
inner rubber window seals (top of front door cards)
front wippers pair
front headlight
mirrors x2 sets
or carbon effect pair
windscreen washer bottle
mk3 wishbone carriers
kenwood tape player inc leads (leads worth that alone as they fit the cd ones)
gearbox air duct (non turbo engines)
drop links
mk3 strong boot hydrolic
rear speakers and mounts for rear parcell shelf etc
non egr exhast manifold zetec
std airbox zetec
airbox bracket part
heater matrix leaf cover
scuttle pannel +rubber
airbag control moduel
escort brake resivior with cap (also fits on top of mondeo brake servo)
resivior plug caps
non abs mk3 fiesta set up
s brace
gearbox cradle
empty cat
rear drum brakes pair
behind the dash plastic heater pipes
bonnet hings
heater box linkages and sliders
pedal box mk3
clutch / spedo cables
zetec fan
steering colum manual steering and mk3 surround
wiper moter and mech/ linkage setup front
front engine mount
various fuel pipes
chrome washer cap £20 as new
ESCORT P REG LX 1600 PARTS: (NORMAL PRICES)
bumpers got -crack 2 on front one on rear --- free
power steering set up (- rack) - £35
header tank £5
alternator £20
door cards £10 all 4
fuel tank £10
fuel pump £10
injectors £15
inlet manifold £20
air box £5
cross over pipe £5
exhaust (except manifold and downpipe) £5
dash £10
clocks £5
heater £ 10
wiper mech front £5
wiper mech rear £5
indicator stalk £10
all stuff atached to dash ask as depend what it is
interia loom £30
all interia trim etc (- seats and belts) ask
possibly engine loom £25
possibly ecu £60 inc 2 keys
lights front £8 pair
rear lights £8 pair
grill £5
all trim
door rubbers £5 whole car
side strips £5 both sides
glass windows sides £2 each
front and rear windscreens heated £10 each
all carpets etc.......
be quick!!!
or call
cat 1.6 si £65
roof grab handles
mk3 gear nob oem
hand break handle
header tanks
standard radio
rear boot wiring
boot motor
boot catch
blue mk3 door
glove box door
front wippers pair
front headlight
mirrors x2 sets
drop links
std airbox zetec
airbox bracket part
resivior plug caps
s brace
gearbox cradle
empty cat
bonnet hings
pedal box mk3
zetec fan
front engine mount
various fuel pipes
header tank £5
alternator £20
fuel tank £10
fuel pump £10
injectors £15
inlet manifold £20
air box £5
cross over pipe £5
dash £10
clocks £5
heater £ 10
wiper mech front £5
wiper mech rear £5
indicator stalk £10
interia loom £30
rear lights £8 pair
grill £5
all trim
be quick!!!
- sam-si
- Your car: FORD FIESTA
Re: 3 jan 2013 breaking xr2i 1992 mk3
continued.
- sam-si
continued:
- sam-si
continued still avalible
mk3.5 zetec 1.6si alternator worked great! £20
brand new fag lighter and set up £5
clocks with glass seperated £1
1.1 +1.3? fiesta fan £2
fiesta mk3 mk3.5 window rubber £2
ford fiesta si front arch splats pair £5
odds and sods and (the well i hope you can 'identifys'):
hcs rocker cover and rockers 1.1? 1.3? mk1? mk2? mk3?
odds i know the long bracket is off a mk3 si 1600 brake servo to steering rack bracket
inlet? hcs? 1.1? 1.3?
hcs 1.1 1.3 alternator
coil 1.1 1.3 hcs??
dizzy off hcs?
mechanical fuel pump off something>
oil pump.... hcs??
apparently a escort powersteering type auxilarybelt tentionor (was ordered by mistake for my si) new £60
some door rubber not sure what off!?
some door rubber not sure what off?!
Wire with eylets either end? brakes mk3 fiesta new £5
cheers sam
#0781 366 9260 call between 9am and 10pm
- sam-si
message sent to you on fiesta guides
- AW0L
AW0L :message sent to you on fiesta guides
messaged back on there
- sam-si
sam-si :AW0L :message sent to you on fiesta guides
message back!
- AW0L
btw also have a rear axle set up and rear drums and rear anti roll bar etc and 5 alloys just need to take pictures soon!
- sam-si
sam-si :btw also have a rear axle set up and rear drums and rear anti roll bar etc and 5 alloys just need to take pictures soon!
i got mk5 rear beam on mine and trying to sell my stock beam too lol
- AW0L
Location?
And would/will you cut anything off the shell, im after the passenger side wishbone outrigger..
Oh and cracking advert, bet that took a few minutes to put together
- Fraggle
Fraggle :Location?
Oh and cracking advert, bet that took a few minutes to put together![]()
i'm in rayleigh in essex fella. unfortunately i scraped the shell this morning but i kid you not its one of the worst condition mk3 shells i've seen so i doulbt them bits would have been any good!
shell spec
1) had a hole or 2 in bulk head about 40mm round
2) the floor on either side has about 1/3 of the edge missing (slotted holes) where it meets the seals
3) the underside of the seals was really bad so soft it was unreal and a hole that large i could put my hand in!
4) the outer and inner skim of rear quaters had parted as there was a constant hole round the mating areas
5) the rear arches had about a inch missing from where the lip should be all the way round
6) rear valance was dead and like paper in the corners and the exhaust hole twice as big
7) front chassis legs were dead
9) big 120mm patch welded in n/s/f inner arch/ bulk head
10) both front wings had holes in!
11) o/s/f inner arch / drivers foot well corner area was really soft and where all 3 panels met was rotten big time!
bit of a bad shell
quote;
Oh and cracking advert, bet that took a few minutes to put together .
that was a long one the old xp died 3 time in the process!
- sam-si
Sounded a peach
anyways' no worries, cheers for the reply though...
My quest continue's.......................................................................
- Fraggle
Fraggle :Sounded a peach![]()
what part actualy is it your after? get a piture and i'll keep a eye out!
- sam-si
sam-si :Fraggle :Sounded a peach![]()
One of these highlighted in the black box, with about as much metal around it as the outline of box shows so i can unpick it from the leg...needs 2b passenger side
- Fraggle
Hi mate I'll have the dash and clock surround (binnacle?), the rs2000 discs and calipers, and I also need the interior triangle bit of trim for the door mirrors for both sides too.
Also, you mention "s brace". Do you mean strut brace? Seems very cheap, but if it'll fit the front of the 1.8 xr2i I'll have that too mate please.
I have someone that could collect from you, just give me your PayPal address and let me know how much you want for the lot and I'll send you some money bud.
Cheers, Adam.
Cheers, Adam.
- adamr6698
- Your car: XR2I 1.8 16v
Actually, I'll take the rear lights and the gearstick gaitor too please if you still have them
- adamr6698
adamr6698 :Hi mate I'll have the dash and clock surround (binnacle?), the rs2000 discs and calipers, and I also need the interior triangle bit of trim for the door mirrors for both sides too.
Cheers, Adam.
right fella am i right in saying you want the dash and all the bits on the dash?
i.e
1) dash ( please note the mark pictured in the second picture of the dash on the nsf)
2) clock surround
3) centre dash (where the log light buttons go not included)
4) ash tray
5) blower inserts x3
6) glovebox door
7) gearstick gator
9) triangle interia mirror bases
10) rs2000 disks and calipers
11) dash clock
are you also interested in ?
1) hocky stick interia pair?
2) black center console?
the s brace is gone that isthe underside of the exhaust suport member
also fella what did you mean by "(binnacle?)" cheers sam 0781 366 9260
- sam-si
By "binnacle" I mean the clock surround mate. So I need just:
1) the main dashboard and
2) the clock surround please. As well as
3) the interior door mirror triangles,
4) rs2000 brakes,
5) rear lights and
6) gearstick gaitor.
Thanks bud
4) rs2000 brakes,
5) rear lights and
Thanks bud
- adamr6698
adamr6698 :Oh and what do you mean by the hockey stick bits?
i think he means the handles that move the mirrors
- AW0L
AW0L :adamr6698 :Oh and what do you mean by the hockey stick bits?
If that is what you mean mate I don't need them bits ta
- adamr6698
na the hcky stick trim that goes from the bottom of the dash board along the floor under the doorway
- sam-si
1) the main dashboard £10
2) the clock surround £4
3) the interior door mirror triangles, £3
4) rs2000 brakes, £40
5) rear brake lights (i'm guessing the external lenses you mean not the bulb holders?) £5
6) gearstick gaitor. £2
can do the above for 60 quid collected? any good?
cheers sam
cheers sam
- sam-si
Yeah the lenses mate that's spot on. What's your PayPal address, and your home address? I'll get them collected within about a week on the night time. Is it ok if I pass your phone number on to the guy collecting? Cheers bud
- adamr6698
adamr6698 :Yeah the lenses mate that's spot on. What's your PayPal address, and your home address? I'll get them collected within about a week on the night time. Is it ok if I pass your phone number on to the guy collecting? Cheers bud
paypal;
sam77watson@live.co.uk
ill meet him at asda (rawreth lane) car park rayleigh. as its easyer to find fella and yer pass my contact details on there;
sam #0781 366 9260
- sam-si
Thanks Sam all paid now. I'll give my mate your details tomorrow, so expect a call/text from someone called Alan. Thanks again mate
- adamr6698
adamr6698 :Thanks Sam all paid now. I'll give my mate your details tomorrow, so expect a call/text from someone called Alan. Thanks again mate
awsome cheers fella much apreshiated and, once he collects i'll tell you! cheers!
- sam-si
Hi there
Do you have the steering wheel cowl both top and bottom and the steering lock? Is it the same as the early mk3 one?
How much please
How much please
- matteoman
- Your car: mk3 fiesta 1.1/ Ka 220bhp
matteoman :Hi there
How much please
whole steering cowl is gone and the whole steering colum and outer casing are being sold together for £20 if interested cheers sam
- sam-si
both window regs sold
steering cowlings sold
batt bracket sold
1x s-brace sold
body kit sold
interia light sold
dash sold
clock surround sold
rs2000 disks and calipers sold
rear brake lights sold
interia mirror triangle trims sold
gearstick gattor sold
batt bracket sold
1x s-brace sold
body kit sold
interia light sold
dash sold
clock surround sold
- sam-si
- sam-si
alright bss. he ad me today and i'll be digging the stuff out tomorow and he's coming to collect them wed eve!
- sam-si
- sam-si
