Rolling road went right this time
52 posts • Page 1 of 2 • 1, 2
The car went back today, and I stayed with it all the time just to make sure It is now holding about 1.5 bar boost (about 23psi), and is giving no less than 150bhp. No torque figures sadly...it's a pretty old rolling road setup. The picture below shows road speed on the left (about 80mph in fourth) and power at the wheels on the right (it rose over 90 but I missed it). He had to stop as the temperature was climing - their fan wasn't too useful So it's a bit more than 150bhp.
Feels great, but I'm still after more out of it. No problems with the running whatsoever, so I'll be on the case Some pictures...
James.
James.
150 bhp!!!
That is outstanding, well done mate, bet ur well chuffed!!
If I was u tho, I'd go to a decent rollin road and get them to do a graph, then frame the results sumwhere....a diesel to be proud of!
Mike
- mike_wall15
And another thing...I looked at the invoice when I got back to uni today - I was told £150 for the rolling road tune, and it's come up as £250 on the invoice! I will be calling them first thing tomorrow. The guy who worked on it was a really nice guy, I had no problems with them at all, and no grumpiness from them. Only problem is my boost gauge only goes to 20psi Anyone wanna swap me a 30?!
lol I would mike, but I'm not done yet. Will let the bank balance get itself back to the green and plan in the meantime. I am happy though
heeman10 :lol I would mike, but I'm not done yet. Will let the bank balance get itself back to the green and plan in the meantime. I am happy though
Not done yet!!!
Well come September time they'll be another healthy installment of "student loan" and an extended overdraft!! Yeah!
Good luck with it all mate!
Mike
- mike_wall15
Excellent mate Go somewhere else and get a full graph and printout
Commonrail next when you're done with this engine
Gareth
Gareth
- Gaz7
- Authorised Trader
Mike - September, it's on!
Gaz - Yeah I'll be doing a fair amount of research through summer, seeing what can be done with this engine to take it to the next level. Economy's amazing, just need a shedload more torque and some more power and it'll be a good un. Commonrail for 2006 perhaps....we'll see
Once you try CR you wouldn't go back You could make one of those truely fast Take a unit from the Mondeo ST TDCi (out later this year plug plug ) 2.2L I-4 turbo, and tune that
Gareth
Gareth
- Gaz7
- Authorised Trader
Great stuff mate - you'll be snapping on my heels now!
Bloody weasels!
How much you hoping for in the end - so it's going to be more on the road when you're travelling at speed (considering their poor fan setup)
Bloody weasels!
- andyhardy
Your boost guage is going to be having a fit when you drive it lol.
Thats amazing power though, Whats insurance like?
- Smo
- StoveyXR
- Your car: Subaru Impreza WRX
I'm not sure what plunger is in that Lucas pump, possibly around 10mm so i'm not enturely sure what BHP it will support. But I think it's time for a new turbo.
I'd be interested to see a VNT 20 on there, or even a 25 with some headwork, that would broaden the power band nicely as it's a little short with the current unit.
Rawli - I remember that comment about the boost gauge *slaps forehead*
Gaz and Excursion - I'll be looking into what can be done with this engine...I suspect I may be better of leaving it as it is and getting a more modern engine in time. If there are any not-too-expensive ways of getting the torque and power I need, I'll look towards those
Max - They're 90bhp in the Mondeo, mine was about 100 before the tune. Am calling insurers this afternoon - not gonna be nice
Andy - I guess maybe 160bhp on the road with air for two reasons. (1) He had to stop because of the temp build-up and (2) yes, proper high flow of cool air would help a lot. It's torque and revs I need from it really - longer gearbox would make it much more driveable.
Funkylicious! 150bhp.
Hey,just wait till you get a CommonRail Diesel.
Gaz is right they are just awesome, our Signum demo car is a 3.0V6CDti Common Rail, it easily beats the 2.0Turbo Signum.
Better consumtion,better emmisions.
*EDIT*
Spec on engine...
Description: 3.0CDTi V6 24v
Capacity: 2958cc.
Maximum power: 177PS (130kW) @ 4000rpm.
Maximum torque: 370Nm (273lb.ft.) @ 1900rpm.
Compression ratio: 18.5:1
Combined MPG - 38.7
*EDIT*
Spec on engine...
Capacity: 2958cc.
Combined MPG - 38.7
- Brycey
Yeah, Commonrail would be lovely - I'll never say never to that
XR - If you know anyone with one of those, and they want a 20psi gauge, gimme a shout!
Just wondering, is it possible to fit dump valves to turbo diesels, and would there be any point if you can?
- Smo
mark what the bloody hell did you do to that diesel engine....
i was going to put the diesel engine back in another car... i will use a bigger cooler this time to also what size turbo have you used on this ?
- mmogenius
- 2.0 16v Fiesta RS Turbo
Smo :Just wondering, is it possible to fit dump valves to turbo diesels, and would there be any point if you can?
dont see why not....plenty of Golf TDI's going around with dump valves
- Superal
- Location: Waltham Abbey, Essex Drives: Peugeot 206 Work Van
Yeah you can get dump valves, not that I'll be getting one, I like hearing the wastegate. It'll set you back £200-£300 though, as they don't work in the same way as petrol dump valves.
Mmo - I went to a rolling road with it, sadly Mark can't take credit for this bit! It's still using the standard turbo for now (T1.5 I believe), but I'm looking into my options, and want to get things shifting ASAP.
mmogenius :mark what the bloody hell did you do to that diesel engine....
I removed the cat mate, and it's got a straight through 2i exhaust system. The I/C is Saab 9000. There was a bit of pressure drop through the cooler, i'd estimate 2-3 psi so 100bhp wasn't bad - if you put a bleed valve on and did yours bye ear I'm sure you'd get 110.
topstuff dude, these diesels really are making the moves with regards to performance increases over the last few years so respect for sticking with the diesel and not going petrol turbo
now sold but not forgotten!
- 1600power
