uprated brake
4 posts • Page 1 of 1
uprated brake
i Have a set of 2.0l mondeo front brakes for my mk3 rs 1800 what brake hoses do i use and with there be an issue fitting them i do have mondeo 16 inch wheels on it?
and
i also have a set of focus rear hubs and brakes would these fit on my fiesta? if so what handbrake cables and brak hoses do i need for that?
the mondeo brake coversion is the important one atm
Thanks Darrell
and
Thanks Darrell
RS1800 Done and dusted
- Dwayneology
- Your car: Yamaha YZF R1, RS1800
Re: uprated brake
Dependant on the model the mondeo brakes came off you should be able to use the standard brake hoses as the fittings are the same, I've got Mondeo ST24 brakes and they just connected straight up. With big front brakes you'll want the servo and master cylinder conversion done as well though.
Not sure about the rear setup, but I've heard focus rear brakes mentioned with a MK5 fez rear beam to fit correctly (without MWSTEWART levels of welding).
- DanFraser
Re: uprated brake
The discs are.only a little bit.bigger. the calipers are just slightly bigger too off a 2.0l mondy will I need the servo master upgrade
- Dwayneology
Re: uprated brake
The brakes will fit under 16's, no issue, the 278's off an early ST24 I have under my 15's fit fine.
I would definitely do the Servo and Master cylinder upgrade, though you may want to do the brake lines too. I have done everything but the brake lines and I'm concerned about possible bulging in the future though everything is fine at the moment.
- DanFraser
