teamSPB Project D*FN U - 4 SMD 18's,SPL D 25kwrms,16v,Air ri
133 posts • Page 3 of 4 • 1, 2, 3, 4
Re: teamSPB Project D*FN U - 4 SMD 18's,SPL D 25kwrms,16v,Air ri
Heres a quick vid of the mids running no low pass filter on the temp door builds...
Version 2 door builds coming up!
teamSPB
teamSPB
- bassboy
- Authorised Trader
HCS PIMP wrote:Over Kill Perchance??
The same way having a car does over 70mph is an over kill
bassboy
- bassboy
- Authorised Trader
Door builds Version 2!
Now that we know the mids would work the way we wanted them to...I decided to work on a new layout for the doors as I wasnt happy with the rush job I did on the last...
The tweeter builds will remain, but the bottom section of the door card will change...moving 1 midrange from the door to the kick panels...you will see why this was done a bit later...
1 Router bit and LOTS of saw dust later...I was left with this...
Port anyone?! LOL
Time to recess the midrange
Lots of recessing later
A few different layouts were considered...this was the initial one I was going for...
With the above, I was going to have an Ascendant logo in the middle kinda like their 'badge' logo...but decided against it...
This layout was then agreed upon...
Wrapped up...
At this point I wasnt really happy with the desgn and keeping the empty space...The original AA logo idea came back to mind...
teamSPB
Port anyone?! LOL
Wrapped up...
teamSPB
- bassboy
- Authorised Trader
- bassboy
- Authorised Trader
fudgekin epic job your doing there mate.
eagerly awaiting updates!
- Ratspeed
Door builds Version 2.0
Resined and strengthened with matting
For the little 'blank' area, I decided to put a logo there...Initial plans were for a AA logo...
Some sanding later
Test fitting
After a while of thought and putting a few logo ideas down...the AA idea changed into a SPB idea!
These were then flocked!
teamSPB
Some sanding later
Test fitting
teamSPB
- bassboy
- Authorised Trader
- bassboy
- Authorised Trader
nice
- HCS PIMP
- bassboy
- Authorised Trader
- bassboy
- Authorised Trader
Some videos
teamSPB
teamSPB
- bassboy
- Authorised Trader
Niiiiceee Looks like a really good job you done there mate!
Ford Escort GTi
Ford Puma 1.7 ..... in bits for scrap.
- Pumatt
Why?
- FiestaBen
- Your car: Vauxhall Astra Sport
Car: 1995 Vauxhall Astra
I wanted to have a screen in the roof to allow connection of a rear view camera and a DVD player so I could have flexibility in the cabin;
DVD/navigation
DVD/browsing the web
Rear view camera working while driving
Rear view camera/web browsing
Rear view camera/playing music
etc etc
I chose a Veba 'rear view' screen (Veba AV70MM) simply for the shape of it looking like a rear view mirror...having 2 inputs was perfect for what I needed to achieve the above.
Also locating it where an OEM rear view mirror would go would allow me for a 'natural' rear view by simply looking up
First off, make some templates...
Transfer these onto wood and cut out
Assemble
Time to strip apart the screen and flush it into the build
teamSPB
DVD/navigation
etc etc
Assemble
teamSPB
- bassboy
- Authorised Trader
As with everything else....test fit time!
I know its a bit bulky but you adjust to live with it lol! Still have perfect view of the road...and with a bit of know how, its removable just incase I didnt want to have it up
The front section needed a bit of smoothing in
The edges of the roof needed finishing off, so I needed to either get the edges of the standard roof lining (which is now in the bin), or fabricate some of my own....out came some more FG and fabric!
teamSPB
teamSPB
- bassboy
- Authorised Trader
- bassboy
- Authorised Trader
Movie clips from a small open day today...only got 4 or so though
teamSPB
teamSPB
- bassboy
- Authorised Trader
Cant really get a feel for it from vids, but people don't seem too keen
The screen build was flocked and vinyled...
Fitted...playing some Def Comedy Jam....Cederic the entertainer doing his CLASS act!!
Time to update on the amp builds me thinks!
Here is the 2 SPL Dynamics S6002 and the S1200 (which was sold...used the run the 4 8s originally)
Each S6002 is wired to 2ohm per channel, resulting in each amp doing 2 x 500wrms...so 1kwrms on tweeters and the same on the 7's!
Mocking up the board for the S6002's
Lots of timber was cut to create the framework for the amp racks...I was just going to use MDF to mount the amps directly on...but I wanted something a bit stronger to ensure no flex for whatever reason!
These were then knocked up into this
teamSPB
teamSPB
- bassboy
- Authorised Trader
Inch thick MDF added
All 4 sorted
Test fitted
At this point, we were decided on running 4 SPL Dynamics D5's...however, due to a supply problem...we are considering a few options...however, the amp layout will remain the same
For a little while, the amp rack remained like this
Ignore the nasty cabling LOL! Everything was lashed in to make sure it all worked ok and to encounter any potential problems we will see at full power....had a ROCK solid power supply before the batteries were sold though!! 3 x XS Power D3100s!!
Midrange mount removed
teamSPB
All 4 sorted
Test fitted
teamSPB
- bassboy
- Authorised Trader
Remaining parts of the back of the box were carpeted to - although these bits wont be seen once everything else is fitted and the front panels are on etc...I wanted to put carpet onto the mounting surfaces just to make sure there were no vibrations etc
SPL Dynamics D5 was moved up
Remainder of the side panels were made
Carpeted
Some of you may have noticed I complain of voltage issues night and day...in the next picture you will see why pimsle!!!!!!!!!!!
And a rather nice pic of the S6002's
Think it might be time for some TL scores now that everyone knows my power supply and problems LOL!
teamSPB
Carpeted
teamSPB
- bassboy
- Authorised Trader
big_K...heres your demo!!!
teamSPB
teamSPB
- bassboy
- Authorised Trader
- bassboy
- Authorised Trader
Nice plate mate, I get the project title now!
TL Scores coming up! Only off its current guise though...so around 500wrms per driver
teamSPB
teamSPB
- bassboy
- Authorised Trader
Testing when the subs were brand new...Stiff as anything...and no EQing or gains setup
Power approx 2k with voltage into the 11's
Sealed
20 142.5
21 144.3
22 145.4
23 147.3
24 148.3
25 149
26 149.8
27 150.1
28 150.5
29 150.8
30 150.7
31 150.5
32 150.1
33 149.8
34 149.7
35 149.7
36 149.4
40 149.7
45 149
Ill be doing more testing when I get the TL back as the subs have softened up, and its ALOT louder now we have had time to mess around with things! STILL on a CRAP power supply to! The Halfords battery is holding up LOL!!!
Mic on screen, door open results coming up
teamSPB
Sealed
20 142.5
21 144.3
22 145.4
23 147.3
24 148.3
25 149
26 149.8
27 150.1
28 150.5
29 150.8
30 150.7
31 150.5
32 150.1
33 149.8
34 149.7
35 149.7
36 149.4
40 149.7
45 149
teamSPB
- bassboy
- Authorised Trader
Mic on screen, drivers door open
20hz 146.4
21hz 147.6
22hz 148.5
23hz 149
24hz 149.5
25hz 149.9
26hz 150.2
27hz 150.4
28hz 150.8
29hz 151.3
30hz 151.6
31hz 151.7
32hz 151.9
33hz 150.9
34hz 150.8
36hz 151
38hz 151.3
40hz 151.3
45hz 150.6
A few days later ~30hz scores became;
28hz 151.4
29hz 151.9
30hz 152.7
31hz 153
32hz 152.8
33hz 152.8
34hz 151.6
Cant wait to test what its like now...should have gained a small bit here and there..howmuch though, I have no idea until we test again...
teamSPB
20hz 146.4
21hz 147.6
22hz 148.5
23hz 149
24hz 149.5
25hz 149.9
26hz 150.2
27hz 150.4
28hz 150.8
29hz 151.3
30hz 151.6
31hz 151.7
32hz 151.9
33hz 150.9
34hz 150.8
36hz 151
38hz 151.3
40hz 151.3
45hz 150.6
28hz 151.4
29hz 151.9
30hz 152.7
31hz 153
32hz 152.8
33hz 152.8
34hz 151.6
teamSPB
- bassboy
- Authorised Trader
Been getting a few PM's about the car PC setup...basically its a mini ITX type PC complete with touch screen monitor, 4 internal USBs and an external USB hub with external power supply, GPS, 120gig hard drive, Centrafuse interface....bought off Steve off TA with the following spec
voom pc case
Via VB series board VB7001
centrafuse 2 installed
M2-ATX PSU car power supply
cooling fan
3x5m usb cables
soundcard
bluetooth dongle
gps reciever
vga cable
120gb hard drive
usb hub
memory stick with drivers and centrafuse 2
lilliput touchscreen , stripped down for custom fit into double din
Nifty little thing!
First thing was to modify the existing fascia panel to accept the touch screen (not got any photos of the standard fascia with the headunit in)
Primed and guide coat sprayed
Screen secured in
Heres the PC itself...just been sprayed
teamSPB
voom pc case
cooling fan
3x5m usb cables
soundcard
bluetooth dongle
gps reciever
vga cable
120gb hard drive
usb hub
Nifty little thing!
Screen secured in
teamSPB
- bassboy
- Authorised Trader
- bassboy
- Authorised Trader
Unfortunately I havent had time to crack on with this yet...but hopefully will be able to get on with it next week in time for the final VW show of the season (even though it aint a VW LOL!)...and touch wood, we hit the final show with a LOUD goodbye for the winter...hoping to get the Previa, and Blade Ice's Chevy with the 12 18's playing side by side!
In the mean time, ill post up a link to another car we have been working on hoping to get ready for the show to! vw-passat-build-3-ascendant-10s-spl-dynamics-amps-vt186912/
teamSPB
teamSPB
- bassboy
- Authorised Trader
Right not updated this for around a month now and there is a good reason behind that which I shall explain at a later date...
I havent really done much to the vehicle to be honest and I hope to press on with it next week.
The SPL Dynamics D5 I had in there has been sold (well deposit taken)...so this paves way for me to get the SPL Dynamics ICE 3500d's. However, I have the small issue of the charging system to sort out first!
Some boring pics for those who are interested
10g speaker cable front to back - 4 runs per door
Knu Konceptz Krystal RCAs
Also got this handy little machine to print lables
Type in what you want
It prints it out
I can now keep track of what cables are for what! Quite handy when all the cables are braided LOL!
Ill get some more recent pics up soon of the cables neat and tidy
It prints it out
- bassboy
- Authorised Trader
Under the centre console got a seeing to as well
45meters....YES FOURTY FIVE meters of 1/0 Knu Konceptz Fleks cable!!!!
The idea behind the 0g, is basically 4 runs of 0g positive from front to back, and 2 maybe 3 runs of 0g negative front to back to! This is to keep up with the current supply of 3 maybe 4 210a alternators charging at 16-17v!
Ill get some pics of the alts up in a second...they are just repetitive to be honest as I was messing around with a friends SLR camera at the time so thought I would have a play!
- bassboy
- Authorised Trader
Also for those electrically minded...you will probably notice that I have the main fuse holder, which is then connected to a smaller fuse holder beside it...its connected with 20a cable however will never pull that much current...
The smaller fuse box will only be running things like processer (epicenter), rear view camera, parking sensors, remote relay etc etc so should never even see more than approx 10a if that!
Back to the alts!
teamSPB
Back to the alts!
teamSPB
- bassboy
- Authorised Trader
Some video clips from yesterday
[media]http://www.youtube.com/watch?v=mjJmrpaiRDI[/media]
[media]http://www.youtube.com/watch?v=W6Vy27qeSIo[/media]
[media]http://www.youtube.com/watch?v=NGX9WrVBfS0[/media]
- bassboy
- Authorised Trader
[media]http://www.youtube.com/watch?v=LmWEiPEN1Uk[/media]
And one of Mana's Passat
[media]http://www.youtube.com/watch?v=FAr1_IiUKD8[/media]
teamSPB
teamSPB
- bassboy
- Authorised Trader
