Russ' mint green FRST , update :)
Re: Russ' mint green fezza
glad to hear u got it sorted.
look forward to seeing new pics
- fezza89
glad its done now tho cos i'd b fcuked if i could think of anything else
b good to c it runnin now
- frst toady
- Your car: ranger super cab, frst t3
yaaay its always something silly like that
once i couldnt get my 18 goin gin my mk4 [ERRR] i forgot to reconnect the fuel pump trip switch
Awesome Russ, great to hear! I could only do so much at the time and it sounded like the injectors were clicking at the time, but obviously not
Glad you've got it sorted and glad it was something so simple in the end
- Smo
thanks for all the support guys and advice its been a real help and kept me going with it
and as always special thanks to simon for coming over on the cold days and rackin his brain for ideas
its all go now for saturday so hopefully by saturday eve i should have her at home and bathed and some pictures and videos
cant wait!!
one thing i was bemused about: i went into ford today(well my mum did
) and spoke to the manager about gettina gasket to go between the turbo and the zorst manifold and apparently they didnt do a gasket for it its just a face to face contact... sounded abit strange to me as it looks like it should have a gasket
just wondered if anyone could confirm this doesnt need a gasket or the ford bloke was chattin sh*t
either wway il try it without one even if it still blows im driving it home
- russ-RST
- Your car: fiesta rs turbo
most turbo flange - downpipes dont mate, we have many turbo examples at college that we strip and they dont have any either
i was also amased to see they use hex bolts, id have though they'd use something a bit more heat resistant myself
no i mean the contact between the turbo and the manifould (on top with the 3 bolts going through it) if that makes sense
- russ-RST
hmm, not sure on that side, doesnt seem that inportant
Re: Russ' mint green fezza, Now things are started :D
its alive!!!!
found out the blow was coming from the downpipe part that bolts to the turbo id forgotten to put back in the small bolts in it
lol
so off came the turbo and everything to gain acces to these chucked it back on filled with water and voila!!!
its a bit loud and smokey but its its first proper start up and its got a s/s scorpion from the downpipe back on it
anyway as promised heres some videos:
(sorry for the crap quality its on my phone :rolleyeyes: )
- russ-RST
tidy m8 bet u had a grin like a cheshire cat when it was finally runnin properly
- frst toady
Lol sound saying haha, glad its all[list=][/list] going well, ain't you a bit concerned to wether it cqn pass an not emissions test since its a post 92 red car? It's the reason why the rst cvh was discontinued
jonyb4 :Lol sound saying haha, glad its all[list=][/list] going well, ain't you a bit concerned to wether it cqn pass an not emissions test since its a post 92 red car? It's the reason why the rst cvh was discontinued
im sure il find some way around that
and i had a bigger grin than a cheshire cat matey i was well happy
- russ-RST
I'm sure older engines in later cars can pass the MOT, i.e. if the engine is pre August 1992, or something along those lines. You may need to prove it though...
- Smo
i havent a clue on the subject to be honest with you mate but i know of a few people that know of a few mot people that are silly enough to put the emissions tester up the wrong car if u get my drift
so i dont think of it as a problem at the current moment
drove it home today
im never going naturally aspirated again
i love the boost and the noise is awesome
will try and get a few vids up of it on drive bys and tunnel runs
only a few problems that iv found so far 1: the speedo isnt working properly its jumping between 10mph and off the clock
any ideas on what this could be??
it used to bounce before but was only about 5mph max of a wobble, think im just going to get a few gearbox sensors from a scrappy and try them and if that doesnt remedie it then get a new cable
and 2: the car will charge the battery sometimes and then over times itl be flat as a pancake
im thinkin towards a combination of the battery has been run down over the conversion with the constant turning over and not actually being aloud to run properly and the connection where the cables from the alternator bolt to the starter motor looks a little minging so il have those off tomorow and give them a good wire brush before work and charge the battery up if i can find my charger
and then see what its like at holding its charge, the thing is it will sit idleing all day long and wont cut out bog down etc, and sometimes u twist the key and it starts straight up no probs and other times the battery is flat and it just ticks, if these two solutions dont solve it i shall get the current tested to make sure that the system is charging the battery and if so then shall just get a new battery
all in all a reallly good day for me and ican sit outside looking at my car now
hopefully i can wash it and sort the problems out within the week and post up a few pictures and maybe a video or two
drove it home today
- russ-RST
yeah get some pics m8 b good 2 c wot it looks like now,
and no-in wot problems there been i'd prob say it was the wiring again
check all the other earths when u do it, make sure there no other s**t 1's cos they all ad up...
by the way u got dump valve or u staying chatter (chatter sounds the funlumps on me T3
- frst toady
chatter alll the way buddy i cant get enough of it
it sounds awesome
really tempted to go for a drive with it now
- russ-RST
just being put off with the fact the speedo doesnt work and i havent changed the cambelt yet so im not sure on whether to risk going for a lesuirely drive
- russ-RST
sod it im "going to get petrol"
- russ-RST
lmfao u dont need a speedo long as u can hear that chatter chatter chatter
- frst toady
although i have found out that it likes to randomly everynow and then cut out when i come to stop lol, but if i dip the clutch and grab a gear before it dies its fine
- russ-RST
Re: Russ' mint green FRST :D
check your breathersand filters , i had this with my 1.3 and it was lack of air flow.
worth a try
someone else here mite have another reason why its happening
worth a try
- fezza89
yea i shall do this whilst its warming up before i take it to work tomorow i take it all im doing is feelin to see if theres air blowin out of one of the vacs or a leak/crack in them?
- russ-RST
yeah just make sure u have a good flow of air, mine done the same, everytime i stopped at lights it went to conk out, had 2 keep the revs up all the time. cleaned all my breathers and filters and the thing was sorted.
hope its a simple fix like mine was
- fezza89
il have a little looksy tomorow before work then
cheers for the tip matey
- russ-RST
im willign to bet your battery connections aint as tight as theyre meant to be, or alternator/start if that...
its really easy for the batteries connectors to be loose and be overlooked, you'd think they not havr to be 100% tight but, they do
the starter relies on all the charge it can get to just start spinning, thats when if you fail to give it enough juice, you get a fu*ck you, aka a click
another thing, when i put the 1.8 zetec in my mk4 fez, i used the same gearbox, but my speedo would bounce and only read half, i never found out why
mate you really can not type
frst toady :yeah get some pics m8 b good 2 c wot it looks like now,
by the way u got dump valve or u staying chatter (chatter sounds the funlumps on me T3)
jonyb4 :im willign to bet your battery connections aint as tight as theyre meant to be, or alternator/start if that...
its really easy for the batteries connectors to be loose and be overlooked, you'd think they not havr to be 100% tight but, they do![]()
the starter relies on all the charge it can get to just start spinning, thats when if you fail to give it enough juice, you get a fu*ck you, aka a click![]()
Pot - Kettle - Black???
Looking forward to seeing this around matey, if you see a red octavia vRS with a guy waving at you, it's me!
- bakewell001
exactly that... pot - kettle - black
if got something to say bout some1s typing bud
make sure your own is a1 cos u made yourself look a lil bit silly there......
i was only askin bout the chatter, and saying bout the wires cos of earlier earth wire issues the fella had wernt asking for spellin lessons
- frst toady
wtf is pot kettle... etc
did you not notice the time i typed that? it was late and i was tired, typos expected
you just simply cant be arsed with correct working nor typing
dick
thanks for the second piss take of the month there bakewell...
dick
basically pot kettle black is a sayin mean look at yourself cos u jus took the piss for exactly the same as wot you said about
and ahh boo hoo tired lil boy get mummy put u bed earlier then
and u mean wording not working
, done it again so early in the evenin....i no i work properly...
and err if you want to b proper funny you dont use punctation so errr call me a dick.. take a good look in the mirror bud
it aint got nothin to do with this blokes motor so why even comment in first place??
- frst toady
Now now children, this is a car topic not an english lesson. You have both made mistakes with spelling/wording etc. Its things like this that ruins the site
- rs220bhp
totally agree in a sense
just cant see why it had to be said in first place
- frst toady
nope i stand by your just a dick who cant be arsed to add a few more letters to each word...
and now you try the childish insulting me about age card
so sad
so whats your point then im sad cos i dont spell..... right o p nut
keep it about motors thats wot the site is about who give a fk how every1 spells well apart from u
long as ppl can understand what i mean whats the prob gammon slipper
- frst toady
I hope a mod can delete a few of these posts because this keeps happening in peoples' project posts and it's a bit silly.
Glad you're enjoying it Russ, I'll have to keep an ear out for you
I'm sure you'll sort the problems easily enough. Most CVH bits are pretty cheap second hand these days, so if you need anything it's not going to cost you the earth!
- Smo
Fukkin el jony wots your problum? jst Bcoz He drps a few vowals ot
I cant stand TXT spk either jony, it makes my eyes hurt trying to read
Oh, and awesome news on getting it running mate!
- Ratspeed
