rsonblackwheels Fiesta RST, Feature pics.
Re: rsonblackwheels Fiesta RST,Small up-date 9/9/09 lil video
sounds good atleast it was a simple fix
- jonboisescort
Car: 1994 Ford Fiesta
nice one mate whats the handling like
- Xr_Dub
looks well on the track, keep up the good work
- corrupt_panda
- Your car: Fiesta RS Turbo
corrupt_panda - thanks dude will do
Xr_Dub - handles quite well on trac, not as under steery as would be expected with 221hp but i think the Quaife ATB helps that, awesome mod for FWD the more you put you accelerate the more it turn's in. should be better after the winter going to get soem area6 lower arm's on it and i could do with some new front amd rear tyres, so should be able to find some more grip.
up-date coming soon, just got the gearbox out for the paddle clutch and few more lil jobs
- rsonblackwheels
Looks and sounds awesome on track mate
Glad to hear you got the problem sorted too, I've never heard of that before either!
- Dave G fsi
- Your car: Mk1 FRS and FRST
bit of an up-date, as the weathers taken a turn for the worse its up on axle stands for a bit
and in bits
dropped the gear box out to do the paddel clutch and a few other lil jobs
the slipping clutch
mmmmm technie clutch
fly wheel in need off a skim
box cleaned and ready for paint
and after the 1st coat
clutch arm and support bar thingy getting some 'ammerrite
got some area6 lower arms coming in the post (if the postman ever comes off strike ) so removed the hubs and drive shafts
took off the roll bar links to freshen them up on is knackered and the other didn't wanna come off with out a fight, both need replacing now. also removed the roll bar bush's to replace them with polybushs and gave the roll bar a clean up
also recived my flo-flex front strut top mounts to day
flo-flex on the right
old - they pretty much fell out
new - lots of fun to try and squeeze in, even made me sweat!!
sooo tomorrow when i finish work got to clean-up the Spax, spray the roll bar clamps and then some more cleaning
then got to go collect the AP paddle clutch and pollyflex bushs from TOTD on wednesday
and in bits
the slipping clutch
- rsonblackwheels
top work as always.
when u put the top mounts in did u cut them on one side. would've been easier that way.
- Minstral
- Your car: *
Good work fella, You'll be painting the underside next
- Turboboy67
- Your car: 911GT3 RS
Good work mate, your doing a brilliant job there! I love everything about this car, its almost like my idol lol!
What did you paint the gearbox with? Is it just silver hammerite?
Keep up the good work mate
- Dave G fsi
Nice work fella
you will be pleased with the 4 paddle ap clutch but be warned it does make a wine in 1st gear and reverse
put a new clutch cable on while its all out. Makes the pedal nice and soft. My old cable was so stiff in comparison ...
is that a plastic hose joiner dude ?
if it is i advise you swap it for a alloy one or some copper pipe.
I had a plastic hose joiner going to my turbo coolant pipe and it split on me as it gets hot and cold over and over again and ends up becoming brittle and eventually cracking.
knuckles
knuckles
- knuckles
- Your car: Fiesta Rs turbo
thanks for the comments guys, going to hold off cleaning the Spax as Dom's got the spring compressers and hes on holiday in Cornwall (lucky git)
minstral - nope didn't cut them, didnt think of that just swore lots and struggled instead. Got abit of a technique after the 1st side though
carbonboy67 - yeah its crossed my mind ecspecialy when you see some of the projects on here, like yours and Dave G fsi's lots of insperation
Dave G fsi - thanks dude, its not hammerite its some stuff i found in my local motor factors made by CarPlan, just called alloy silver paint i think i'll check tomorrow though
Knuckles - i was thinking about doing that while its out and theres abit more space, i take it you used a genuine Ford part? any idea how much one would set me back? well spotted with the plastic joiner too dude, its been one of those temporary things thats kind of got forgoten about i've got to get it sorted befor it goes back on the road now
thanks again people
thanks again people
- rsonblackwheels
Ah rite cool, looks really good! I'm going to do my gearbox the same as that before I refit it
- Dave G fsi
spoke to TOTD today and they said AP Racing have just released a Hi-Tourque version so no need for a Paddle so i'm going to try it out and see what happens, it can deal with 285 ftlbs of torque so my current 222 should be no problem
some pics will follow when i have it
- rsonblackwheels
Sounds good mate, look forward to the pics
- Dave G fsi
collected the new clutch from TOTD on wednesday morning
not sure how well this will show up but it even says AP on the rivits
also picked up the pollybush front roll bar bushs too and found the ACT gauage i've been meaning to fit for ages
got they fly wheel at the same time and finished painting the roll bar clamps too
and these turned up in the post, thanks scott
did a bit more yesterday afternoon and got the fly wheel on with new bolts
in the process of tourquing up the bolts i fort i snapped one off in the crank but turns out it was a cheap tool shuold of just put the 1/2 inch 17mm straight on but couldn't see it at the time
after finishing work today went and collected the new ball joints for the lower arms and then fitted the clutch, i'll get some more pics up soon
- rsonblackwheels
you used a 3/8 drive to touqe up
still if its a halford pro adaptor take it back for a new one free of charge
Looking good mate. Bet you were pleased it was the socket and not the bolt that sheared!
- Dave G fsi
all good mate... keep the updates coming...
- FRSJON
jayrs - affraid so dude it was the one that came in the box with the tourque wrench too
Dave G fsi - oh yes mate, very pleased. i was all like then saw the adaptor and was like
- rsonblackwheels
it wasnt a argos one wqas it by anychance
no wasn't argos mate got it when i was still an apprentice at Renault/Hyundai the technican who i worked with for a year donated it to me
also found this the other day
oh dear crack/fracture/split in the Scorpion system. must be because the down pipe hasn't got a compensator in it any more so going to get it repaired & have by a flexi joint welded in
got the gear box back in when i finished worked on Sunday afternoon with help from RS1800dom, cheeRS dude, got it bolted back in then called it a day so we could watch the Grand Prix (Button Champ09 )
- rsonblackwheels
Re: rsonblackwheels Fiesta RST,Small up-date 20/10/09
well it was a freebe so its all good then
Great work mate...well impressed with your hard work!
Keep us posted
Keep us posted
- gcodin
been playing down the garage again this weekend
bought one of these a while ago
TiAL MVS external wastegate 38mm, very nice bit of kit
so bought another escort manifold off ebay and got TOTD to modifie it for me, Allen did a wicked job
and some other bits and pieces
had a quick test fit this afternoon
with the screamer pipe/dump tube heading for the drivers side of the front bumper the turbo cooler will need fitting somewhere else so i was thinking
one of the mounts needed grinding down to make it fit but my fun was rained off b4 i could get it finished but will carry on tomorrow, so will hopefully have some more pics up then
- rsonblackwheels
rsonblackwheels wrote: Knuckles - i was thinking about doing that while its out and theres abit more space, i take it you used a genuine Ford part? any idea how much one would set me back? well spotted with the plastic joiner too dude, its been one of those temporary things thats kind of got forgoten about i've got to get it sorted befor it goes back on the road now
i got my brass hose joiner from work - it was a air line joiner
but ive noticed yours is a 3 way joiner. so maybe look around a hard ware store or even plumbing supplies may have something simerlar to suit your needs.
What does that swirl pot do anyway ? excuse my silly question ... its been bugging me for a while what that extra bit is for lol
TOTD are awesome arent they !
im hoping to go down there this week and get mine set up - May wack the beiges in with the 195 chip before i go
- knuckles
Re: rsonblackwheels Fiesta RST,Small TiAL up-date 5/12/09
nice one screamers are awsome
great work mate
great work mate
- jonboisescort
cheers dude
Knuckles: good idea mate, i've seen 3way joiners on ebay, fuel pipe joiners . swirl pots are used to get any bubbles/air out of the cooling system, they should have 3 conections, an inlet near the top, a vent at the top and exit at the bottom normaly at diffrent angle to inlet. as the coolant comes in the inlet it swirls around to the outlet and any bubbles/air should vent out at the top back to my header tank. they are also used in fuel tanks too to stop fuel surge or any bubbles going up your lines
TOTD are fantastic, i've been using them since they opened and won't take my RST, MK5 Zetec-S or Civic VTI any where else. gr8 blokes heard mixed views about beiges and 195 but i'm sure TOTD will help you out dude
- rsonblackwheels
Nice one mate, keep up the good work
- Dave G fsi
Looks wicked look forward to seeing this finished
2014 Fiesta ST3 & Mk6 Fez ST
- mrorange2
Looks great fella!
Keep up the good work and keep us posted
- gcodin
Looks ace! The cooler might look better suited of the inner bit of the bumper was black too, other than that, would look cool
- - Danny Boy -
- Your car: Fiesta Si 2.0
looking good mate.... can i ask how much the wastegate mod/piping cost from totd?.. cheers...
- FRSJON
Don't know how I've missed this thread! Looks like a really clean project, I like how you clean/paint things before they go on the car
Get a video up of the screamer pipe if you can
- Sphinx
Gwaaan with the screamer pipe! get ready to melt your bumper
- Ram
thanks for comments guys
Danny Boy - the inner bit will be painted black b4 it goes back toghther as will the the other side, not sure what to put over there yet
sphinx - i'll get a vid up as soon as mate
Jon - got the wastegate of internet for just over £200, can't remember labour cost at the min but will let you know
Ram - oh yes mate, the bumpers ready and willing, i seem to cut more and more away of it every year thinking about a carbon fibre suround maybe that will help
more pics soon hopfully
- rsonblackwheels
