Recent Site Downtime
50 posts • Page 1 of 2 • 1, 2
The site has been going down for the odd ten minutes at a time over the past few days. It has just come back on after about fifteen minutes of getting the usual internet error message saying the website is experiencing difficulties etc. This has been the fifth time today that I have counted.
Is this a temporary thing, as I was under the impression the new server last year would solve these issues?
YRN Thread - yrn-vt151433/
- Ollybee
Car: 1996 Ford Fiesta Quartz
- dontpannic
Re: (6th March) Recent Site Downtime
I haven't seen it personally, though I've read a few posts that suggests it is happening. I've no idea why either I'm afraid
Nothing to see here...
- andymac
- Elite Pie Master
I haven't noticed anything today, however I haven't been at work (on here) all day!
- Ollybee
Re: (8th March) Recent Site Downtime
8th March.
It's just come back on line. It went down at 1207hrs and came back to life at 1224hrs. I don't think it's at my end as other websites load up and load up quickly.
- Ollybee
Also went down at 1407hrs but I didn't see what time it came back on. However was down at 1558hrs as well.
- Ollybee
Re: Recent Site Downtime
It's just come back online today. Went down at 1646hrs and came back up at around 1709hrs.
- Ollybee
Out of interest, are you using your ISP's DNS or say, opendns to resolve hostnames ? It could be glitches / problems with DNS rather than the site ?
OpenDNS servers are at :-
208.67.222.222 and 208.67.220.220.
- andymac
- Elite Pie Master
I have absolutely no idea what that means!
I can operate a keyboard and plug a hard drive into a motherboard, that's where my computer expertise ends.
- Ollybee
When it happens, resetting my router seems to work.
Does anyone know why it would only block ft.com though?
- Ollybee
mine keeps going down to mate but other sites work fine, went down last night about 6-7ish!??
- dangerousdave
Oh rite so it might not be my router then.
- Ollybee
no i been having occassional trouble with it for a couple of weeks now mate!
- dangerousdave
same here for the last 2 days....
- upnorth
Mine's been fine here now. It went "down" if you like using IE at a mates house, but came home and it was working straight away in Firefox...
- dontpannic
Again odd, because I was on much of the evening last night and never noted an outage.
A DNS server is computer systemf that turns a "hostname" (e.g. http://www.fiestaturbo.com) into an "IP address" (e.g. 192.168.1.200). If the DNS server can't be contacted then you can't turn hostnames into IP addresses and the computers can't communicate.
A quick and easy test is to try "PING"ing a computer on the net (kind of like a sonar "ping"), this will test if DNS is working and that traffic is making it out. The ping sends a message out to a specified computer requesting a response, unless the computer has responses to pings blocked by a firewall (or simply disabled on the computer) it'll send a message back in response.
This is dead easy to do, just open a command prompt (Start menu then run, or press the windows key and "R"). Then type "CMD" (leave off the quotes) and press enter. A black window should appear. Now type...
If DNS is working, you'll see something like...
if not, you'll see something like this...
If you get the "could not find host" message try this...
This is a router at my workplace that's permanently connected to the internet, it's a good test for connectivity because it's ALWAYS on. If you get replies then the net's probably working.
Make some notes of this above then try it when it goes wappy and post the results up when it's working.
Oh, to close the command prompt window click on the cross at the top right or type "EXIT" and press enter.
- Code: Select all
ping www.fiestaturbo.com
- Code: Select all
Pinging www.fiestaturbo.com [85.91.227.78] with 32 bytes of data:
- Code: Select all
Ping request could not find host www.fiestaturbo.com. Please check the name and try again.
- Code: Select all
ping 213.249.137.10
- andymac
- Elite Pie Master
Nice one Andy, very helpful and informative, I shall do this.
Oh, and in response to your last comment, please extend your middle finger and place it up your bottom.
- Ollybee
Ok, I've only just been able to get on this morning since about 0620hrs. Here are the results.
- Ollybee
Looks to me to be a problem at your end of things. We've had no issues here with the server or the network and looking in the logs I can see plenty of access still going on at the times you are having trouble.
What ISP are you on?
Also, pinging won't work, as pings are blocked by the firewall. Next time you can't view the site, do an nslookup on fiestaturbo.com (same as a ping but type nslookup) to see if you get the IP back, also try a traceroute (same again, but type tracert) to fiestaturbo.com, but this should stop at firewall-b.1steasy.net.
Also, try and view rewards4.com, as that is on the same network.
The only downtime we've had has been on Wednesday mornings when the server has frozen during the backups, we're looking into how to stop this happening.
- AdrianFRST
- Baby Battle Scratch
- Your car: ..? Pretty car..!
Car: 2010 Ford Focus RS
OK Ade, cheers for the response.
- Ollybee
@Ade - Yeah I noticed packets were dropped, was going to move onto traceroute-ing the webserver next if it was resolving correctly. I'm in agreement re the ISP - I've had similar effects before when I had multiple IP's attached to my BB account. They never worked properly so ditched them a couple of months ago.
@Olly, since you can turn http://www.fiestaturbo.com into an address, the next thing to check (when it's broken) is the route to the webserver. To do this, get he command prompt open and type
This will then try to trace all the way from your computer to the webserver that hosts fiestaturbo. You should see something similar to this...
I pressed Ctrl-C at hop 12 as there wasn't going to be any more information to be had, hopefully you should get to firewall-b.1steasy.net at some point, if you don't then there's a routing problem somewhere. If you do, well, we'll have to think harder
- Code: Select all
tracert www.fiestaturbo.com
- Code: Select all
Microsoft Windows XP [Version 5.1.2600]
(C) Copyright 1985-2001 Microsoft Corp.
C:\Documents and Settings\Andrew>tracert www.fiestaturbo.com
Tracing route to www.fiestaturbo.com [85.91.227.78]
over a maximum of 30 hops:
1 3 ms 2 ms 1 ms home [192.168.1.254]
2 31 ms 31 ms 30 ms l1.ar21.f2s.gs1.dsl.pipex.net [62.241.167.241]
3 33 ms 31 ms 29 ms ge-2-0-1.2.cr01.gs1.dsl.pipex.net [62.241.167.57]
4 122 ms 32 ms 246 ms pc24-102.cr05.tn5.bb.pipex.net [62.72.139.109]
5 109 ms 30 ms 33 ms 503.ge-1-3-0.mpr1.lhr2.uk.above.net [209.249.203.137]
6 95 ms 31 ms 32 ms 213-152.240-110.PXu259.above.net [213.152.240.110]
7 48 ms 49 ms 60 ms ge-3-0-0-0.raphael.as34270.net [85.91.232.2]
8 40 ms 38 ms 39 ms ge-0-2-0-0.rembrandt.as34270.net [85.91.232.6]
9 36 ms 39 ms 38 ms firewall-b.1steasy.net [85.91.226.126]
10 * * * Request timed out.
11 * * * Request timed out.
12 * ^C
- andymac
- Elite Pie Master
Nice one, I'll give that a whirl.
- Ollybee
So what does all this mean then?
- Ollybee
A bit later on.......
- Ollybee
- Ollybee
Ollybee wrote:So what does all this mean then?
Its the names of the routers your internet traffic is passing through to get from your pc to fiestaturbo.com, but to someone technical it can tell you where things maybe going wrong.
http://en.wikipedia.org/wiki/Traceroute#Uses
- JamieFRST
- Keep It Tidy
OK the site has been down all morning and I haven't been able to get on from either home or from work until now so I guess that kind of rules out my router.
What's going on then because this is really annoying and I thought we pay a subscription now to stop this happeneing.
- Ollybee
As Ade said you wont be able to ping fiestaturbo.com because it is blocked by the hosting companys firewall, but it does show your isp's DNS is working because it resolves the ip 85.91.227.78
The first few tracert's look ok, because its showing the hops for everything upto firewall-b.1steasy.net, after that it wont get a reply. But it does mean if the site isn't loading its something inside the hosting companys network possibly.
The last tracert you done, looks like there is a problem else where on the internet because the hops didnt make it to firewall-b.1steasy.net
Next time its down try :-
AdrianFRST wrote:Also, try and view rewards4.com, as that is on the same network.
- JamieFRST
- Keep It Tidy
MixonFRST wrote:Next time its down try :-AdrianFRST wrote:Also, try and view rewards4.com, as that is on the same network.
Ah yes, I forgot about that!
- Ollybee
Just to say I'm also experiencing similar things - not as often as Olly, also on an ex-ntl connection. This doesn't figure though as the other morning I couldn't access it via Synetrix either. So that's two ISP's definitely doing the same things.
Nick
Nick
- dontpannic
I am having a lot of problems, every other page can't be accessed or can't be found.
I have this problem at college to so its not something to do with my network.
dontpannic wrote:Mikey B knows as much about directions as a chinchilla knows about tapdancing!
- M1K3Y_B
Car: 1996 Ford Fiesta Classic
Ive not had any problems and i'm on here alot at all different times. Very odd.
Best to make a note of the time to see if there is a trend and try the other site Ade mentioned further up the post. The more info there is the better chance of getting to the bottom of it.
- JamieFRST
- Keep It Tidy
Ollybee wrote:OK the site has been down all morning and I haven't been able to get on from either home or from work until now so I guess that kind of rules out my router.
Progress !!!
If it does this again, let it time out a few more times before cancelling, just in case it finds another router. Looks like the BT router there is dropping the ball somehow (hop 3).
- andymac
- Elite Pie Master
I've not had any probs for the last few days but I've not been on as regular as normal. However when it last went down I could get to the other site.
- Ollybee
Sods law this.
About two mins ago ft was unresponsive, probably a glitch, but....
Ade, has the webserver stopped dropping packets now ? Just noticed it's now responding through the firewall...
- Code: Select all
1 4 ms 2 ms 1 ms home [192.168.1.254]
2 31 ms 31 ms 31 ms l1.ar21.f2s.gs1.dsl.pipex.net [62.241.167.241]
3 30 ms 29 ms 31 ms ge-2-0-1.2.cr01.gs1.dsl.pipex.net [62.241.167.57]
4 31 ms 31 ms * pc24-102.cr05.tn5.bb.pipex.net [62.72.139.109]
5 93 ms 35 ms 31 ms 503.ge-1-3-0.mpr1.lhr2.uk.above.net [209.249.203.137]
6 33 ms 31 ms 31 ms 213-152.240-110.PXu259.above.net [213.152.240.110]
7 146 ms 52 ms 51 ms ge-3-0-0-0.raphael.as34270.net [85.91.232.2]
8 39 ms 39 ms 39 ms ge-0-2-0-0.rembrandt.as34270.net [85.91.232.6]
9 38 ms 39 ms 37 ms firewall-b.1steasy.net [85.91.226.126]
10 40 ms 38 ms 40 ms server.fiestaturbo.com [85.91.227.78]
Trace complete.
- andymac
- Elite Pie Master
