Mk3 Fiesta 1.1
17 posts • Page 1 of 1
Mk3 Fiesta 1.1
I have a 1.1 fiesta its my first car so I am new to all this,
Can anyone suggest a cheap and effective solution to get more power out of it??
Any help is appreciated,
- festy11
- Your car: Mk3 Fiesta
Re: Mk3 Fiesta 1.1
No offence mate, the only efficient and cheap method of getting more power out of it is to change the engine.
- RSGeorge
- Your car: Saab 9-3 & VW T4
Re: Mk3 Fiesta 1.1
None taking, But for insurance reasons it has to be a 1.1 lite FOR NOW
- festy11
Re: Mk3 Fiesta 1.1
The only thing I've done which was a tiny bit noticeable was to take the standard pipe off the airbox and put a bigger flexible pipe on instead and extend that to somewhere there's cold air have a look on my thread too see what I mean . Also you could get a head off a 1.3 and put that on as they've got bigger valves ( you could also do a diy port and polish before you put it back on ) , also don't bother with de cats as it will make your car sound like a tractor don't bother with bigger back boxes either when I put my standard one back on the car seemed abit more responsive
- jakerowles
- Your car: pulse adrenaline 125 / klx650
Re: Mk3 Fiesta 1.1
Hi everyone,
Does the head off a 1.3 fit? Does it have same holes? (water circulation I mean)
Thank you
Thank you
- ADIMK3
Re: Mk3 Fiesta 1.1
ADIMK3 wrote:Hi everyone,
Thank you
i cant say for sure but i think they do fit theyre the same but have bigger valves so you may get abit more power , get a 1.3 head injector unit and ecu and that would give abit more power, only worth doing if you can get it all for cheap though
- jakerowles
Re: Mk3 Fiesta 1.1
It's not worth doing anything to it, a 1.3 head would give less power from lost compression. Just leave it until insurance goes down.
- MB7201
- Your car: Fiesta lx
Re: Mk3 Fiesta 1.1
I have a mk3 1.1 aswell and can get 105mph out of it on flat or 105 downhill.
all i did was put a sportier backbox on, and drill about 4 holes on the side of the dustbin and the back
- Tommm.Mk3
- Your car: Ford Fiesta Mk3 1.1 Azura.
Re: Mk3 Fiesta 1.1
Is your 1.1 carb or CFI ?
I can't stand people who say to us young one's (No point, get a bigger engine, ECT)
>>1.3 head will give you a better/smother rev range and may give you a very slightly better BHP.
>>If you have the carb engine then there is a number of different twin choke and twin carbs routes you could go down to gain BHP and awesome noise
>>1.3 engine is a straight swap in and can be done in a matter hours.
>>You could also have flywheel and crank shaft lightened and balanced for around £140 and it will rev alot quicker and smother.
>>Cylinder head porting is another worthwhile option that will have noticeable gains.
>>Exhaust systems also give you around 4BHP all mk3 fiesta exhaust's will fit as the hangers are in the same place, but you may have to join the sport system to your manifold or cat your self by welding of flaring the pipe and using an exhaust clamp,
>>Puma sport used to make a 4-2-1 manifold for the 1.1 and 1.3 engine, I have messaged them 3days ago to see if i can still get hold of one, You could also make one your self using a 4-2-1 from another car and welding it to the flange of your existing manifold, Or have one made for you.
>>I have a mk3.5 fiesta 1.3 CFI (Single point injection) and i am planing on converting it to EFI (Multi point injection) like the ford KA's then il turbo it useing a T15 turbo from a Diesel, this could be done to yours also as they are the same engine.
>>Also handling is well worth looking at as many small engine race cars focus on making there car handle as good as possible as the less yo have to slow down for a corner the less speed you have to build back up
(I.E Polly bushes, decent lowering springs, brakes, tires).
>>13" or 14" wheels are the best size to give you decent acceleration and speed, wouldn't recommend anything wider than a 6.5J as anything over the 185 tire size there becomes so my friction on the road and start's slowing your speed back down, On 15" wheels my 1.3 struggles to hold a wheel spin and feel gutless, but my new 13" steels feel great.
>>Keep the rocker/tappets in adjustment, Or else your engine will under perform and make a horrible tapping noise
(inlet - 0.2mm Exahust - 0.4mm)
>>A good service also helps ALOT good plugs (Champion EON3). Recommend oil also helps performance and keeping that engine quite (5W-30) or for a high mileage engine (10W-40) Oil filter, Fuel filter, 7mm or 8mm Leads, Air filter, also make sure all components of your distributor are in good condition, Most of the above can be brought at Halfords.
>>Air filters give a nice noise and help flow there for helping BHP, For EFI there is a wide range of Cone induction filters, For carb and CFI you can purchase the old style metal K&N filter that make the car sound RUDEEEE and much more responsive.
>>I also have a friend with the same engine and he has just fitted bike carbs, And i have already called dibbz on the carbs and manifold as he is planning a 1.8 upgrade soon. Here is a vid to show what they sound like BEAST
http://www.youtube.com/watch?v=H0fcltg9U1s
This is just a few things you can do, There are many other modifications so don't listen to that s**t people give you saying (YOU CAN'T DO ANYTHING) But a main factor to tuning small engine small cars, is handling and weight, as the lighter the the car the less the car has to move, there for the faster it will get to it top speed, Hope this helps alot of you out there and gives you abit of inspiration to try out different things with you Valencia/HCS/Endura-e engined cars.
If you need any help pm me.
KIEREN
KIEREN
- Kieren
- Location: Letchworth Garden City, Hertfordshire, England
- Your car: mk2 fiesta, mk3 fiesta SI.
Re: Mk3 Fiesta 1.1
Depends on the circumstances really. If you can get parts cheap it might be worth it as a pratical exercise, but when you can buy a 2.0 engine and the parts to put it in for less than the price of new full exhaust system for the hcs it puts things in to perspective. For myself it was also about the same to insure a 2.0 than the standard 1.1 carb engine.
- MB7201
Re: Mk3 Fiesta 1.1
- MB7201
Re: Mk3 Fiesta 1.1
But for us at 17,18 and these days even 19 insurance is through the roof, £4000 on a 1.3 1996 ford fiesta, FULL standard and i have a SPYBALL thatch alarm fittet
- Kieren
Re: Mk3 Fiesta 1.1
Kieren wrote:But for us at 17,18 and these days even 19 insurance is through the roof, £4000 on a 1.3 1996 ford fiesta, FULL standard and i have a SPYBALL thatch alarm fittet
so hows tuning a 1.1/1.3 going to help you,
tbh mate id love to see half those mods you mentioned actually make a real difference to a 1.1, short of a turbo none of them would gain more than 5bhp, its a costly deadend to tune the 1.1/1.3
and no offence to the guy who made the thread, he sounds young, so money and experience isnt on his side
i was there myself at 18 asking how to make mine more powerful, i was told by a forum member not to bother, go out and to buy myself a 1.6 Si and enjoy that instead, havent looked back since
not even that much of a insurance cost difference between the 1.1 mk3 and a 1.6 mk3 Si anyway
Re: Mk3 Fiesta 1.1
Kieren wrote:I can't stand people who say to us young one's (No point, get a bigger engine, ECT)
Fair enough...
Kieren wrote:>>1.3 engine is a straight swap in and can be done in a matter hours.
Bu... bu... bu... bu...!
It's fair to say though, that the ROI is insignificant on a 1.1 - people have done mad, mad things with HCS engines in the past (turbo conversion thread somewhere I think) but really it's a case of throwing money at something to be unique as opposed to get significant power gains. Remember, 10% improvement on 50hp is less than 5% on 115...
If you wanted lots of fun and reasonable insurances etc then I might consider a 1.8 td conversion...
Nothing to see here...
- andymac
- Elite Pie Master
Re: Mk3 Fiesta 1.1
thats not a bad idea, you can reach 120bhp with the lynx 1.8 TD engine from just silly mods like upping the boost, fueling pre and post boost, larger (even cheap universal) intercoolers and breathing mods eg air filter and exhaust, and a ton of torque on top (which is the underdog of power gains world)
Re: Mk3 Fiesta 1.1
Torques nice for pulling along, but you need a balance of delivery at both ends - if you get the opportunity for a ride in a Mk2 Focus ST or RS take it, you'll see what I mean then. Tractability is immense and illustrates perfectly what I'm on about.
You're right though, diesel power is fun when in band but it runs out of puff very quickly, MMoGenius had a TD van at one time that was really quite quick (up to a point) - lots quicker than a 1.6 si at any rate
- andymac
- Elite Pie Master
Re: Mk3 Fiesta 1.1
tried it, been down similar routes
you'll skint yourself and piss yourself off. not worth it
ENGINE CONVERSION is the best thing, if your that bothered about having a quick car and paying cheaper insurance, do it and dont declare it. just dont cry when you get your car taken off you.
keep the 1.1 until you can afford something better
also, this message will self destruct in 5 seconds...
- Michael!
