Re: Introducing Katie's Dirty Little Sister...
nice catch,
looks well preserved
good luck
good luck
- GRP16V
- Your car: Fiesta Si /Escort mk6
Yea is it just self tappers? Being picky
Max M4X WW wrote:Yea is it just self tappers? Being picky
Yes
MotorcyclesFish wrote:The thing is if I caught Brian fudgekin a bloke, I wouldn't think 'oh Brian's a gay', I'd think 'Brian that fudgekin weird haired mongoloid is raping a gay to see if anyone finds it funny'
- Rhinopower
- Your car: Volvo FH330
Nice find. Looks tidy enough
My frascati had everything on it! (Was an 'N' plated state blue one too! )
- trecoll
mid level? central locking, electric windows, twin air bags, pas, and most had the 1.3
seems quite high to me
anoying place to rot
Don't forget the boot pop!
Yeah that too Max lol, plus intermittent front wipers. It is missing many minor items though as I said, fag lighter, rear speakers, door trim, boot pannels, C-pillar covers etc.
- Tweek
- Your car: VW Golf GTD
my first mk3 had a passenger airbag as well. it was a mistral
- Minstral
- Your car: *
That looks like a cracking base, Wayne. What's the ZT spec?
So far since I'm still making it up as I go along...
Bored out 2ltr engine with ARIAS pistons (from a F22 engine of all things)
mk1 Focus RS conrods + ARP bolts
T3 turbo, not entirely sure what it's from but 'rs200bhp' off here had it on a FRST, has an uprated actuator though
Exhaust is here too, again unsure on make but it's a T3 with a phat 4" outward rolled tip
Also have manifold adapter plates to fit a FRST inlet and ERST exhaust manifolds.
Still chewing over rad and intercooler. I don't really want to cut out the front bumper much so may go for a double-capacity FRST one and radiator, would have to find new yellow hoses though too. Also need to relocate PAS cooler.
ECU isn't certain yet but I am very keen on going towards Emerald, Gearbox will be uprated too. My ERST LSD box is already starting to whine.
Those are the key elements anyway, all the bits in between will come when they're needed. My personal target for at least having it on the road is FITP 2013, what state the external is in though is another matter.
- Tweek
Tweek wrote:Yeah that too Max lol, plus intermittent front wipers. It is missing many minor items though as I said, fag lighter, rear speakers, door trim, boot pannels, C-pillar covers etc.
Door trim? Boot panels?
nice project
- FRSJON
Looks solid, time for the fun to begin.
- MB7201
- Your car: Fiesta lx
You sure those pistons will fit those rods? I thought frs rods only took frs pistons
- Rhinopower
2-point door handles, manual-window doorcards with bungs in, no carpeted suspension turrents, just bare with caps over the top mountsMax M4X WW wrote:Tweek wrote:Yeah that too Max lol, plus intermittent front wipers. It is missing many minor items though as I said, fag lighter, rear speakers, door trim, boot pannels, C-pillar covers etc.
- Tweek
Ah ok, forgot about all this stuff lol. Mine will have a full dark frst interior and that's it.
Rhinopower wrote:You sure those pistons will fit those rods? I thought frs rods only took frs pistons
Just confirmed it, frs gudgeon pin is 22mm, all other zetec rods are 20mm
- Rhinopower
One's already assembled from where it was previously test fitted in an engine, They're not Zetec pistons, they're Honda F22 pistons, info copied from ARIAS job sheet:
Displacement: 134.71 / 2208.36
Finished Bore: 3.386 inch / 86mm
Stroke: 3.74 / 95
Rod Length: 5.571 / 141.5
Comp. Height: 1.215 / 30.86
Compression: 8.2 / 8.2
Pin Diameter: 0.866 / 22
Top Groove: 0.06 / 1.5
2nd Groove: 0.06 / 1.5
Oil Groove: 0.158 / 4
Piston Weight: 313
Stroke: 3.74 / 95
Piston Weight: 313
- Tweek
They must also be 22's then
- Rhinopower
Just added piston spec sheet above, bearing in mind they're Honda specs but the measurements tick the boxes.
- Tweek
id love to buy the old zetec hoses if your selling them
lol aye forgot about them smaller things, still higher than some Si's and xr 8v
Right, today I sat inside it inspecting everything to look for any bodge jobs that have been done or any broken things that need doing. It's major stuff!
- Driver's window switch faulty
- Clock doesn't work (replaced with the 5dr clock to test which worked fine)
- Cluch pedal manual adjuster is missing the white knob from the front
- Crack in passenger speaker grille
- Passenger door mirror adjuster "collar" missing
Might take me 5 mins if I drag it out
Everything else is as new, just dirty!
- Tweek
Tweek wrote:Right, today I sat inside it inspecting everything to look for any bodge jobs that have been done or any broken things that need doing. It's major stuff!
Just gotta break something along the way. Something that you never, ever get round to.
- DanFraser
Tweek wrote:- Cluch pedal manual adjuster is missing the white knob from the front
That's weird. My Frascati was missing the white knob too.
Even with it replaced, I always had to stick my foot under the clutch pedal to bring it all the way up and stop the clutch slipping!!
- trecoll
trecoll wrote:Tweek wrote:- Cluch pedal manual adjuster is missing the white knob from the front
There's a white thing on the clutch?
- DanFraser
- Tweek
I'd advised against the FRST double capacity cooler. I take it you mean the one that sits in the place of the standard one but is bigger?
If so, (and you are running with the frst rad) it means you have to have the radiator at a silly angle, then with the T3 turbo, it will look super bodged.
Ex Fiesta RS Turbo owner
- filtra
Advice noted. Will have a rethink on that then cheers
- Tweek
Chop the wings off and start fresh
Looks good apart from that tho...
- TIL13R
you got it then
i suspect the rust on the wings where they meet the front panel is prob due to replacment wings early in its life and it was never protected right, cos ive not seen rot on a fiesta there that bad before.
i wouldnt mind betting the rust is deeper, beterrn the wing lip and slam panel, prob best to chop them sections out and replace them with new metal, not worth binning the complete wings though, although is that dirt, or rust on the tip of the drivers wing above the indicator?
nice project hopefully u do keep it a nice little sleeper
- Rs Adz
Looks like a good base there Tweek Look forward to seeing this progress
1600cc T2= 220bhp 222 lbs/ft
- Russ FRST
Just bought some very expensive number plates for this car Project will be known as "K80"
- Tweek
I like what you did there!
I hope the last 3 letters was BHP so everyone thinks its got 80bhp and they dont realise it has about 200 on top of that
- - Danny Boy -
- Your car: Fiesta Si 2.0
