Re: Project "K80" ZT - Let's Get Started... (10/05)
knuckles wrote:jayrs wrote:you redoing the locks your self wayne?
i did them
so f**k off !
LMFAO
- RSGeorge
- Your car: Saab 9-3 & VW T4
LOL Clark has infact done them for me and apparently they work too
- Tweek
- Your car: VW Golf GTD
thats good then mate.
i was only going to offer advice if you were going to rebuild them yourself
- knuckles
- Your car: Fiesta Rs turbo
in a strop now
jonyb4 wrote:in a strop now
who? me?
if so, no mate, not at all
Does it have a trip meter Wayne?
- hb69
- Your car: Fiesta 1.1 LX
Is it going to be a higher spec?
- dontpannic
Dunno if I can match "high-spec" tbh.
- Tweek
no guys you have to remind me to laugh
Wayne, If you give me your address I'll send you those C-pillar trims.
- ~S1~
- Hold On...
ive just found a brand new genuine ford silvertop water pump in my garage if your interested wayne
- knuckles
Feeling left out by not having any required MK3 parts to offer you, I've just found a half eaten chocolate digestive in the back of my shed if you want it Wayne. Just let me know.
- dontpannic
dont really know whats going on
but i have a brand new orignal zetec oil filter
- Minstral
- Your car: *
Re: Project
Sheriff Burman wrote:Feeling left out by not having any required MK3 parts to offer you, I've just found a half eaten chocolate digestive in the back of my shed if you want it Wayne. Just let me know.
sod him, i'll have that
Am I still ok to have the 1.3 when it comes out?
- hb69
Can I have jayrs when he comes out?
heeman10 wrote:Can I have jayrs when he comes out?
wtf
and no
- hb69
Re: Introducing Katie's Dirty Little Sister...
I keep pondering a zt build but i find it a mine field with pistons and rods, i.e what pistons to get, then knowing if i can use standard rods, or if alternative items are required etc. From some research i done a while ago it seemed the vauxhall 86mm pistons were an "easier" way to go, but then the standard rods need adapting to fit!
What pistons and rods are these that you are using?? pm if you dont want to post it here, any help / advice is much appreciated.
Gareth.
- black2
Honda pistons. Been covered in the thread somewhere
- - Danny Boy -
- Your car: Fiesta Si 2.0
Re: Project "K80" ZT - New Engine Stripped (20/05)
Pistons are made by ARIAS and were actually made for a Honda F22 engine. All the numbers on them add up to fit a ZT though using FRS rods which is nice.
Today I have stripped down the new engine ready to be modified and rebuilt. I had planned on taking a photo of what the engine looks like now but I forgot Very strange discovery though is that it seems to have a 1.8 head on it?! Not too happy about that, no idea if some came like that from factory or not but I shall be refitting a 2ltr head on anyway. Pics below show the head with the "1.8 HO" stamp, 2ltr ones I've seen have "2.0 MO" stamped inside them It's a 1997 Series 2 engine if that matters.
And finally, I've also found some Nissan 200SX (SR20DET engine) side-fed injectors rated at 370cc, so if and when they turn up it gives me the option of running the Zetec inlet rather than the FRST.
- Tweek
Re: Project "K80" ZT - Engine Stripped With 1.8 Head?! (20/05)
Have you got another head yet? The 1.8 head may be fine, it's 45 cc instead of a 2 litre head which is 50cc. It just depends what compression ratio the bottom end gives you. That all needs to be calculated correctly
MotorcyclesFish wrote:The thing is if I caught Brian fudgekin a bloke, I wouldn't think 'oh Brian's a gay', I'd think 'Brian that fudgekin weird haired mongoloid is raping a gay to see if anyone finds it funny'
- Rhinopower
- Your car: Volvo FH330
knuckles wrote:ive just found a brand new genuine ford silvertop water pump in my garage if your interested wayne
2.0 or 1.8? if its a 1.8 ill swap you as ive just bought a gen 2.0
- FRSJON
Get a syringe and measure those combustion chambers, Wayne.
I can't see there being any other difference between your head and a 2.0 head other than the chambers, so like Ryan says, you may be fine, depending on compression ratio. My 2.0 head was a late one, too, something like a 96 or 97. The one I looked at first with nothing on was an early one. I'd swap you, but the reason I'm not using my 2.0 one is because it's been skimmed so much in a past life that my pretty straight 1.8 head seemed the better option!
- Smo
How do I do that then Mr Barter?
I've googled and ebayed the casting number on the side of the head and every result comes back as a 2ltr? If so then why does it have a fecking 1.8 stamp inside
- Tweek
I expect the heads are cast before machining and stamping.
You need to use a syringe to measure the chambers as Simon said, but ....
Put an old cd on top of the chamber, sealed with a smear of Vaseline
Use paraffin to fill, you will know its full when the miniscus is level with the bottom lip of the cd hole. As long as you can fit 50cc in your in luck. Remember tho, this will change when you have the head skimmed. 1mm skim can increase c/r by 0.5 iirc on a 86mm bore zt. If you look back through one of my threads I've got all the calculations you need
- Rhinopower
Could you not just measure the diameter of the chamber where it's circular?
- MB7201
- Your car: Fiesta lx
MB7201 wrote:Could you not just measure the diameter of the chamber where it's circular?
No. You are measuring volume not diameter.
- Rhinopower
I would have thought the chamber would be different diameters between the 1.8 and 2.0 though to closer match the bore size?
- MB7201
As Ryan says, that's pretty much how I measured mine and found out my 2.0 head was pointless! I think all my 2.0 chambers ended up being 44.5cc each.
I know what Mark is trying to say, as the diameter of the rounded part of the chamber should determine whether it is a 1.8 or 2.0 head regardless of what the chamber size is. If Wayne measures his and it's over 80(ish)mm then it should be a 2.0, as I remember checking a 2.0 head out ages back to see if I could use it on a 1.8 block and it was larger than the 1.8 bore... So as a rough answer, it should tell you something!
- Smo
which ever head you go with they both flow the same it will just change the CR,
what does that rod and piston combination give on a 2.0 zetec?
