Idle problems on FRST
5 posts • Page 1 of 1
Hi Fellas,
I have a frst when on idle it runs fine, the problem I have is when you blip the throttle the revs hang for about 10 secs and then drop to normal but if I disconnect the iscv it revs ok. Things I have done are,
Brand New items are ISCV, CO Pot, Map Sensor, ACT, Water Temp Sensor, CPS Sensor and I have checked for air leakes, set the base idle and it is still the same.
Any help please as this is really frustrating me now.
Mark.
Mark.
- FiddlersFRST
- Your car: Ford Fiesta Rs Turbo
Re: Idle problems on FRST
How did you check you air leeks? Also checked breather isn't blocked
- rich1987
- Your car: fiesta rs turbo (zvh)
Everything is more or less brand new when the engine was built, breather is brand new. I used starter spray to check for leaks.
- FiddlersFRST
That actuallly sounds not too bad for a FRST tbh matey. They do kinda hang for a bit before returning to tickover but if she runs grand & drives fine id leave her as is, loads of us wish ours ran like that instead of the car dying on tickover
CheeRS
BOBFRST
CheeRS
BOBFRST
- BOBFRST
- Your car: 1991 Fiesta RS Turbo
FiddlersFRST wrote:Hi Fellas,
Mark.
Have u tried another throttle position sensor ?
The contacts inside them do wear across the range causing issues - I stripped one down to find this out on my xr2i but then the sensor is no good once opened.
Try another TPS . And make sure your inlet manifold gaskets are good - any air leak will cause it to hang.
- knuckles
- Your car: Fiesta Rs turbo
