[info] How do I know if it is an RS1800 engine?
Postby winterracer on Wed Jan 19, 2005 7:42 pm
I'm looking at possibly buying an RS1800 engine for my si but all the good ones seem to be miles away which would mean it would be cheaper to courier it instead of collecting, can anyone tell me if there is a way i can verify that the engine is an RS1800 and not a 105bhp model? ie engine number etc
[identification guide below :Q]
winterracer
engine
Postby Brammer on Thu Jan 20, 2005 7:30 pm
I just thought that rs1800i was just a stock 1.8 16v maybe with a few tweaks you'll pay extra for that rather than just out of an escort 1.8 16v why don't you get in touch with car transplants they will have loads of 1.8 and 2.0 16v engines
Brammer
Your car: Sierra Cosworth
Postby winterracer on Thu Jan 20, 2005 9:33 pm
its going to work out at the mo that an rs1800 engine is £50 more than an escort one, but then i would have to swap over bits from my fiesta's engine to make it fit which means buying gaskets and then to get it to 130 brake i would need to buy a 2.0 throttle bodie and cams.
I think i'll stick to paying £50 more :wink:
oh and btw if anyone does want to know how to find out the type of engine i found a guide :
The engines have the cc size stamped on the side but the power output is on sticker on the air pipe and wears off. However there is a stamp on side of the cylinder block (gearbox side) which will tell you exactly what engine you have got. The following is a decode:
Escort/Orion/Fiesta
First letter/number
L - 1.6
R - 1.8
N - 2.0
Second letter/number
I/1 - 66kW/90 bhp (65kW/88 HP on certain models)
D - 77kW/105 bhp
K - 85kW/115 bhp
Q - 96kW/130 bhp
Mondeo
First letter/number
As above
I/1 - 66kW/90 bhp (65kW/88 bhp on certain models)
K - 85kW/115 bhp (82kW/112 bhp on certain models)
G - 100kW/136 bhp
The third letter is the emission standard apparently B & J are the latest standard.
winterracer
Postby mike_wall15 on Sat Jan 22, 2005 8:19 pm
winterracer - Nice bit of info there :Q
My engine number begins with NG....which match's to the 2.0L I have, phew! :lol:
Where did you find this info?
Muchos thankios :aviator:
mike_wall15
Car: 2002 BMW M3
Postby winterracer on Sat Jan 22, 2005 10:58 pm
Ahhh many hours of surfing and reading :Q Links Below:
http://zetecescorts.bravehost.com/Engines.html
winterracer
Postby mike_wall15 on Sat Jan 22, 2005 11:24 pm
Cheers mate :aviator:
mike_wall15
Car: 2002 BMW M3
Postby Percy! on Tue Feb 01, 2005 2:16 pm
Gonna check my engine number later now just to see!, where is it on the zetecs? worried I will find NK
If you have no luck gettin an RS1800 engine I do have some 130ps cams from a 2.0 I want rid of as I have piper cams in mine. Would want about £70 for them with pulleys and followers.
Percy!
Your car: Citreon
Postby wayners1800 on Thu Apr 28, 2005 4:33 pm
Great article and info... but whereabouts exactly on the head are the no's?, I ave looked but cant find them?
Wayne.
wayners1800
rs1800 engine
Postby gibbsy on Thu Nov 03, 2005 2:59 pm
an rs 1800 engine should have RQC stamped on the cylinder head just to the front of the thermostat housing up on a little like tab like bit on the cylinder head
gibbsy
Postby jdfiesta on Mon Nov 14, 2005 4:47 pm
on my block, on the raised bit. stamped on that is PJ*****
it's definately a 2ltr engine though
JJ
Is that the best you can do?
jdfiesta
Your car: V70 T5
