Fiesta rs turbo 2.1 zvh full resto unlucky 13 ?!
83 posts • Page 2 of 3 • 1, 2, 3
Re: White FRST restoration unlucky 13 ?!
Smo wrote:Your Fiesta is looking lovely, nice work! The green springs are a great contrast, but almost a shame that they'll hardly be seen!
Do you work on just classics, or is it varied? I'm not a huge E type fan, but it's looking good!
Cheers !
Im hoping to show it next year so the suspension etc will be visible when on axle stands with the wheels off
Its mainly the newer stuff I work on but if something interesting comes in I'll take it on !
- tin-ribs
- Your car: fiesta rst
Spot on fella.... Where u based? And wotcha coat underside in, looks like epoxy..?
- Fraggle
Fraggle wrote:Spot on fella.... Where u based? And wotcha coat underside in, looks like epoxy..?
Yeah it's Bonda anti rust red oxide primer.
Any progress on yours mate, haven't seen any updates for a while ?
- tin-ribs
Nah just harvesting the dry crop supply lol.
I'm hoping this month to make a push if i can get what I'm after......
Keep the progress going bud, you've made a remarkable transformation to it
- Fraggle
Fraggle wrote:Nah just harvesting the dry crop supply lol.
Cool !
Much appreciated
- tin-ribs
Not too much to update but here goes...
Managed to pick up some gaz coilovers, had them polished and the springs powder coated. Also had some gaz stickers made up but yet to fit them !
- tin-ribs
I ve had new brake lines made up and etch primed and painted them to factory colour.
Bought some st150 front calipers and discs. Stripped the calipers down, had them powder coated and built them back up with new service kit (seals, rubbers etc).
Also converted the rear brakes to discs, just need to fit the calipers.
Fitted the fuel tank, just waiting for a few more under body clips and the car will be ready to come off the jig !
- tin-ribs
Finished building rear calipers today and fitted them alongside new pagid discs and pads. I just need to fit the handbrake cable now and hopefully I can get it on the ground next week ready to start the bodywork.
Also my new stage 3 T3 turbo turned up !
Here's some pics of brakes before and after.
- tin-ribs
This is going to be awesome, great job so far.
Can't wait to see the final result.
Psssst dump valves rock!
- nick.king
- Your car: VW Passat 170 TDI Sport
Cheers pal !
Car is on the ground now and bodywork is well on the way. The so called engine builder has turned round after having my engine for 2 years and said 'I haven't got time to build it can't you just take it to puma build ?' .So I've collected all parts and dropped them down to a more professional outfit that have experience in building a zvh.
- tin-ribs
Here's a few pics of the engine build, hoping to get it back in the next week or so. As you can see from the pics, the block has been drilled/modified for the zvh conversion. Oh, and could anyone advise me on the next upgrade from beiges with ofab?
- tin-ribs
Got my engine back which is good, but found out the stage 3 port and polished head I bought for it is mfi !
Spoke to Jano at oddkidd today (very helpful ) and I've ordered an adaptor plate to solve the problem.
I assumed that both the escort and the fiesta turbo engines were the same ? How wrong was I
- tin-ribs
tin-ribs wrote:Got my engine back which is good, but found out the stage 3 port and polished head I bought for it is mfi !
jano's a top bloke mate, he'll always help you out when he can
- pauldolman
So after many many man hours over the last few months attending to every scratch, dent, chip, rust and any other imperfection I finally got my shell into a condition I was happy with to prime.
Any minor rust was treated with red oxide before the shell had x3 coats of lechler's TI high build primer applied.
The plan next is to get the rest of the panels to the same stage and then it's just a case of prepping and painting everything together.
Hoping to be on the road next summer.
Hoping.........
Hoping.........
- tin-ribs
Managed to prep and prime the rest of the panels.
Also had more fixings back from zinc platers.
- tin-ribs
Started to build up the engine but ran into a problem with the exhaust manifold catching the breather blocking plate/bolts which prevented the manifold from sitting flush to the head.
Solved the problem by grinding a tad off both the manifold and the blocking plate and fitted countersunk allen bolts
Painted the manifold black with high temp paint to freshen it up.
Also fitted the adaptor plate for the inlet manifold.
Plan now is to get the inside of the car prepped and painted then fit the wiring loom ready for the engine to go in.
- tin-ribs
Removed old sound deadning and replaced with new.
Painted the inside
Painted the inside
- tin-ribs
Hi, Where did you get the hard sound proofing that you painted over? Currently removing all the original from mine now and will need to replace... Plan to paint inside similar to yours.
Lovely car!!
Lovely car!!
- RossYB
- Your car: Fiesta Mk6 ZS 1.6TDCI
Hi,
Most paint suppliers will sell sound deadning pads that you can buy over the counter.
Google body shop suppliers / automotive paint suppliers in your local area.
Good luck and thanks for the comments
- tin-ribs
Soooo making progress on this now and have booked a few weekends aside to work on it.
Bonnet was prepared today to have flush aero catches fitted. I had a right game getting the door hinge pins out when stripping the shell which resorted in 3 of them coming out in 3 pieces and only one decent one remaining ! As these are no longer available I used this one to have 4 new ones made up at an engineering company thanks to my father in law !
Body kit and bumpers have been painted, applying x3 coats of base followed by x4 coats of lacquer leaving 15 min flash off in between then leaving to air dry to reduce any sinkage. Recommended is x2 coats but as I plan to flat and mop the whole car I wanted to make sure I had something to work with
Rest of the car will be painted next week, cannot wait
- tin-ribs
Good job with those pins! Coming along nicely.
Thanks for the comments
So now the car was in primer it was a case of prepping it ready for paint. No air or electrical sanders were used in the prep, every panel was wet sanded on a block by hand
Again, x3 coats of base coat followed by x4 coats of lacquer no thinners
Fitted the doors which lined up nicely.
In the process of stripping bits for the zinc platers before fitting them back to the car.
- tin-ribs
Cheers Paul !
Tailgate painted and fitted.
Can't beat freshly painted diamond white
- tin-ribs
Looks lush mate!! Love Diamond white, my first Fiesta was a 1.1 pop plus Si replica in Diamond white.
Do you have any photos of the underside of the bonnet where the aerocatches are going to be fitted?
Paul
Paul
Fiesta Si 2.0 16v
Mods: K&N 57i, 2.0 Silvertop, Samcos, GAZ Coilovers, Quaife Straight cut box, Wilwood 4-pots, stripped out track female provider of 'horizontal refreshment'
Planned: GSX-R 1000 ITB's, ST170 4-2-1 Manifold, Megasquirt 2 ECU, OBP Pedal box
- elPaulio
- Your car: Mk3 Fiesta 2.0 Zetec Si
Cheers pal appreciate the comments
Yeah I'll get some pics up the weekend of the underside of the bonnet.
- tin-ribs
You're welcome bud Looks like a lotta love has gone into her!
Nice one! that'd be brilliant, just looking to see what I need to cut out
Fiesta Si 2.0 16v
- elPaulio
Was the engine bay painted the same time as everything else? I'm guessing so, couldn't see a photo of it
- pauldolman
No Paul, I painted the engine bay a while back because originally I was going to get the engine in/running before complete respray.
Pics are on page 1.
Here the pics of the aero catches holes on the underside as promised....
Pics are on page 1.
- tin-ribs
