Fiesta Bonus - Zetec Turbo Update - Cooling update 31/7/13
Re: 2.0 ST170 Bonus Dirtbox Sleeper - Update 20/3
Postby knuckles on Sun Mar 20, 2011 10:06 pm
juicy :)
knuckles
Your car: Fiesta Rs turbo
Postby Smo on Sun Mar 20, 2011 10:20 pm
Can't wait to see this go :D
Still going to use the nitrous?
Smo
Postby Rhinopower on Sun Mar 20, 2011 10:26 pm
Smo :Can't wait to see this go :D
Yes, changing to direct port instead which gives a much better boost for the same size shot so even if it makes 170bhp + 50bhp shot i'l get over 200 n/a :Q
Rhinopower
Your car: Volvo FH330
Postby jonyb4 on Mon Mar 21, 2011 2:17 am
this is gonna be ballistic :Q
Postby Xr2chris on Thu Mar 24, 2011 10:28 pm
You have to pay for it first lol looking good tho :D
Xr2chris
Postby Smo on Fri Mar 25, 2011 7:32 pm
Xr2chris :You have to pay for it first lol looking good tho :D
Chris the gearbox-delivering legend! :aviator:
Smo
Postby ~nomad~ on Mon Mar 28, 2011 7:36 pm
Gave the bay a quick clean and cut the old engine mounting area out today, and gave the area a lick of paint. It could do with grinding back a bit more tbh, but time is tight for fitp, the car may be tidied up a bit later in the year so can sort bay out then.
~nomad~
Your car: Breadvan
Postby Rhinopower on Mon Mar 28, 2011 7:45 pm
Looks good in there! I think i will lift engine in tomorrow and then get my mount welded!
Rhinopower
Postby jonyb4 on Mon Mar 28, 2011 8:37 pm
there used to be a mount there :)
Postby Ratspeed on Mon Mar 28, 2011 9:11 pm
jonyb4 :there used to be a mount there :)
10 points to detective jony :lol:
Ratspeed
Postby jonyb4 on Mon Mar 28, 2011 9:12 pm
Postby Excursion on Mon Mar 28, 2011 9:22 pm
~nomad~ :Image
Go on, do the lot 8)
Postby Rhinopower on Mon Mar 28, 2011 10:06 pm
I cant be arsed to take any more than that, my elbow aches from drilling 7 days a week :lol: Will at some point tho when i completely strip and repaint the shell.
Do you think i would get away with rear alternator now?
Rhinopower
Postby Excursion on Mon Mar 28, 2011 10:11 pm
Rhinopower :I cant be arsed to take any more than that, my elbow aches from drilling 7 days a week :lol: Will at some point tho when i completely strip and repaint the shell.
No mate, it fouls on the 'brakcet' going down from the chassis leg to the front bolt on the lower arm carrier.
Postby Rhinopower on Mon Mar 28, 2011 10:17 pm
Ah never mind. I'm watching a new loom on ebay so hopefully pick that up (as long as it has all the wires!) fit the connectors and have it running soonish!
Rhinopower
Postby jonboisescort on Mon Mar 28, 2011 11:13 pm
looking good about the alternator ive put a rear mounted one on the escort
it sits quite high up
the mounts ive got are off a mondeo with a blacktop
jonboisescort
Car: 1994 Ford Fiesta
Postby jonyb4 on Mon Mar 28, 2011 11:55 pm
gotta make sure the belt clears too mind you
Postby Rhinopower on Tue Mar 29, 2011 9:38 am
I had a spare 20 mins this morning so dropped the engine in.. As you do!
Mount is sitting pretty close to the wing (its touching)
The sump needs a bit more modifying, its currently resting on the CV so im going to chop a bit more of where it is, not lifting out again :lol:
And where the focus inner wing mount needs to be welded in
Rhinopower
Re: 2.0 ST170 Bonus Dirtbox Sleeper - Update 29/3
Postby ~nomad~ on Tue Mar 29, 2011 10:32 am
getting there, whens John coming to weld it?
~nomad~
Your car: Breadvan
Postby jonyb4 on Wed Mar 30, 2011 1:03 am
so glad this aint me doing it, alot of work :(
will the mount bang and knock on that bracket?
Postby ~nomad~ on Wed Mar 30, 2011 1:45 am
I reckon so as it sits, not sure if Brian is planning to cut the last of old mounting down or take a bit off the bracket.
~nomad~
Your car: Breadvan
Postby jonyb4 on Wed Mar 30, 2011 2:23 am
a bit of both might even be needed?! :(
Postby ~nomad~ on Wed Mar 30, 2011 11:04 am
maybe, I think it will more rub than knock.
~nomad~
Your car: Breadvan
Postby Rhinopower on Sat Apr 02, 2011 7:08 pm
Little more update, started fiddling with the mount more. Ive got to hack a bit more out of the inner wing / strut and then plate it up to give clearance. Im also going to have to make a spacer to weld in from the front of the mount to the chassis leg, and cut a little triangle to go in at the back of the mount, sadly the angle grinder went up in smoke so i couldnt make up the rest of the bits ready for welding.
Rhinopower
Re: 2.0 ST170 Bonus Dirtbox Sleeper - Update 2/4
Postby Rhinopower on Thu Apr 21, 2011 8:08 pm
New mount all welded in, more pics to follow tomorrow, head is on, power steering rack is in (bulkhead needs modding to get the UJ through), and just need to find a few parts i've put away safely and cant find :rolleyes:
Rhinopower
Re: 2.0 ST170 Bonus Dirtbox Sleeper - Update21/4 - Engine fitted
Postby Smo on Thu Apr 21, 2011 8:36 pm
Very nice!
Mine's not really going to have much of a chance if a rematch ever comes up :lol:
Smo
Postby bakewell001 on Thu Apr 21, 2011 8:59 pm
Smo :Very nice!
That's because you are a lazy bugger, even when i offer to help! :P
bakewell001
Postby jonyb4 on Thu Apr 21, 2011 11:02 pm
Smo :Very nice!
dont worry im sure you'd kick my arse :bonkers:
hey that looks really good ryan, top work, can barely see the old mount
Postby Rhinopower on Thu Apr 21, 2011 11:10 pm
He had to do a little patch over where i had butchered before but its a nicer shape i think than the original. Cant take credit for the welding, was done by an old boy we use. Got the bit of st170 mount tacked in and then build the rest up with one rectangle bit and a few triangles for strength. Suprisingly good clearance for working on the cambelt side of the engine.
Rhinopower
Postby jonyb4 on Thu Apr 21, 2011 11:12 pm
good, my mk4 didnt when i put a zetec in that!, thankfully i never had to change it :rolleyes:
nothing worse than having to drop the engine most the way out just for a timing belt
Postby Rhinopower on Fri Apr 22, 2011 7:43 am
Just really need to find my vvt solenoid & cam caps and the cambelt backplate, I'm at a standstill with the car
Rhinopower
Postby ~nomad~ on Fri Apr 22, 2011 10:16 am
I will have to completly remove the engine to do anything in the Ka :(
~nomad~
Your car: Breadvan
Postby Excursion on Fri Apr 22, 2011 11:18 am
That's not going anywhere, nice one :D
Postby Rhinopower on Sun May 01, 2011 7:41 am
Replacement head is built up, the missing cam bearing wasn't replaceable and not to be found :(
I've lapped in all 16 valves, just need to check the clearance if the litters now, and return the valve spring compressor to halfords!
Rhinopower
Postby Excursion on Sun May 01, 2011 1:58 pm
What cam bearing is missing, Ryan?
Did you steal that tool? :o
